#15 | |
Drives: BRZ Pearl White
The moment changes even though the lever arm length remains the same (height of CG above the ground, ignoring anti dive and anti squat forces). Therefore, anything that makes the braking more effective will increase weight transfer. Stiffer front springs often improve braking forces because all four tires can contribute more, resulting in more weight transfer and less dive than for a softer front springs. The poster you replied to had the effect correct but the explanation backwards. Stiffer front springs tend to shorten braking distances, all other things being equal, but by doing so they increase weight transfer (actually inertia forces tending to compress the front springs by torque forces acting through the CG). Better tires also increase weight transfer, provided the road surface can deliver the grip the tires can exploit. Better tires on a snow covered road aren't going to work (unless they are snow tires of course). |
| The Following User Says Thank You to Ubersuber For This Useful Post: | Racecomp Engineering (07-11-2014) |
#16 | |
Drives: C-17A
Thank You |
#17 |
Drives: FR-S Whiteout
Alignment would be the first thing to check. I wouldn't be surprised if the rear toe was off due to the toe link adjusters (eccentric bolt assembly) slipping.
#18 | |
The front is McPherson strut so it's going to be pretty good slapped together at the factory. The rear is more sophisticated and, ironically, precise alignment at the rear has much more effect on handling than the front end does. This car handles so well that any mis-alignment is going to be very noticeable. |
| The Following User Says Thank You to Ubersuber For This Useful Post: | solidONE (07-11-2014) |
#19 |
What kind of brake setup do you have on your S2000?
Perhaps you're just not used to having lower grip tires? |
#20 |
Drives: Strangely.
The issue you're having is the inverse of the issue I'm having: I want the rear to slip under braking, but the front does instead.
Based on my experience with various setups on my Altima, spring stiffness profoundly impacts weight transfer. With the stock stuff, it oversteered all over the place under braking, and the stiffer suspension I installed, the less corner-entry oversteer I got, even though steady-state cornering balance didn't change much. The main (only, as far as I know) mechanical difference between FRS and BRZ is the springs. FRS front springs are roughly 2/3 as stiff as BRZ front springs, and FRS rear springs are roughly 10% stiffer. That translates to the FRS being a much softer, much more oversteering car. Having driven both, the BRZ feels much more planted (less roll), much less oversteery, and way less comfortable than FRS. I recommend you get BRZ front springs. And then give me your old ones haha. Along with, naturally, an alignment (might as well do front camber bolts and rear camber-adjust control arms too). If your car came off the same assembly line as mine, I can guarantee that your alignment is way off: One of my wheels had positive camber, another one had 2 degrees negative. |
#21 | |
Drives: 370z
#22 |
StreetKart
Drives: 2014 Scion FR-S Monogram
tl;dr
if the car is oversteering under braking you're trail braking. I've had to train myself to no to do this since my last car was a staggered wheel setup and i HAD to.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#23 |
Drives: C-17A
#24 | |
Pneumatic tires are unusual friction devices and empirically we know that, up to a point, higher tire load develops more grip. This is why heavy cars brake as effectively as light cars and corner as well also. Aerodynamic downforce exploits this characteristic by loading tires vertically but not adding any real weight. Weight transfer is really a momentum effect. Imagine a car without springs at all (infinite spring rate). Braking that car would not result in any dive at all but weight transfer would still occur. Weight transfer isn't really weight transfer, it is rotation around the CG in a vertical direction and perpendicular to vehicle motion, just as roll is rotation around the roll axis and in a longitudinal direction. The forces are independent of the springing but the body movement is dependent on the springing. Weight transfer is an acceleration force (torque) tending to rotate the mass around its CG. The extent to which it actually does rotate depends on the freedom of movement but that does not affect the size of the torque force. Braking forces create weight transfer, not the other way around. More braking force causes more weight transfer just as more cornering force creates more roll force. Brake force causes dive and roll forces cause roll. Without spring travel there is no movement but the force will be the same, so when the car goes over on the bump stops roll stops but weight transfer continues to rise as cornering speeds increase. Spring rates cannot increase maximum possible grip but they move the grip curve/tire loading. Stiffer roll cannot increase maximum grip but it will deliver higher grip more quickly AND importantly, make use of the inside tire grip for longer so that the car will turn in more readily and will reach maximum cornering speed more quickly. Stiffer front springs do the same for braking forces, allowing the rear tires to grip better for longer as they unload more slowly. Weight transfer will always be the same for any given brake or cornering g but the rate of weight transfer will be different with stiffer springs, reaching a maximum when all suspension travel is absorbed. Which is why hitting the bump stops can cause you a moment of a different kind. |
| The Following User Says Thank You to Ubersuber For This Useful Post: | dradernh (07-11-2014) |
#25 |
Drives: 2014 BRZ Ltd - DGM
So it looks like you're toe'd out in the back? That could be why. (unless I'm interpreting that incorrectly.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car E46 323ci vert |
#26 | |
Not the numbers...just in terms of how vague it is.Anyway, it's hard to tell but it looks like you have a little toe out front and rear. I can't tell how much because that sheet sucks. - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | solidONE (07-11-2014) |
#27 |
Drives: 2013 Scion FRS
So it looks like they passed the alignment. But what is unclear is the toe left to right. The numbers are within factory spec, but I would not like the toe out on one side. If you are going to be off a little, it's best to be off equally on both sides... Was this a dealer alignment or an alignment specialty shop?
FA500 Coils/Swift/Radial Upgd, Cusco R.LCA, SPC R.Toe Arms, TqSol. R.SubFrame Bushings, MTEC Shift Springs, Perrin Shift Bushing/Trans Mount, Greddy SP Exhaust & Intake, RPF1 18x9.5 +38, 255/35-18 SDrives, Raceseng Ashiko Knob/Lockout |
#28 | |
Drives: C-17A
| Braking Noise | hasfoot | Issues | Warranty | Recalls / TSB | 12 | 04-25-2015 12:02 AM |
| frs oversteer in brz mechanical? | swpbrz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 03-18-2014 09:48 PM |
| car pulls to right when braking hard.. | VoiD | Issues | Warranty | Recalls / TSB | 15 | 12-17-2013 05:26 PM |
| Stall in high G turn/oversteer spin | DR J | Engine, Exhaust, Transmission | 23 | 06-04-2013 01:54 PM |
| Wheel Hop When Braking Hard | Bonburner | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 01-14-2013 09:31 PM |
