View Poll Results: If I were to repaint/vinyl wrap this car, what color should I go with??
Stay with Lightning Red! 42 45.16%
Silver 0 0%
Gunmetal 26 27.96%
Black 5 5.38%
White 6 6.45%
Other 14 15.05%
Voters: 93. You may not vote on this poll
CounterSpace Garage, Evasive Motorsports, robispec
Old 07-06-2014, 05:20 AM   #197
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
There's been talk of this new Excedy STG 2 clutch having no chatter and slightly heavier peddle feel over stock and suppositively very DD friendly. Is that accurate in your opinion??
Old 07-06-2014, 02:06 PM   #198
ImperiousRex
Track Junkie
ImperiousRex's Avatar
Drives: 2013 Subaru BRZ Limited, 2005 S2000
In general I would say yes. From a stop the clutch needs to be quickly eased into because of its tendency to grab but once the car is moving at all, it's very easy to use and on track it's very solid. The pedal feel is slightly heavier than stock but it's still pretty light compared to other clutch solutions.
I have one issue where sometimes it's difficult to get into 1st gear (at times it feels like the gate isn't fully open) but I also had this issue with the ACT clutch. Having said that though, my situation is a little different due to the engine/transmission mounts and LSD so my observations might be a little different than someone with a stock car.
ImperiousRex is offline   Reply With Quote
Old 07-06-2014, 04:23 PM   #199
OICU812
Just a dude
OICU812's Avatar
Ok and no chatter that you have observed as of yet?
Old 07-07-2014, 12:27 AM   #200
ImperiousRex
Track Junkie
No chatter so far
The Following User Says Thank You to ImperiousRex For This Useful Post:
OICU812 (07-07-2014)
Old 07-07-2014, 02:23 AM   #201
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I would recommend pushing your rad forward, it would help you a decent amount
Old 07-07-2014, 10:54 AM   #202
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
So what you see here is the power on the first run when everything was cool and on a DynoJet vs. power after 6 runs at high rpm's. The whp in cool conditions again corroborate the Evasive numbers but the 40whp loss after 6 runs was eye opening. On track we suspect the car is losing even more power after multiple sessions and the main culprit appears to be the intake ambient temperature (IAT). As you can see there's a direct correlation in this graph:
Now keep in mind this is probably something that daily driven cars will never really experience. This type of heat soak is from sustained high RPMs for extended periods of time. On track this will be up to 20-25mins of 5-7k RPMs during the entire session. (Although in hot summer months this can happen more naturally.)
I would say that the fact that you lost a PSI of boost on the second run was more of a contributing factor to the power loss than the IATs. The dyno with fans blowing still isn't going to simulate the IATs that are going to occur on a race track though. I would like to see an EcuTek datalog from an entire 20 minute session.
Old 07-07-2014, 12:02 PM   #203
ImperiousRex
Track Junkie
Thanks! Yeah that's something we're looking into when we put in the new radiator.
Yeah, the multiple runs weren't meant to accurately depict track conditions (and I already admitted as much), it was just meant to build up heat in the engine bay and see what was happening with the power. We probably lose another 10-20whp on track depending on ambient temps.
The point about boost is valid though. The boost chart didn't taper off at higher rpm's so I had ruled out a boost leak but perhaps something else is going on regarding heat expansion with the piping inside the engine bay. We also had another FI FT86 on the dyno that day and the power loss was similar at those IAT ranges. I'm pretty sure the ECU is pulling timing at that heat range but we'll be back on track at the end of the month and I'll try to get the datalog for you then.
Old 07-07-2014, 12:07 PM   #204
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Sounds good. An EcuTek datalog will tell you what timing the car is actually running. Are you just running off wastegate or are you using something for boost control? Normally a manual boost controller or a wastegate can be influenced by heat and produce different boost levels depending on temp.
Old 07-07-2014, 12:09 PM   #205
ImperiousRex
Track Junkie
No boost controller yet. It's just running off the wastegate.
Also after re-reading through my updates, I don't want to come off as demeaning the turbo kit in any way. The design comes with some inherent issues but overall the car has been pretty solid after many hard track days. I think it's a testament to Greddy's quality control and the issues are just giving us a clearer path to improve the car
Old 07-07-2014, 12:44 PM   #206
Cliu91
Cliuless
Cliu91's Avatar
Drives: Whiteout Scion FRS 2014
How loud is that Greddy exhaust? I've had my eyes on it for a while. Will it draw too much attention? I DD my FRS.
Cliu91 is offline   Reply With Quote
Old 07-07-2014, 12:54 PM   #207
ImperiousRex
Track Junkie
LOL you tell me
[ame="https://www.youtube.com/watch?v=qNLKubCqMhk"]Silent but Deadly turbo BRZ - YouTube[/ame]
But in all seriousness, I like the exhaust quite a bit. The 70mm diameter was a selling point but so were the silencers that it comes with (which are demonstrated in the video above). Certain tracks like Laguna Seca have a strict dB limit and I wanted to be sure that I had an option to quiet it down if I needed.
When I'm running a straight pipe and no silencers with the turbo kit however, the car gets loud inside the cabin. For some reason the noise doesn't travel very far from the car but it all seems to channel inward
Last edited by ImperiousRex; 07-07-2014 at 01:31 PM. Reason: Forgot to add the quote...
The Following 2 Users Say Thank You to ImperiousRex For This Useful Post:
akahenry (07-24-2014), Cliu91 (07-07-2014)
Old 07-07-2014, 03:21 PM   #208
CSG Mike
CSG Mike's Avatar
PSI =/= Power.
There is a very weak correlation at best.
Lets dig into why this is. As the IAT gets hotter, it has a larger differential from ambient. The psi coming out of the turbine is the same, but because the IAT is hotter, the air is cooled more (relatively speaking) by the intercooler, causing a large pressure drop.
While the PSI is lower, the mass of air flow into the engine has not changed from before/after the intercooler. The absolute mass is lower, since the turbo itself is not able to pack as much air into the same amount of volume.
Remember, PSI is a pressure measurement, not a flow measurement.
If you look at datalogs, the heat soaking happens within the first outlap.
ImperiousRex (07-12-2014)
Old 07-12-2014, 01:33 PM   #209
Fresh86
Fresh86's Avatar
Drives: 2013 Scion FRS
this build is so amazing
Fresh86 is offline   Reply With Quote
The Following User Says Thank You to Fresh86 For This Useful Post:
Old 07-19-2014, 11:28 AM   #210
Scracho
Drives: 2018 Subaru BRZ
Subscribed!
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
The Following User Says Thank You to Scracho For This Useful Post:
ImperiousRex (07-19-2014)
LIGHTNING RED BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 409 03-01-2025 12:28 PM
StockySnail's Lightning Red 6MT BRZ Limited Build Thread stockysnail Member's Car Journals 206 09-23-2024 12:40 PM
The lightning lap Gixxersixxerman FR-S / BRZ vs.... 35 09-17-2014 02:15 PM
Lightning Red Ft 86 Acid18 Member's Car Journals 6 12-28-2012 03:27 AM
SD: Lightning Red BRZ Limited 6MT tastefully modded epson1 Cars for Sale/Trade 2 09-24-2012 01:56 PM
