Old 05-28-2014, 10:31 PM   #71
Cards2323
Drives: 2014 BRZ Limited-SWP
I thought I read that the +45 rubs somewhere in the front at full lock and it couldn't be avoided...
Cards2323 is offline   Reply With Quote
Old 05-28-2014, 11:02 PM   #72
mrk1
Drives: Sterling BRZ Ltd
I have 17x9 et38 with 255 and its a meaty setup, Im on coils so I wishing I got 42 or so. Real close to the fender.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 06-13-2014, 08:15 AM   #73
captainzib
Oompa Loompa of Science
Drives: Scion FR-S
Yes, I ended up going with 255 tires and +45 wheels. It rubs at full lock. I can live with that.
captainzib is offline   Reply With Quote
Old 07-14-2014, 11:56 PM   #74
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Is -2 degrees front camber possible with the +35s and 245/40 Michelin pss? How close would it be to the spring/strut lowered on eibach prokit?
eSOLOR is offline   Reply With Quote
Old 07-16-2014, 02:34 AM   #75
jsc1234
just got my rpf1s today. 17x9 +45 planning to slap on 235/45s on them. and -2.8 camber. what do you guys think?
jsc1234 is offline   Reply With Quote
Old 07-16-2014, 07:57 PM   #76
kosoku
Drives: 2013 fr-s
I think +35 is better
kosoku is offline   Reply With Quote
Old 11-12-2014, 02:17 AM   #77
Drew97
Drives: 2014' Brz Limited
I want to run 17x9 +32 offset does anyone know if it will rub my fender if i drop it at 1.5 inches
Drew97 is offline   Reply With Quote
Old 11-12-2014, 10:57 AM   #78
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Depends on your camber and tire size.
Old 12-04-2014, 04:50 AM   #79
ravisraval
Drives: 2013 FRS
Will 17x9 +45 with Super Sports on completely stock everything give me any issues?
ravisraval is offline   Reply With Quote
Old 12-04-2014, 05:14 AM   #80
s2d4
s2d4's Avatar
Why not just get +35 so you won't have any of the limitations on +45?
Old 12-04-2014, 05:18 AM   #81
ravisraval
Drives: 2013 FRS
I got a deal on used +45s
Old 12-04-2014, 07:43 AM   #82
s2d4
s2d4's Avatar
Probably why you got the deal.
Old 12-04-2014, 07:44 AM   #83
lbejosano
Drives: 2014 Firestorm Scion FR-S
I second the +35 suggestion. From an aesthetic standpoint (disclaimer: MY opinion) it looks better, the rear wheel isn't sunken in to the fender like a +45. Any poke in the front can be addressed with extra camber.
From a functional standpoint, you have the option of fitting a BBK behind the wheel down the road, but more importantly, rubbing issues in the front are minimized. At worst, the only rubbing you'll run into will be induced by a huge tire (e.g., 255s with stock spring perches).
lbejosano is offline   Reply With Quote
Old 12-04-2014, 10:44 AM   #84
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
I fit 245/40 rs3s on completely stock suspension fine with +45, but you can't run any more camber than stock spec. I've done 3 autoxs with them with no issues aside from wanting more camber.
Mad_Mike is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 02:35 PM
RPF1 are coming in 17x9 5x100 in Nov! Cheddar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-23-2012 07:23 PM
