Old 06-19-2014, 07:53 PM   #15
Frs x3
Likes it in the rear
Frs x3's Avatar
Drives: RS 1.0
Link still broken :/
Frs x3 is offline   Reply With Quote
Old 06-19-2014, 08:06 PM   #16
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
For some reason pasting the link is not working. Try doing a search on Amazon for Bojo- Blue Genius Car Trim Clip Pry Removal Tool Kit.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
Old 06-19-2014, 09:57 PM   #17
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
[ame=http://www.amazon.com/Bojo-Blue-Genius-Trim-Removal/dp/B005CICS1O]Here's the link[/ame]
@CruiseZen you must be copying it weird or you're on a phone because I was able to copy and paste it in just fine, same item based on your link (item code is the same)...?
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 06-19-2014, 10:27 PM   #18
cycleboy
Drives: 2013 Scion FR-S - Argento
Originally Posted by hur1ey02 View Post
I just popped mine out with a flathead screwdriver using the rest of the foam as leverage. It felt like they'd shatter, but they are a pretty simple clip and it was easy to put them back in (so no damage!)
I did the same, took out the foam in order to zip tie/foam tap anything possibly rattling. Kind of scary to pry them that much but it worked, nothing broke, and all went back together.
cycleboy is offline   Reply With Quote
Old 06-19-2014, 10:54 PM   #19
86Toyobaru
Drives: 86 & GRB
Those clips are very easy to remove when I install rear strut bar. Just use the tool below. You can use this tool for almost all the trim clips in the car. No need to spend money for expensive tool.
86Toyobaru is offline   Reply With Quote
Old 06-20-2014, 10:35 AM   #20
phobos512
phobos512's Avatar
I agree. Not to mention, there's no need to have a hard-on for US made tooling when you're driving an imported vehicle!
Old 06-24-2014, 01:22 AM   #21
86Toyobaru
Drives: 86 & GRB
I found a better tool to remove clips.
Old 09-01-2015, 12:06 AM   #22
xtral
xtral's Avatar
Drives: Ford Focus 09'
I removed the clip but when I try to put back it can no longer insert firmly.. looks like I damaged something on the other side of the clip, Is there a way to fix this ?
xtral is offline   Reply With Quote
Old 09-01-2015, 12:56 AM   #23
xtral
xtral's Avatar
so I broke this part, I can't find a way to buy this part then to replace it .. Any suggestions for help ?
Old 09-01-2015, 12:59 AM   #24
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
I use a fork I broke in middle and a thin computer flathead. I used to have a thin special tool like below but it was forgotten somewhere.
Old 09-01-2015, 04:09 PM   #25
Fishbed77
Fishbed77's Avatar
Drives: 2013 FR-S 6MT Whiteout
Does anyone know the part number off the top of their head for those clips? I just happen to need a few.
Fishbed77 is offline   Reply With Quote
Old 09-01-2015, 04:11 PM   #26
http://www.ft86club.com/forums/showthread.php?t=94163
rain guards? clips or no clips? kylem1853 Cosmetic Modification (Interior/Exterior/Lighting) 7 10-29-2013 02:59 PM
where to cop missing tabs/clips YDNA Southern California 4 06-18-2013 04:26 AM
How do you remove plastic clips? ayau Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 01-13-2013 10:42 PM
Need Help... Missing Clips NoLeftHere Scion FR-S / Toyota 86 GT86 General Forum 9 11-29-2012 01:13 AM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 11:41 PM
