Old 06-23-2014, 02:42 PM   #1
Chimera
Drives: FRS
Painting Emblems
So I painted my Emblems about 6 months ago, noticed yesterday one has had some paint chip away, right in the corner.
I painted them with krylon spray paint, 2 coats of primer, 3 gloss black, 4 clear coat.
I could patch this spot with some model paint, but I was wondering if anyone else who does this does anything to prep the emblems, like sanding?
Old 06-23-2014, 06:59 PM   #2
illest86
Just my opinion - You'll never get a home job that lasts through weather and time.
Prepping will help.
illest86 is offline   Reply With Quote
Old 06-23-2014, 07:15 PM   #3
kALMIGHTY
Drives: TRD Ultramarine '13
Is that another paint chip on the trunk above the emblem?
Old 06-24-2014, 12:18 AM   #4
Chimera
Drives: FRS
I think its a speck, it just looks like a chip or cut in the photo. I live in GA, there's a lot of trees and so forth here.
disheartening. I was hoping some other folks who have done this, or do this regularly might be able to comment. Maybe there are better brands? Honestly Krylon is what they sell at walmart so I can only assume there are better more lasting options?
Prepping will help.
Old 06-24-2014, 12:41 AM   #5
Luke
Luke's Avatar
Drives: 2014 Whiteout FRS
What kind of prep work did you initially do?
I would recommend removing all the paint you applied via soaking it in a small dish filled with purple power, castrol super clean, etc. It will take several hours for it to start loosening, but you can use brush to help it along.
Once you have the paint off, sand it a bit wih 240 to provide some teeth. Wash it with the PP, CSS,etc to remove any contaminents. Thoroughly rinse and dry.
Prime it and once dry, sand with a higher grit to smooth, reprime, and repeat until you have a smooth surface. Once your final layer of primer is cured, apply two coats of paint and follow with two coats of clear. Better quality paint will yield better results. I've had good luck with duplicolor.
Luke is offline   Reply With Quote
Old 06-24-2014, 01:01 AM   #6
Chimera
Drives: FRS
Thanks, welcome to the forums
Old 06-24-2014, 01:49 AM   #7
kALMIGHTY
I plastidipped mine last year and not a single problem so far. It's still holding up perfectly. Maybe go that route? Unless you prefer the glossy look.
Old 06-24-2014, 02:11 AM   #8
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Like the post said above, plastidip is a much easier alternative than using spray paint and having to prep, prime, coat, clear and let dry. Not to mention you can get two cans of plastidip, a can of black and a can of clear for a glossy finish.
Old 06-24-2014, 10:37 AM   #9
Chimera
Drives: FRS
Interesting, I hadn't considered using plastidip under regular spray paint.
I was partuicularly attached to the red lettering, as I liked how well it fit the red black color scheme.
I found a chrome black wheel paint at autozone the other day, maybe Ill try that?
Old 06-25-2014, 06:44 AM   #10
kodyo
Drives: Scion FR-S
I used krylon on my original emblems and couldn't get it to not chip in the front. Paint stuck well, but that location takes a beating. Switched to Toyota emblems after that.
kodyo is offline   Reply With Quote
Old 06-25-2014, 07:02 AM   #11
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Everyone is saying they used "Krylon". There are many different types of Krylon paints. I used Krylon for plastics on my +50 rc boat and it is still on there. Yes it does make a difference.
Old 06-25-2014, 12:10 PM   #12
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Plastidip for badges. They're so exposed it's not worth the hassle of constant repainting.
MokSpeed is offline   Reply With Quote
Old 06-25-2014, 06:17 PM   #13
kodyo
Drives: Scion FR-S
You are correct. For the record, I used Krylon Fusion in Satin Black.
It could not hold up to the abuse the front of the car sees. Used the same stuff on my '86 piston' emblems on the side and it has held up great for 18k miles.
Old 06-25-2014, 06:43 PM   #14
boredom.is.me
Custom User Title
^^^ perfect info
Couldn't remember what the plastic paint was named as. It is indeed Fusion.
Painting Stock Emblems ipothas DIY (Do-It-Yourself) Guides 21 10-09-2014 06:59 PM
Painting the J2 OURO3OROS Engine, Exhaust, Transmission 5 03-02-2014 05:10 AM
Autobody Shop/Painting Near Me ? Issue with Painting Carbon Fiber Hood? ScionFR-S Cosmetic Modification (Interior/Exterior/Lighting) 20 11-08-2013 01:51 PM
Painting calipers GTA wbradley CANADA 50 05-08-2013 02:42 AM
Painting the Emblems bigbroimc Cosmetic Modification (Interior/Exterior/Lighting) 11 08-31-2012 10:00 PM
