Old 06-24-2014, 04:55 PM   #1639
SPCorBUST
SPCorBUST's Avatar
Originally Posted by Freeman View Post
Nice, what transmission?
I'm running the stock transmission. If you meant clutch, I'm running a stock clutch as well. Normal shifting at WOT holds fine, but if you use the Ecutek feature for holding revs it slips, so I tend not to use the map with that feature on it so much.
Sent from my SGH-M919 using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 06-24-2014, 05:19 PM   #1640
lucid215
Originally Posted by ST-A View Post
its up and running!
Now needs mapping, we are going to use the OFT so we will develop an OFT-KW map, hope all works out
that will be awesome since i will be running oft in the next month. good luck with it
lucid215 is offline   Reply With Quote
Old 06-24-2014, 05:22 PM   #1641
zERoTu
Drives: 1st RBv2 10 Series FRS
Making me jelous with all ur dyno numbers. I have no clue as of why mine are so low
zERoTu is offline   Reply With Quote
Old 06-24-2014, 05:32 PM   #1642
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Did you contact KraftWerks? If you did what did they say?
zoth is offline   Reply With Quote
Old 06-24-2014, 05:37 PM   #1643
zERoTu
I have, they actually contacted me. Told me to give them some info on the car, and I also gave them some ecu logs. Hopefully they can figure it out soon. Cause driving this car isn't much fun now . It a really rough ride.
Old 06-24-2014, 05:49 PM   #1644
SPCorBUST
SPCorBUST's Avatar
Sorry to hear that man. All boost leak sources accounted for and zip tied or clamped?
Old 06-24-2014, 05:57 PM   #1645
noob001
Drives: frs
@zERoTu I am also on the kraftwerks tune, dyno today at 210HP.
did you guys change out the spark plugs to one step colder?
anyone else on stock exhaust setup?
my car sometime buckles and the shop recommended replacing the exhaust system and to switch to one step colder plugs.
noob001 is offline   Reply With Quote
Old 06-24-2014, 06:00 PM   #1646
zERoTu
Kraftwerks Supercharger Owners Thread
@SPCorBUST Everything clamped down under the intake manifold. Was a pain. But it's done.
@noob001 I'm stock everything. I'm picking up exhaust tonight.
Old 06-24-2014, 06:28 PM   #1647
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Who's jumped to a step cooler plugs? And where did you get them from?
Freeman is offline   Reply With Quote
Old 06-24-2014, 06:32 PM   #1648
zoth
zoth's Avatar
its up and running!
Sounds like you have the smooth pulley's?
Old 06-24-2014, 07:07 PM   #1649
SPCorBUST
SPCorBUST's Avatar
Still don't know why everyone had a hard time with those. Just loop a zip tie around a line, push it to the back and tighten it down. You can use the hole between headers to pull the loop tight. I'm at 15psi I never had a blowout, makes no sense to go through all this trouble for the same outcome.
Old 06-24-2014, 08:18 PM   #1650
Calum
That Guy
Drives: 2013 asphalt FRS MT
My ring finger is a size 14.5... My hands barely fit in the engine bay, let alone between the runner of the intake manifold.
Old 06-24-2014, 08:50 PM   #1651
zoth
zoth's Avatar
I would if we could actually do it without lifting the engine.
I might give this badboy a try... or 50 bucks down the drain.
http://www.powerhouseproducts.com/ph...ocket-5-8html/
Old 06-24-2014, 08:52 PM   #1652
Freeman
Freeman's Avatar
Might get that for down the road. I was looking for a step colder plugs and couldnt find any, neither could my parts guy.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
