#43 |
Drives: 2014 Firestorm FR-S 6MT
#44 | |
2013 Lightning Red - 6MT Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler |
#45 |
Drives: Black 2013 FRS
I've had this same clunk over bumps since I've installed my KW V3's as well. I've got the whiteline rear subframe mount insert kit too if that makes a difference. It's on the right side rear same as everyone else here.
#46 |
Drives: 23 GT4RS
I currently have whiteline inserts but I'll be switching to pbm risers, I'll let you know my results.
#47 |
Checking in after pulling out the right rear, making adjustments/checking all hardware, and re-installing. I managed to eliminate the clunk, although I couldn't pinpoint the problem. I made the following adjustments:
1) re-torqued the nut on top to 26 ft-lbs, making sure to use a strap wrench/vice grips and rubber hose to prevent the the coilover from spinning; 2) I adjusted the pre-load on the right rear to better match the left rear. I counted the threads at the bottom on the left rear and found that I was about 2 threads off from where the right rear was at; 3) I made sure to tighten the little lock on the purple collar on the bottom of the coilover to prevent my preload settings from moving; 4) finally, when reinstalling, I made sure everything was tightened down to the appropriate torque settings. One of these things, if not all of them, helped eliminated whatever was causing my clunk. |
#48 | |
#49 | |
Good luck! |
#50 |
Drives: 23 GT4RS
So I figured I'd bump this thread since I fixed my problem. Ended up getting replacement dampers from parts shop max and the clunk went away. Wound't be surprised if BC and Stance also get their dampers from the same supplier, would explain why so many people complain about them making noise. Either way, seems like sometime last year there must have been a bad batch, its seems like they fixed it now.
#51 |
AIM4APX
Drives: 2013 WRB BRZ Limited
FWIW I have a clunk from my fronts. This past weekend I replaced my suspension completely in essence. I replaced struts (B8's), tie rods and lower A arm bushing (whiteline roll kit), and end links (perrin). Everything was torqued, but I still have the same clunk. I did reuse the OEM pillow mounts.
Im going to take a look at the front again today and use another jack to compress the suspension in hopes that I can find something loose when its not under load.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#52 |
Drives: Scion FR-S 2013 Raven
I have an noise also, details into this topic at the end.
http://www.ft86club.com/forums/showthread.php?t=81293
o= FR-S =o |
#53 |
Drives: 2014 Monogram
Anyone else still having this issue? Just installed my airlift kit and the clunking is horrible. I stop my car and press on my trunk and make it bounce and hear the clunking.. I just checked all my nuts and bolts and torqued them to all the correct specs.
#54 | |
Do you have full metal pillow ball? I think some noise are normal with that... Mostly with the Twins...
o= FR-S =o |
#55 |
Drives: 2014 Scion Frs Whiteout
My psm coils clunk and i have yet to figure out a solution.... guess ill try readjusting them again.
#56 |
Drives: White scion frs
I installed coils and have the same clunk and it's only in the rear. Whenever I turn my wheels to one side the rear of the car raises and this is when the noise seems to happen. It happens on both sides. I am going to check the end links and sway bar next weeks as I checked the actual coilovers today.
| Clunk when going into first gear? | huma | BRZ First-Gen (2012+) — General Topics | 22 | 07-24-2014 05:49 PM |
| DG-5 Coilover | harajukukei | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 06-27-2014 03:42 PM |
| Parking brake clunk | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-28-2012 12:10 AM |
| Parking/Emergency Brake - "Clunk" | EsoBOFH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-24-2012 11:43 AM |
| Thud/Clunk when shifting. | erom | Engine, Exhaust, Transmission | 10 | 06-17-2012 07:08 PM |
