Old 06-29-2014, 11:57 PM   #1905
PolishFrs13
building life
PolishFrs13's Avatar
Drives: Raven Black, 6MT
Ordering my FBM base kit on the 7th along with the FBM single exit turbo back exhaust.. Still debating on if I should upgrade the turbo or not.
Sent from somewhere
PolishFrs13 is offline   Reply With Quote
Old 06-29-2014, 11:57 PM   #1906
Dipstik-sportech
Dipstik-sportech's Avatar
Which turbo do u plan to get? ^
Old 06-29-2014, 11:59 PM   #1907
PolishFrs13
building life
Either the GT2871 or GTX2867
Sent from somewhere
Old 06-30-2014, 12:12 AM   #1908
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I have the gtx2867 you can search my build thread. Do you have e85?
Old 06-30-2014, 12:13 AM   #1909
PolishFrs13
building life
I do, but it's a bit of a drive.. Probably will stick to 91
Sent from somewhere
Old 06-30-2014, 12:21 AM   #1910
Dipstik-sportech
Go with the gtx if u can afford it. The GT is a terrific turbo, I know I had one. But from what I'm reading the gtx is just that bit better at higher numbers. I will say get the aluminium oil pan if nothing else it makes running the turbo drain way easier and it's just cool looking lol
Old 06-30-2014, 12:23 AM   #1911
PolishFrs13
building life
Hmm, I do want around 350 or so.. might get the gtx. yes im getting the base kit
Sent from somewhere
Old 06-30-2014, 10:10 AM   #1912
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by blackfireball5 View Post
Everything I've read said that doing it that way is the right way to do it?
You have it hooked up correctly if your car wasn't boosted. Let me clarify some things:
1. PCV stands for Positive Crankcase Ventillation. It is possible for the crankcase to build up pressure especially if you are getting blowby past your piston rings. The port on the back of the passenger side of the block allows any pressure to be sucked out and into the intake manifold in normal operation.
2. Our car DOES NOT have a PCV VALVE. There is no check valve or any other type of valve anywhere on the car. The result is that if you leave the PCV line connected to the intake manifold, you will be pressurizing the crank case with boost pressure.
3. This can be fixed by either running a VTA (Vent To Atmosphere) catch can, or by adding a one way check valve that will let the crankcase vent to the intake manifold but not let any pressure go back into the crankcase when you pressurize the intake manifold with boost.
Old 06-30-2014, 10:14 AM   #1913
King Tut
NASA SpecE30 Racer
King Tut's Avatar
@Reaper would a proper setup be a dual catch can setup like the radium cans and a check valve located between the pcv can and the intake manifold? With the breather can connected before the turbo intake?
My advice if you want to keep the Custo catch can is to tee into the line going from the PCV to the catch can and run a tube from your breather line (one with plastic bottle attached) to that tee. This will turn your catch can into a dual catch can, then put a one way check valve in the hose from the back of the intake manifold to the catch can.
Old 06-30-2014, 10:16 AM   #1914
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That will be very difficult on a stock motor with 91 octane and a GT28 size turbo.
Old 06-30-2014, 10:41 AM   #1915
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Thank you for your responses. Everyone has been a lot of help this weekend.
I plan on getting rid of the cusco can and going with the dual radium setup since my cusco can seems to be pretty useless.
I was planning on getting a silicone T house coupler just after the air filter and bring the breather line in to there after it passes from the breather to the can.
Also, putting a check valve between the pcv can and intake manifold.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 06-30-2014, 10:43 AM   #1916
blackfireball5
Also, does anyone know the diameter of the pipe that the air filter connects to?
Wheelwell Profile
Old 06-30-2014, 05:14 PM   #1917
PolishFrs13
building life
Any advice on how to up the power for it than ? it would be much appreciated!
Old 06-30-2014, 06:20 PM   #1918
mike the snake
I have the same goals as you on 91.
As I saw it, I could either go with a built, lower compression shortblock, or go with methanol injection. I went with the WMI.
I should be able to hit my 350whp goal with gtx2867 FB turbo kit, 3" Nameless catless front/overpipe, Tomei titanium 80R exhaust, tuned with Hydra standalone and Hydramist WMI.
I'm right around 300 now with 10lbs boost. I'll be running more boost soon.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
