Old 07-11-2014, 03:30 AM   #113
yoruck
Drives: ford fiesta st 150
Originally Posted by shiv@vishnu View Post
International folks will be able to test v2.0 very soon
so happy
yoruck is offline   Reply With Quote
The Following User Says Thank You to yoruck For This Useful Post:
GT86meMR2 (07-11-2014)
Old 07-11-2014, 03:46 AM   #114
s2d4
s2d4's Avatar
@shiv@vishnu
Can you please change the placement for 0 for FLCK (in blue on the pic)?
Half way in between current placement and the placements for IAM and FBKC would be perfect.
Right now it just gets cluttered with AFR/commanded AFR except for during WOT.
Can you also change the FLKC degree text to the degree symbol like FBKC please?
DI mode only appears to be off by quite a bit in terms of scaling.
Old 07-11-2014, 04:27 AM   #115
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
So is the stg2 el e85 b01c map going to support LC and FFS, or just the stg1 maps?
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 07-11-2014, 04:37 AM   #116
Kodename47
Kodename47's Avatar
Drives: UK GT86
The problem is that PI/DI scaling is very car specific.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-11-2014, 07:38 AM   #117
Malt
Drives: 2015 WRX
If they have it working on one stage, it will work on all stages.
Malt is offline   Reply With Quote
Old 07-11-2014, 01:33 PM   #118
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
@shiv@vishnu Where there any changes to the V1.60 release from the beta version?
Old 07-11-2014, 03:08 PM   #119
8686
8686's Avatar
Drives: 86
Is the 1.6 released? where can I find it?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 07-11-2014, 03:25 PM   #120
s2d4
s2d4's Avatar
Sure, this seems to be E85 tune related.
What would your suggestion be in getting the DI pressure to match the MAF scaling for idle?
Old 07-11-2014, 05:35 PM   #121
solidONE
solidONE's Avatar
http://openflashtablet.com/products/...ads/index.html
I think it's only for ESC and or OFH equipped cars tho.. not sure
Old 07-11-2014, 05:57 PM   #122
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
V2.0 beta maps aren't publicly released yet. They are being tested beta testers at this time. Should be released soon
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Mike86 (07-13-2014)
Old 07-11-2014, 06:36 PM   #123
Kodename47
Kodename47's Avatar
Drives: UK GT86
DI flow rate or DI Quantity Comp (I think) tables.
.: Stealth 86 :.
Kodename 47 DJ:
s2d4 (07-12-2014)
Old 07-12-2014, 12:10 AM   #124
troek
troek's Avatar
Drives: 2012 Toyota 86
I just set out a email to the beta tester mailing list
if you need beta testing for international roms, im your man for A type.
troek is offline   Reply With Quote
Old 07-12-2014, 02:22 AM   #125
s2d4
s2d4's Avatar
I'll have a look and play around.
Old 07-12-2014, 02:58 AM   #126
s2d4
s2d4's Avatar
@shiv@vishnu
@shiv@vishnu
Did you see this?
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-14-2014 12:14 AM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet: USDM Stage 2 EL/UEL testers needed Shiv@Openflash Software Tuning 13 01-05-2014 01:42 AM
