Old 10-09-2012, 08:35 PM   #1
ipothas
ipothas's Avatar
Drives: Whiteout FR-S
Painting Stock Emblems
I've been dying to start modifications on this car, but I decided to stick with a few simple and cheap cosmetic changes first.
I would love to have Toyota badges, but seeing as a set of two costs around $60, I decided to paint my stockies
To remove your emblems, follow this DIY.
http://www.ft86club.com/forums/showthread.php?t=7296
Anyways, here it goes.
Materials Needed
Scion Emblem (in this example, I'm doing the rear emblem.)
Acrylic paint (I went with plain white to redo the black lettering.)
Painter's tape
3M Double Sided automotive tape
All Surface primer
Your choice of plastic bonding paint. I went with a glossy black finish.
Clear coat. Trust me, don't pass up on this. Will protect your paint job and give your handy work that "professional" look.
Everything in the list can be purchased at any Wal-Mart or Auto parts store.
1. After removing the emblems, I used a small brush to paint the black SCION lettering white. In this step you don't have to be too careful to stay within the lines since you will be masking the lettering and spraying the rest of the emblem.
Basically, I coated the brush about halfway with paint. Wiped off the excess, and began blotting the paint on. The first coat works best if you "dot" the color on rather than "brush" it.
2. After your first "blot" coat dries, apply a second coat. This time, you can fill in all the little black bits showing through and make the paint job much smoother. After 2 coats I was satisfied with my results, but you may want to do more. Mine looks pretty good here, so I moved onto the next step.
3. After the lettering dries, it's time to mask them off. I took painters tape and laid it over the lettering. I then to a razor blade and cut out the depressions of the lettering. Be sure to cover the ENTIRE letter, and leave enough room to cover the edging.
This step is the most important if you are looking for quality white letters. You have to be meticulous in the position of the tape, and think about where the white color will end, and the black will begin. IDK if someone has a better way of doing this...if so, let me know
4. Once the emblem is masked, you can apply the primer. I went with 3 coats just to be safe.
5. After the primer dries, apply your gloss. 2 coats should be fine.
After your gloss dries, CAREFULLY remove the tape. Make sure the paint is ABSOLUTELY dry. I used a small knife to pry up the corners of the tape, then peeled it off slowly with my fingers. At this point you want to go back and touch up any of the white lettering you aren't satisfied with.
6. Apply your clear coat. 1-2 coats depending on preference.
I know this pic looks rough. This is before I went back and touched up a few spots.
7. Re-attach your emblems using the 3m double sided tape. Easy to do considering the rear emblem has 2 holes to position the badge correctly.
Sorry about the light, I was too anxious to put the badge back on to wait until tomorrow morning. May be silly, but I personally enjoy the way it looks. Particularly on the Whiteout
Enjoy! If you decide to use this DIY post some pics up of your results
ipothas is offline   Reply With Quote
Old 10-09-2012, 10:55 PM   #2
Mrqb22
Drives: 2013 FR-S Whiteout
Looks good man some guys on have serious skills. I wouldnt try 99 percent of this stuff on my own
2013 Whiteout
2013 XB black pearl.
Mrqb22 is offline   Reply With Quote
Old 10-10-2012, 02:12 AM   #3
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Nice job! Looks good on the car, although I REALLY like that 2nd pic of the grey emblem and white lettering.
You could also paint all the black, then let it dry and stick a piece of tape over the lettering and use the razor to cut out the "SCION" and then brush/spray your white on. I would think this might be easier than trying to stuff tape into the depressions.
I've also heard of using Vaseline to cover parts you don't want painted (with a Q-tip or something), then just rub it off (after paint dries, duh). It would work well in this type of application.
Bigger photos would be great, especially of the finished product.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 10-10-2012, 02:20 AM   #4
ipothas
ipothas's Avatar
Thanks for the feedback. I might try repainting them with the method you described, it definitely sounds like the way to go.
I was tempted to stick with the white on silver after I saw it. I'll post up links to bigger photos tomorrow, I kept them small to keep the thread looking clean haha.
2013 Whiteout 6MT
Old 10-10-2012, 11:24 AM   #5
PrinzJ
Drives: White Fr-S and Black 9thgen Corolla
That looks great
PrinzJ is offline   Reply With Quote
Old 10-12-2012, 02:42 PM   #6
ipothas
ipothas's Avatar
Thanks!
Sent from my ADR6410LVW using Tapatalk 2
2013 Whiteout 6MT
Old 10-12-2012, 02:45 PM   #7
phenom86
phenom86's Avatar
Drives: Scion FRS Asphalt
How come you didnt just paint it black then filled the lettering white? I think it would have been easier..
phenom86 is offline   Reply With Quote
Old 10-17-2012, 03:19 PM   #8
ipothas
ipothas's Avatar
It probably would have been. I wasn't sure how to approach it, and I figured I could make the lettering look a bit "cleaner" by doing it first
2013 Whiteout 6MT
Old 10-30-2012, 08:27 PM   #9
Xerail
Xerail's Avatar
Drives: Ultramarine FR-S
Does anyone know where i can find a DIY on making the words scion light up on the trunk instead of the badge being there. I know it probably has some fabrication involved but I'm just making a list of the thing's i want to do before i get started. I've seen the lighted up scion word once.
Xerail is offline   Reply With Quote
Old 10-31-2012, 09:26 AM   #10
DadHawk Approved!
Looks great. I fell in love with this particular combo in Long Beach. They had it on the "Speed Racer FR-S Convertible" thingy there.
I want to do this exactly and have been trying to figure out the best way to do it. Problem solved. I may do my letters in Firestorm (paint match) though, haven't decided.
Old 10-31-2012, 03:02 PM   #11
ipothas
ipothas's Avatar
DadHawk Approved!
thanks! Matching Firestorm lettering would look great. I wish I could make the white lettering look a bit better, I painted them flat black now :/
2013 Whiteout 6MT
Old 10-31-2012, 11:10 PM   #12
In the photos the look great, I'm guessing they did look good from the 10 ft view.
Old 11-01-2012, 01:31 PM   #13
ipothas
ipothas's Avatar
If I was more patient and had better tools at my disposal I probably could have made the white lettering work, but it had this rough look to it, like the paint was uneven. Drove me crazy. Now I'm wondering if I should go flat black emblems rather than gloss :P
2013 Whiteout 6MT
Old 11-01-2012, 01:32 PM   #14
ipothas
ipothas's Avatar
Nope...sorry.
2013 Whiteout 6MT
Painting calipers GTA wbradley CANADA 50 05-08-2013 02:42 AM
WTB: Stock Scion front & rear emblems JoeBoxer Exterior Parts (Aero, Lighting, Etc.) 9 10-01-2012 10:52 PM
Helmet painting? Mitch Tracking / Autocross / HPDE / Drifting 1 09-02-2012 03:44 PM
Painting the Emblems bigbroimc Cosmetic Modification (Interior/Exterior/Lighting) 11 08-31-2012 10:00 PM
Who has toyota emblems****in stock right meow!**** NeedsmoreCowbell Scion FR-S / Toyota 86 GT86 General Forum 0 07-16-2012 06:45 PM
