Old 06-28-2014, 08:58 PM   #6427
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
I have a different kind of victim story. Found out what was wrong with my dump pack.
One of the terminals looked pretty fried when I removed the top cover. Emailed Rob, he said it looked like a wrench or something has touched the terminal. The only thing I had done since installation was an oil change.
Called the oil change, asked for the employee that changed my oil. Sure enough, he had removed the battery tie down to get a peek at how the ESC was wired. When he went to replace the tie down, he nicked the terminal with the dangling metal pin, sparking and fusing the bolt and nut. He then tried starting the car, noticed the gauge and the car both were working, and apparently decided not to tell me. the ESC functioned fairly well on the battered terminal, but i imagine that heat and such finally overwhelmed the battery and it gave up the ghost. this probably explains my concern about the boost being a little low too.
His company will be covering the cost of any replacement parts or batteries.
Still cant believe it.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 06-28-2014, 09:04 PM   #6428
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
I'm amazed he was honest with you after the fact. Good think they're making it right!
nlowell is offline   Reply With Quote
Old 06-28-2014, 09:30 PM   #6429
enwave
enwave's Avatar
We have pretty solid community around here. It's pretty religious, being Utah and all (not that religion guarantees morals, don't wanna start that debate). I imagine it had been eating through his conscience a little. I'm more surprised he didn't tell me the first time than I am that he admitted to it when I called.
Old 06-28-2014, 10:08 PM   #6430
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Be glad you were able to get the guy who did the change. I wouldn't trust my car to one of those shops for anything around here. I have a hard time handing over the keys to get the tires balanced/rotated, but I can't do that myself and I get to watch it from start to finish.
Luckrider is offline   Reply With Quote
Old 06-28-2014, 10:35 PM   #6431
enwave
enwave's Avatar
I'm usually the same way with everything but my oil. I am good friends with the previous owner of the shop, which is why I was going there. It might be time to switch now though.
Old 06-29-2014, 01:38 AM   #6432
MagicBobert
MagicBobert's Avatar
Drives: 2014 WRB BRZ Limited
On the contrary I would keep going there. Screw ups happen and it sounds like the shop is making it right.
Shops you can trust to tell you the truth when they stand nothing to gain? Those are a diamond in the rough.
MagicBobert is offline   Reply With Quote
Old 06-29-2014, 02:17 AM   #6433
s2d4
s2d4's Avatar
Stay bro, honesty is hard to find these days.
Old 06-29-2014, 10:15 AM   #6434
raven1231
So, As I was driving home from work yesterday I decided to get on it a little. As i went full throttle the voltage stayed the at 28.7 and the compressor was not engaging. I was worried something with my controller was wrong again. Once I got home I looked over the system and realized the cause. I found my throttle switch sitting on the floor. It turns out it at some point got worked loose and fell off. After bolting it back on and a little adjusting all is well
As for my post about the 1.5 tune. That was meant to be sarcastic as I thought it was supposed to be finished quite some time ago. I was just giving Shiv a hard time. I do realize how busy he is and that he has other priorities at the moment lol....I'm just impatient and can't wait for him to work his magic
Old 06-29-2014, 10:48 AM   #6435
enwave
enwave's Avatar
Yep, agreed on all points about the honesty being valuable, it's just a matter of whether I switch back to doing oil changes myself. We'll see how I feel in 3-5k miles.
Old 06-29-2014, 08:56 PM   #6436
DAEMANO
Time Traveller
Originally Posted by Sojhinn View Post
Maybe. Ride is fantastic. Can't wait to see your coilover setup.
Ok so finally coils, wheels, and tires are on.
Coils: RS-R Sports-i Moto Spec - Thx @Moto-P for the sage advice
Wheels: WedsSport SA10-R 18x8.5 et 45 (new for 2014!) - Thx @MicheleAbbate for the help with the specs.
Tires: Dunlop Direzza DZ102 (also new for 2014!)
Had @F-T remove some frozen lugs, studs, and add header. I think I'm roughly -1.2" F/ -1.2"R. Need to measure the drop. I think I should go down about another 1/4" F & R. The header was an OEM header that I made "special" with the info from @NickFRS. My butt dyno confirms his findings which is the stock header is a fine ELH after the upgrade. The Phantom ESC + beefed up suspension and stickier tires feel very well matched. Thanks again for the powah @Robftss .
Needs a tad more low and the front splitter is being fabbed but took a few not so glamorous shots anyhow.
Old 06-29-2014, 09:31 PM   #6437
raven1231
What's the upgrade? Smashing out the cat ?
Old 06-29-2014, 11:45 PM   #6438
DAEMANO
Time Traveller
http://www.ft86club.com/forums/showp...58&postcount=1
Old 06-30-2014, 04:48 AM   #6439
raven1231
May have to do this myself
Old 06-30-2014, 11:03 AM   #6440
Winjr
Drives: 2013 Subaru BRZ Premium
Exact same thing happened to me yesterday, different problem, just as easily fixed.
The black wire on the harness had pulled away from the 5 pin connector.
Winjr is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
