Old 06-19-2014, 04:20 AM   #1
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
Remove clips....
OK... a simple question here, how do you remove this kind of clip? The only thing I can see is just pulling on them with plyers, is that the way to go? Don't they break? These aren't like the clips on the side panels which have a proper release method (you pop the inside out with a screw driver then the whole clip comes out nicely)
Harvey is offline   Reply With Quote
Old 06-19-2014, 04:25 AM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
There's a special tool to remove them.. it's like a bent screw driver with like a fork attached to it. But you could try using a flat head and popping them out carefully.
If you do break them... they're pretty cheap to replace.
N1rve
Old 06-19-2014, 04:40 AM   #3
Harvey
OK, I see what the tool looks like (I've seen it in the repair manual special tool section), I'll see if I can find one, otherwise I'll try using some thin pincers I have which should be able to slide beneath, or maybe try to make a tool out of sheet meta...
In all cases, you confirm that there's no special movement to apply (like turn clockwise while pulling, or push in center and pull on edges, or whatever else)? I just need to somehow pull it and it should come out?
Old 06-19-2014, 04:51 AM   #4
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
No special movement, it has a ball on the end, and the clip part is actually attached to the body. If you can, try to pull it out straight. The way I ended up doing it, was to slide my fingers between the foam and the metal body on either side of the clip, and pull the foam straight up and they will pop out with no scratches or damage.
Old 06-19-2014, 06:11 AM   #5
Harvey
OK, thanks, I'll see if by any chance I can pick up the special tool, otherwise I'll do it with whatever I've got.
Sometime ago I came across a "paper" that listed all kinds of clips/fasteners used by different automative manufacturers and how they should be removed (tools, method, risk, ...)... it was pretty good, but can't find it anymore. Anyone have something similar?
Old 06-19-2014, 06:56 AM   #6
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Remove clips....
This?
http://www.wclco.com/Plastic_Compone..._Fasteners.php
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 06-19-2014, 07:53 AM   #7
kevman_101
Drives: 2013 Scion FRS
I just pulled straight up on the foam and they poped out. They can shoot out so keep an eye in case they fly out the car or into a crevise some where. They do make a nasty sound I found when they poped out, but none broke .
kevman_101 is offline   Reply With Quote
Old 06-19-2014, 08:31 AM   #8
J_kennington
Drives: 2013 asphalt scion FRS
^ this guy. Just grab the foam...and yank straight up on it. Clip will come undone. It's how I did it when I installed my springs.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 06-19-2014, 08:56 AM   #9
Harvey
Originally Posted by phobos512 View Post
No, it wasn't that, but that's interisting all the same... anychance someone knows which one we're talking about here? Is it the "Snap Rivets" type? Not that it really matters....
Old 06-19-2014, 09:20 AM   #10
hur1ey02
hur1ey02's Avatar
I just popped mine out with a flathead screwdriver using the rest of the foam as leverage. It felt like they'd shatter, but they are a pretty simple clip and it was easy to put them back in (so no damage!)
I had lost a socket (the 8mm one) while doing some taillight installs and had to fetch it.
Amanda - 2013 Scion FRS (Raven)
hur1ey02 is offline   Reply With Quote
Old 06-19-2014, 01:51 PM   #11
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
[ame="http://www.amazon.com/dp/B005CICS1O/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=ZERZ QSXTRBUG&coliid=I17LZAYZMKUZKL"]Amazon.com: Bojo- Blue Genius Car Trim Clip Pry Removal Tool Kit: Automotive[/ame]
These are the tools you will need to safely remove panels and clips. These are made of glass filled nylon (made in US) and not cheap brittle plastic (made in China) that will tend to break when you try use it.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
Old 06-19-2014, 02:50 PM   #12
phobos512
phobos512's Avatar
Link is broken.
Old 06-19-2014, 03:18 PM   #13
Tromatic
Harbor Fright tools has a kit for those things.
There was a cheap plastic set but I dont see it now. The right tool for those things is nice, since finding the rattle causd by pieces of a brokn clip sucks.
http://t.harborfreight.com/6-piece-p...set-66188.html
Tromatic is offline   Reply With Quote
Old 06-19-2014, 06:34 PM   #14
CruiseZen
CruiseZen's Avatar
Link is broken.
I'll try again.
[ame="http://www.amazon.com/dp/B005CICS1O/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=ZERZ QSXTRBUG&coliid=I17LZAYZMKUZKL#productDetails"]Amazon.com: Bojo- Blue Genius Car Trim Clip Pry Removal Tool Kit: Automotive[/ame]
rain guards? clips or no clips? kylem1853 Cosmetic Modification (Interior/Exterior/Lighting) 7 10-29-2013 01:59 PM
where to cop missing tabs/clips YDNA Southern California 4 06-18-2013 03:26 AM
How do you remove plastic clips? ayau Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 01-13-2013 09:42 PM
Need Help... Missing Clips NoLeftHere Scion FR-S / Toyota 86 GT86 General Forum 9 11-29-2012 12:13 AM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
