Old 03-18-2014, 03:28 AM   #1
swpbrz
Drives: swp brz limited
frs oversteer in brz mechanical?
Is there a mechanical difference between the brz and frs that give the frs more oversteer? I feel like I'm noticing a falloff on the oversteer in my brz and was wondering if it was a new mod I would need or is that some kind of computer change to get the same feel in my brz.
swpbrz is offline   Reply With Quote
Old 03-18-2014, 03:35 AM   #2
DAEMANO
Time Traveller
Pretty simple,
FR-S is softer in the front and stiffer in the back making the tail come out easier, BRZ is more equally sprung lending it to very slight initial understeer.
SPRINGS Front/Rate Rear/Rate Part # MSRP
OEM Scion FR-S M/T 0.0"/2.3k 0.0"/3.8k F:SU003-04144 $83.90
OEM Subaru BRZ M/T 0.0"/2.7k 0.0"/3.5k F:20330CA010 $79.70
http://www.ft86club.com/forums/showthread.php?t=8739
The Following User Says Thank You to DAEMANO For This Useful Post:
CSG Mike (03-18-2014)
Old 03-18-2014, 08:00 AM   #3
steve99
heavier rear sway bar (or adjustable)may be easiest way to increase oversteer on brz
Old 03-18-2014, 08:01 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Like mentioned its the spring rates. I have RCE yellows and love them. Still allows the rear to step out when wanted but in a more neutral fashion if that makes sense.
Sent from my LT30at using Tapatalk
Old 03-18-2014, 08:29 PM   #5
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
FRS rear springs. Ran them in my BRZ up until last week, loved it.
Kostamojen is offline   Reply With Quote
Old 03-18-2014, 10:48 PM   #6
swpbrz
Thanks guys! exactly what I was wondering.
Raven down! Mechanical failure :( rasec29 Issues | Warranty | Recalls / TSB 151 10-08-2013 12:25 PM
Overall mechanical satisfaction? Tman08 Issues | Warranty | Recalls / TSB 15 08-26-2013 06:28 PM
More mechanical sound for AT manual mode? trinitron Scion FR-S / Toyota 86 GT86 General Forum 9 06-14-2013 09:52 PM
Stall in high G turn/oversteer spin DR J Engine, Exhaust, Transmission 23 06-04-2013 02:54 PM
Is your FR-S giving you any mechanical problems now? doctortt Issues | Warranty | Recalls / TSB 40 01-19-2013 02:06 AM
