Old 06-22-2014, 03:00 PM   #1
STS-V
Car wont stay running for more than a second - P0102 & P0198
Hi all,
Trying to get my car running. Everything is in, when I turn it over it fires for a split second then dies. I am getting P0102 (Mass or Air Flow Circuit, low input) and P0198 (Engine oil temperature sensor high).
I bought a new mass air flow sensor, and am going through the wiring now. Any other suggestions?
STS-V is offline   Reply With Quote
Old 06-22-2014, 03:25 PM   #2
jflogerzi
jflogerzi's Avatar
What mods are done to the car? is your MAF sensor plugged in?
Old 06-22-2014, 03:29 PM   #3
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by STS-V View Post
Hi all,
This might sound stupid but I have done it:
Did you hook the intake back up from the MAF to the throttle body?
Old 06-22-2014, 05:03 PM   #4
White64Goat
Still under warranty? If yes, dealer let repair it.
Old 06-22-2014, 05:46 PM   #5
stugray
Ok, here is the $10k question:
WHY did you need to replace the MAF????
(my bet is this will be good....)
Old 06-22-2014, 05:48 PM   #6
gramicci101
Off Topic
STS-V bought a totaled FR-S and is repairing/rebuilding it. It wouldn't surprise me if the MAF sensor was damaged in the accident.
Old 06-22-2014, 06:13 PM   #7
steve99
Drives: FT86
Hi all,
Consentrate on the maf sensor and wiring or connectors. Engine wont run without maf sensor.
Another guy on here had exact same symptoms after mouse ate through his air filter and some crap got lodged in maf sensor and car would just fire then stall
Old 06-22-2014, 07:30 PM   #8
STS-V
Maf Sensor is plugged in... I even ran new wires from the harness. Still nothing.
All of it is in, except the sound tube. Then again, it ran after wrecked with half the intake missing.
Nope. Not by a long shot.
The original map sensor was cracked, but it still ran like that. I bought a new one, hoping this would solve the issue.
Ok. I think I will continue on this. Thanks for everyones helpful answers.
Old 06-22-2014, 07:38 PM   #9
stugray
SO has the car run since the accident?
See I expected more to this story :-)
Old 06-22-2014, 10:01 PM   #10
STS-V
http://www.ft86club.com/forums/showthread.php?t=60238
The issue is that it ran fine before we put the new underhood harness and front clip on.
Old 06-22-2014, 10:29 PM   #11
mike the snake
You sure you have fuel pressure/fuel pump working?
Old 06-23-2014, 12:13 AM   #12
Poodles
Drives: 2015 Series.Blue
I wonder if the P0198 code would cause the engine to shut down? I know many cars will shut down if they detect low oil pressure to protect the engine.
Old 06-23-2014, 07:31 AM   #13
STS-V
I can hear the fuel pump kick on during ignition for a second or two. And it does fire and run for a second before it just dies. I will double check.
I dont think so. I had this sensor completely disconnected when I was lot running and driving it at the body shop.
Old 06-23-2014, 01:37 PM   #14
STS-V
Got it. She lives part 2 SHE RUNS.
Thats actually a video. click it.
It ended up being a bad ground. I had a ground attached to trans and not the body, who would have thought.
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 09:35 PM
P0102, P0113, P2096 Engine code Oburn Engine, Exhaust, Transmission 24 09-22-2014 04:30 PM
p0198 code oil temp sensor malfunction circuit high kingkai23 Forced Induction 10 06-17-2014 01:22 PM
6MT wont shift? StRacngtC06 Issues | Warranty | Recalls / TSB 14 01-07-2014 11:59 AM
Door wont stay open cregor Issues | Warranty | Recalls / TSB 21 06-11-2013 11:43 PM
