Old 06-24-2014, 11:03 AM   #85
qoncept
qoncept's Avatar
Originally Posted by texasbound972 View Post
Might be a stupid question or I missed it somewhere but, do I need to put spacers on with these apr studs? I don't want to put them in just for them to be too long and not tight. Thanks!
No, but you'll probably need open ended lugs.
qoncept is offline   Reply With Quote
Old 06-24-2014, 11:29 AM   #86
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Noooooo!!!!
texasbound972 is offline   Reply With Quote
Old 06-24-2014, 09:35 PM   #87
Frs123
Frs123's Avatar
Drives: Raven
What would be a reasonably size adapter(5x100->5x114.3) to use on the arp stud. I don't want the studs to hit the back of the wheel.
Instagram: erik239
Frs123 is offline   Reply With Quote
Old 06-25-2014, 09:40 PM   #88
texasbound972
USMC
That's it. Open ended lugs.
Old 07-05-2014, 09:28 PM   #89
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Don't use Ichiba studs, as others in this thread have posted.
My story posted here:
http://www.ft86club.com/forums/showp...5&postcount=38
Build Thread: Breaking-Bad SWP Build
OFFICIAL NM.FT86CLUB Facebook Page
mwjcyber is offline   Reply With Quote
Old 07-28-2014, 10:15 PM   #90
ZionsWrath
Thanks
ZionsWrath's Avatar
What size washer to place between open end lug nut and hub to push stud in?
Old 07-28-2014, 11:24 PM   #91
texasbound972
USMC
The Following User Says Thank You to texasbound972 For This Useful Post:
DAEMANO (10-11-2014)
Old 07-28-2014, 11:25 PM   #92
texasbound972
USMC
APR studs with Muteki neo chrome lugs
636 (02-09-2015)
Old 07-29-2014, 05:28 AM   #93
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Any size will do really, as long as the ID for the washer is bigger than the stud diameter. You'll need a few washers to space the lug nut out otherwise you'll bottom out on your socket as you tighten it. Do you have a cordless impact wrench? They're awesome for this job. Only needs a few zaps to pull and secure each stud.
Fizz is offline   Reply With Quote
Old 09-09-2014, 01:20 PM   #94
Dezoris
Dezoris's Avatar
This pile is only 2 years old, only saw one winter 23k miles. Cant get hub apart here. (Rear) Going to have to order new ones. Everything that should be simple isnt.
Old 09-12-2014, 06:08 PM   #95
chris86
Drives: 2013 Dark Gray BRZ
Originally Posted by Fizz View Post
So I removed the rear hubs to install my Nismo studs....and after all that hard work I realised that the new stud will easily fit without removing the hubs. Doh!!!
So guys, if you're installing these Nismo 50mm studs on the rear, all you need to do is remove rotors and hammer out the old stud. Also used an impact wrench with washers to fit the new studs make installation a breeze. Few zaps and new studs are secured!
How are these studs treating you?
I want stronger studs without being super long.
I bought ARP studs and was gonna just suck it up with how long they were and brought them with new lugs to a shop and they said they couldn't install them bc they are too long in the rear.
Now I'm reading this thread in greater detail, I think I'd like the nismo ones bc I don't have spacers and don't think ill need them. Are these working out for you?
chris86 is offline   Reply With Quote
Old 09-12-2014, 06:36 PM   #96
qoncept
qoncept's Avatar
Too long for what? Do you not have open end lugs?
FWIW the extra length with the ARP studs is incredibly annoying when you don't have a cordless impact, very convenient when you do.
Old 09-12-2014, 07:48 PM   #97
chris86
They said the ARP studs don't fit in the back. I've never done anything like this before so I didn't really know what to tell them other than ppl have done it. But they were convinced the studs wouldn't be able to fit to get them installed.
I didn't go to the dealer (yet at least) bc I figured it would be cheaper.
Old 09-12-2014, 08:00 PM   #98
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
I use the Nismo ones, and they're perfect. Just slightly longer than stock, didn't have to remove the hub.
I dont have spacers either.
boooooooooooooooooost
Ammonia is offline   Reply With Quote
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 05:30 AM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 03:42 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 11:26 PM
Scion FRS center wheel caps replacement? Silverback Cosmetic Modification (Interior/Exterior/Lighting) 10 09-03-2012 03:16 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
