Old 05-29-2014, 11:35 AM   #15
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
Originally Posted by xxscaxx View Post
In order to basically change the bulb out you have to disconnect the harness plug from the light, which will kill power to it. So even if you used a screwdriver it wouldn't matter, but these bulbs are easily removable with your finger, so if your using something to pry them out I don't know what to tell ya
Right. I was trying to say either disconnect it and use the screwdriver or leave it plugged in and use your fingers. It's not as easy for people with bigger fingers lol (my friends case) since it's kinda a tight space.
Husker BRZ is offline   Reply With Quote
Old 05-29-2014, 11:36 AM   #16
xxscaxx
Drives: 2013 SWP BRZ
True - that comment wasn't pointed at you btw, just was a general statement lol
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Husker BRZ (05-29-2014)
Old 05-29-2014, 11:52 AM   #17
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Originally Posted by Poodles View Post
Said this in the other thread, but I'll say it again.
If the OEM is stupid enough to not use a fuse on a circuit that could potentially short out and damage an expensive component, it's all on them. It's what they're there for.
There's always a possibility of water getting into the door (that's why they have weep holes at the bottom) and shorting it out. Just seems like a terrible oversight IMHO.
So you want one fuse per lightbulb?
Rayme is offline   Reply With Quote
Old 05-31-2014, 02:14 AM   #18
Poodles
Drives: 2015 Series.Blue
No, they're usually grouped in with the dome light or something else.
This is how cars have been made forever. All circuits should have fault protection for safety.
The Following User Says Thank You to Poodles For This Useful Post:
kuhlka (06-16-2014)
Old 06-01-2014, 12:25 PM   #19
Enders FRS
Drives: FRS MT SE 10 edition
So, which line is it going to the BIU and what amperage is it ok with? Sounds like an easy fix with an inline fuse.
Reason why I ask, is I plan on adding some puddle lights to the dome light circuit.
Enders FRS is offline   Reply With Quote
Old 06-30-2014, 04:31 AM   #20
quark
Possible short issue
Checking out thread, I noticed that the LED bulb has a solder joint that sits just next to the metal frame, the frame carries the power.
This may be why some get the dreaded dead controller issue.
This metal frame should be insulated with black tape before inserting the Led.
Does anyone have one of the LED's to verify potential for short?
Here is the solder joint (taken from joergasm)
http://www.ft86club.com/forums/showthread.php?p=1137701
quark is offline   Reply With Quote
The Following User Says Thank You to quark For This Useful Post:
illicitstylz (06-30-2014)
Old 07-08-2014, 02:24 PM   #21
Oliverrick
Drives: 2013 BRZ Limited
Smile Got the Body integrated unit replaced on warranty!
It's finally replaced! Today is a good day. It only took one hour because the Tech that did it knew in advance he would be doing the replacement so he read up on it over the 4th of July weekend. The key fobs did not need to be reprogrammed on the BRZ's. I'm a happy camper! Now summer will be even better. Thank's again to everyone that gave me advice on what to do. Rick
Oliverrick is offline   Reply With Quote
Old 07-16-2014, 01:01 AM   #22
cslntuee
Drives: Subaru BRZ Limited
Did you plan to put the aftermarket door LED again?
Thanks.
cslntuee is offline   Reply With Quote
Old 09-07-2015, 04:05 PM   #23
Slade
Slade's Avatar
Drives: 14 Limited BRZ
So its not safe to put LED in the courtesy lights in a Limited BRZ or it will fry everything. But what about putting them in the License plate?
Slade is offline   Reply With Quote
Old 09-07-2015, 05:44 PM   #24
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Got these from diode dynamics. Installed them 2 months ago and no issues. I'm sure for the BRZ, it's no different.
http://www.diodedynamics.com/store/l...nse-plate-leds
The Twins make me smile
Old 09-07-2015, 11:51 PM   #25
Poodles
It's fine for both... if you just buy the LED assemblies.
http://www.fteightysix.com/appearanc.../#.Ve5NaYuFOUl
Old 11-01-2017, 08:23 PM   #26
Jhood
Jhood's Avatar
Drives: 2014 BRZ Limited [6MT/SWP]
Soo I know this is 2 years old, but I need to know.. after this BIU is fried and you noticed that the door lights continue to stay on when the door is closed, is that literally the ONLY thing that it effects? I have the same issue from an LED install, but I'm out of warranty at 50k miles.. so honestly if all I have to worry about is a tiny light left on, I'll def opt out of a $500 bill and 5 hour wait time. Frustrating because this happened at around 30k miles, I was just too lazy to look into the issue until now and it's mind boggling how shorting a door light bulb fries an entire BIU
|FBM Stage 1 Build|GTX2867R|
|Moto-East Flex Fuel & Dyno Tune|
|360whp / 265tq (E81 @ 12psi)|
Jhood is offline   Reply With Quote
Old 11-01-2017, 10:41 PM   #27
Poodles
Going to run your battery down. I honestly don't know if anything else is affected. The module MIGHT be repairable, but I've never seen the inside of it or what might have failed. Good electronics repair shop might be able to fix it.
JDM GT86 Interior Parts Upgrade (Steering Wheel & E-brake Handle) ZetaPerformance_CS Cosmetic Modification (Interior/Exterior/Lighting) 33 02-18-2016 06:09 PM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
Courtesy Light Stays On After LED Upgrade milhouse Cosmetic Modification (Interior/Exterior/Lighting) 11 01-28-2014 04:45 PM
RedlineGoods wants you to SAVE 50% on your custom leather interior upgrade! RedlineGoods Southern California 6 01-13-2014 05:08 PM
