#6427 |
That headunit though...
Drives: 2013 Subaru BRZ Limited SSM
I have a different kind of victim story. Found out what was wrong with my dump pack.
One of the terminals looked pretty fried when I removed the top cover. Emailed Rob, he said it looked like a wrench or something has touched the terminal. The only thing I had done since installation was an oil change. Called the oil change, asked for the employee that changed my oil. Sure enough, he had removed the battery tie down to get a peek at how the ESC was wired. When he went to replace the tie down, he nicked the terminal with the dangling metal pin, sparking and fusing the bolt and nut. He then tried starting the car, noticed the gauge and the car both were working, and apparently decided not to tell me. the ESC functioned fairly well on the battered terminal, but i imagine that heat and such finally overwhelmed the battery and it gave up the ghost. this probably explains my concern about the boost being a little low too. His company will be covering the cost of any replacement parts or batteries. Still cant believe it. Sent from my iPhone using Tapatalk
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300 Eibach Pro-Kit + Michelin PSS (stock size) |
| The Following 5 Users Say Thank You to enwave For This Useful Post: | Boofneenee (06-29-2014), DAEMANO (06-29-2014), Luckrider (06-28-2014), s2d4 (06-29-2014), unijabnx2000 (06-29-2014) |
#6428 |
Drives: 2013 Scion FRS
I'm amazed he was honest with you after the fact. Good think they're making it right!
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
| The Following 5 Users Say Thank You to nlowell For This Useful Post: | DAEMANO (06-29-2014), enwave (06-28-2014), Luckrider (06-28-2014), MagicBobert (06-29-2014), raven1231 (06-28-2014) |
#6429 |
We have pretty solid community around here. It's pretty religious, being Utah and all (not that religion guarantees morals, don't wanna start that debate). I imagine it had been eating through his conscience a little. I'm more surprised he didn't tell me the first time than I am that he admitted to it when I called.
#6430 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
#6431 |
I'm usually the same way with everything but my oil. I am good friends with the previous owner of the shop, which is why I was going there. It might be time to switch now though.
#6432 | |
Drives: 2014 WRB BRZ Limited
Shops you can trust to tell you the truth when they stand nothing to gain? Those are a diamond in the rough. |
| The Following 3 Users Say Thank You to MagicBobert For This Useful Post: |
#6433 |
Stay bro, honesty is hard to find these days.
#6434 |
So, As I was driving home from work yesterday I decided to get on it a little. As i went full throttle the voltage stayed the at 28.7 and the compressor was not engaging. I was worried something with my controller was wrong again. Once I got home I looked over the system and realized the cause. I found my throttle switch sitting on the floor. It turns out it at some point got worked loose and fell off. After bolting it back on and a little adjusting all is well
![]() As for my post about the 1.5 tune. That was meant to be sarcastic as I thought it was supposed to be finished quite some time ago. I was just giving Shiv a hard time. I do realize how busy he is and that he has other priorities at the moment lol....I'm just impatient and can't wait for him to work his magic
#6435 |
Yep, agreed on all points about the honesty being valuable, it's just a matter of whether I switch back to doing oil changes myself. We'll see how I feel in 3-5k miles.
#6436 | |
Time Traveller
Coils: RS-R Sports-i Moto Spec - Thx @Moto-P for the sage advice Wheels: WedsSport SA10-R 18x8.5 et 45 (new for 2014!) - Thx @MicheleAbbate for the help with the specs. Tires: Dunlop Direzza DZ102 (also new for 2014!) Had @F-T remove some frozen lugs, studs, and add header. I think I'm roughly -1.2" F/ -1.2"R. Need to measure the drop. I think I should go down about another 1/4" F & R. The header was an OEM header that I made "special" with the info from @NickFRS. My butt dyno confirms his findings which is the stock header is a fine ELH after the upgrade. The Phantom ESC + beefed up suspension and stickier tires feel very well matched. Thanks again for the powah @Robftss . Needs a tad more low and the front splitter is being fabbed but took a few not so glamorous shots anyhow. ![]() ![]()
#6437 | |
#6438 |
Time Traveller
| The Following User Says Thank You to DAEMANO For This Useful Post: | raven1231 (06-30-2014) |
#6439 | |
| The Following User Says Thank You to raven1231 For This Useful Post: | DAEMANO (06-30-2014) |
#6440 | |
Drives: 2013 Subaru BRZ Premium
The black wire on the harness had pulled away from the 5 pin connector. |
| The Following User Says Thank You to Winjr For This Useful Post: | raven1231 (06-30-2014) |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
