Old 12-09-2013, 03:25 PM   #1
VoiD
Drives: 13 WRB BRZ
car pulls to right when braking hard..
Just put winter tires on.
On the higway today, had to brake hard because of an object on the highway but instead of braking in straight line, car would pull to the right side.
So I tried again later on a flat road and it still pulls to the right side when braking hard.
I dont remember having this problem when I had summer tires on.. even during autox..
I want to get this fixed asap since it scared the shit out of me the first time it happened.. anything else I should check other than air pressure?
VoiD is offline   Reply With Quote
Old 12-09-2013, 03:44 PM   #2
Air pressure first.
Then check pads to make sure they're wearing evenly.
Third is alignment...
Old 12-09-2013, 04:02 PM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
does the front of the car pull to the right, or the back of the car?
Old 12-09-2013, 05:02 PM   #4
VoiD
Drives: 13 WRB BRZ
the front..
Old 12-09-2013, 05:07 PM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
If pressures are OK, swap front tires left/right. If pull changes from left to right, you have a bad front tire.
Old 12-09-2013, 05:15 PM   #6
strat61caster
strat61caster's Avatar
While you're under there you should be able to see if your tires are wearing evenly, uneven wear would indicate an alignment problem.
ineedyourdiddly
Old 12-09-2013, 05:19 PM   #7
amilleri
Drives: 2010 Scion xD
Possible frozen caliper as well.
amilleri is offline   Reply With Quote
Old 12-09-2013, 05:29 PM   #8
humfrz
I'd suggest you take it into a brake shop ..... before that puppy pulls you off a slick road.
In addition to what was mentioned above, maybe bleeding the brakes would even it up.
Let's hope your car's ABS isn't all wonked out ....
humfrz
Old 12-09-2013, 06:46 PM   #9
Ozzman
Drives: old
My money is on a bad tire, It's more likely than you think.
Ozzman is offline   Reply With Quote
Old 12-09-2013, 07:33 PM   #10
VoiD
Drives: 13 WRB BRZ
Thanks. I checked the pressure on my way home.. all same 32psi.. was too dark and cold when I got home to check other stuff.. These are brand new and directional tires so I can not swap left and right.. snow tomorrow..
Old 12-09-2013, 08:56 PM   #11
humfrz
But you could swap the right side front to rear ....
humfrz
Old 12-09-2013, 09:17 PM   #12
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
I would take it to a shop and have it looked at.
I have seen where new tires were not made right and cause havoc .
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 12-10-2013, 09:03 AM   #13
andrew20195
Drives: 2013 Subaru BRZ
You can swap directional tires left to right for a short test drive. It won't hurt anything.
andrew20195 is offline   Reply With Quote
Old 12-10-2013, 09:08 AM   #14
microbionic
microbionic's Avatar
I had simular two weeks ago when I put my winters on (dunlop wintersports),.. I would actually pull left on acceleration and right on decel, generally at 70+ was it noticeable. I rotated the tires and it went away, .. i figure it a bad tire,.. .that I wont replace .. cause i rarely drive my car in the winter.
microbionic is offline   Reply With Quote
DFW- Free Dyno Pulls awdtuning Southwest 13 08-09-2013 05:26 PM
Wheel Hop When Braking Hard Bonburner Scion FR-S / Toyota 86 GT86 General Forum 27 01-14-2013 09:31 PM
Cummins pulls Chevy bestwheelbase Other Vehicles & General Automotive Discussions 25 12-29-2012 02:19 PM
looking for videos of dyno pulls 1strwdcar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 12-11-2012 07:30 PM
Toyota pulls out of Formula 1... what next? oldeskewltoy Scion FR-S / Toyota 86 GT86 General Forum 16 11-09-2009 02:03 AM
