#15 |
Likes it in the rear
Drives: RS 1.0
Link still broken :/
#16 |
Drives: 2014 Ultramarine 6MT FR-S Monogram
For some reason pasting the link is not working. Try doing a search on Amazon for Bojo- Blue Genius Car Trim Clip Pry Removal Tool Kit.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
#17 | |
Drives: 2014 FR-S 6MT Whiteout
@CruiseZen you must be copying it weird or you're on a phone because I was able to copy and paste it in just fine, same item based on your link (item code is the same)...?
#18 |
Drives: 2013 Scion FR-S - Argento
I did the same, took out the foam in order to zip tie/foam tap anything possibly rattling. Kind of scary to pry them that much but it worked, nothing broke, and all went back together.
#19 |
Drives: 86 & GRB
Those clips are very easy to remove when I install rear strut bar. Just use the tool below. You can use this tool for almost all the trim clips in the car. No need to spend money for expensive tool.
#20 | |
#21 |
Drives: 86 & GRB
I found a better tool to remove clips.
#22 |
Drives: Ford Focus 09'
I removed the clip but when I try to put back it can no longer insert firmly.. looks like I damaged something on the other side of the clip, Is there a way to fix this ?
#23 |
so I broke this part, I can't find a way to buy this part then to replace it .. Any suggestions for help ? Sent from my iPhone using Tapatalk |
#24 |
hey you, yeah you <3
Drives: 2014 37J FR-S
I use a fork I broke in middle and a thin computer flathead. I used to have a thin special tool like below but it was forgotten somewhere.
#25 |
Drives: 2013 FR-S 6MT Whiteout
Does anyone know the part number off the top of their head for those clips? I just happen to need a few.
#26 |
| rain guards? clips or no clips? | kylem1853 | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 10-29-2013 02:59 PM |
| where to cop missing tabs/clips | YDNA | Southern California | 4 | 06-18-2013 04:26 AM |
| How do you remove plastic clips? | ayau | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 01-13-2013 10:42 PM |
| Need Help... Missing Clips | NoLeftHere | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-29-2012 01:13 AM |
| will polishing your car to remove swirls remove opti-coat? | bacon_cheese_beer | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 10-25-2012 11:41 PM |
