Old 06-16-2014, 12:57 AM   #127
RenegadeSS
Drives: Camaro LS/M6
Originally Posted by RB Performance Brakes View Post
For those of you planning on retro fitting or already have the WRX calipers.
RacingBrake offers Front Light Weight Two Piece Rotors for Subaru WRX
That will work with your FRS/BRZ Caliper swap.
FT86Forums member receive free shipping to the lower 48 states using coupon code FT86-SHIP
Reference Photo
RacingBrake Rotors feature 3 patented designs
  • Center Mount – Hat mounts onto the surface of the rotor ring, balancing stress load and improving cooling by allowing air flow to enter from both the inboard and outboard side of the rotor
  • Convergent Vane – Provides efficient air flow and temperature across the disc surface
  • Open Slot – Advantage of both drilled and slotted, optimizes the friction between pad and disc
Street and Track brake pads are also available for your WRX Calipers.
To learn more about us,
Visit our website at
www.RacingBrake.com
I have your brakes on my camaro, and Love them. I would like to have them on my FRS, but I also want a matching rear set. When will the rear be available?
RenegadeSS is offline   Reply With Quote
Old 06-17-2014, 11:36 AM   #128
RB Performance Brakes's Avatar
Drives: BRZ/FRS
Are you looking for OE Two piece replacements for your OE brz/frs calipers or for the non Sti 4 pots?
RB Performance Brakes is offline   Reply With Quote
Old 06-18-2014, 08:11 AM   #129
RenegadeSS
Yes. I want a front and rear matching two piece OE size set, but you BBK is looking really good right now.
Old 06-18-2014, 12:50 PM   #130
Drives: BRZ/FRS
Unfortunately we only have a OE two piece size rotor that will fit the non STi Subaru 4 pots.
We offer several kits for BRZ/FRS's,
once of which is an OE BBK
http://www.ft86club.com/forums/showthread.php?t=59888
We do offer a two piece rotor for the OE BBK if thats something your interested in.
or our tradtional BBK's
http://www.ft86club.com/forums/showthread.php?t=66196
if you need any help,
feel free to ask!
Old 06-18-2014, 05:12 PM   #131
RenegadeSS
feel free to ask!
Awesome. I just printed out a template, and checking for fitment. I have some Enkei RPF1s on the way for it.
Old 06-18-2014, 05:34 PM   #132
Drives: BRZ/FRS
Awesome,
let us know how it turns out for you!
The Following User Says Thank You to RB Performance Brakes For This Useful Post:
RenegadeSS (06-18-2014)
Old 05-23-2016, 09:05 AM   #133
Tor
Tor's Avatar
Drives: Toyota GT86
Digging up this old thread. Are anyone using the WRX (non sti/bremo) on track?
Do they have better resistance to heat that the stock callipers?
Tor is offline   Reply With Quote
Old 05-23-2016, 09:59 AM   #134
Northwest86
Drives: Velocity Orange 86 GT
They shift bias to the rear from memory. They give more feel some people believe. I just think thats a placebo effect personally. Heatwise they would be minimally different. Not really worth the money. In my opinion you get good pads and fluid, then do a ducting system if needed. If you are exceeding that then you need to look at technique or get a real BBK like the AP setup.
Northwest86 is offline   Reply With Quote
The Following User Says Thank You to Northwest86 For This Useful Post:
Tor (05-23-2016)
Old 05-23-2016, 10:27 AM   #135
Tor
Tor's Avatar
Drives: Toyota GT86
Thanks @Northwest86
I have a track locally (Zolder Circuit) that is quite brake heavy. Lot's braking from 110 mph down to 50-60 and minimal time to cool before the next corner.
I have pads, ss brake lines, Castrol fluid, and Porsche brake cooling. The way it is now, the brakes gets mushy after 2-3 fast laps. They don't really fade, there is still lots of braking effect, but the pedal gets a spongy feel.
Also my discs are looking burned around the edge. Where there was rust, there is now golden/grey deposits.
My though was to get some high quality discs (2 piece rotors, stock size). But I am worried if it will move the problem to the callipers? And was considering if these might help if that's the case.
Probably I am better off going straight to BBK?
Old 05-23-2016, 11:16 AM   #136
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Two piece rotors in stock size will be worse regarding endurance/cooling... Same amount of heat to dissipate in less material. They'll be lighter, though.
Guillaume is offline   Reply With Quote
The Following User Says Thank You to Guillaume For This Useful Post:
Tor (05-23-2016)
Old 05-23-2016, 11:38 AM   #137
Northwest86
Those pads are good for about 650C. Stuff like Project Mu HC800s are good for 800 and club racers are similar. So that could help. We have some fairly major braking circuits (5-6 moderate braking points and one large one.) They run fine for us so far. I'm not sure on how the porsche cooling setup is. I assume its a duct into the centre of the rotor? If so maybe a different pad will work better. When some pads get into certain temp ranges they change feel. If a different pad doesn't work then a BBK may be needed. Also look if there is any technique that can be improved. The pedal dance in my experience can reduce temps with less brake pulsing and avoiding ABS at all costs is crucial or they can cook quickly.
What are your rotor temps? Thats usually the best indicator of if you are over the threshold. The DBA rotors have temp paint that changes colour if its exposed to a high enough heat for a period of time. My fronts for example set off the highest marker which is at 660C from memory. I changed brake pads and I've never been that high again. Getting some temp paint meant for brakes and putting it on the outside of the rotor may help see whats happening and if you need a bbk.
Tor (05-23-2016)
Old 05-23-2016, 03:36 PM   #138
Tor
Tor's Avatar
Drives: Toyota GT86
I thought aluminum hats would dissipate the heat better?
They look like this and cost a fortune, 576€ for a pair.
They are available as a one piece as well and 200€ less. Would the only benefit be the weight savings (and even with the cost of less heat resistance)?
Old 05-23-2016, 03:49 PM   #139
Tor
Tor's Avatar
Drives: Toyota GT86
I definitely didn't have pad fade. So I think they hold up pretty well.
It's just an air guide along the lower control arm.
I wasn't aware of that. Thanks, that could of course be the case too.
I didn't get into ABS too often. I'll try pedal dance too next time. Anything to be aware of regarding the lack of electronic brake force distribution? I mean if that will have an impact on handling I should be aware of?
I don't know, I am still on stock rotors. Maybe a rotor change is all I need?
Thanks for your help and advice, it's much appreciated.
Regarding the WRX callipers:
I have the chance to get my hands on some that was only used for 300 miles at the moment (the previous owner ditched them as he had troubles bleeding them). Would a slight increased rear balance be a negative thing? Or could that actually be a benefit?
Old 05-23-2016, 04:40 PM   #140
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Most of the heat flux goes through the bolts between the flange and rotor (higher contact pressure) and the extra interfaces add thermal resistance. For endurance, you really want mass. The aluminium's higher conductivity doesn't make up for all that.
With stock callipers,you're better off with good OEM replacement (Centric for instance) and extra cooling (this recently popped up http://www.ft86club.com/forums/showthread.php?t=105825 ).
Tor (05-23-2016)
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 01:02 PM
Subaru BRZ - RAW Subaru | Official Subaru Australia Ad Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 15 07-20-2012 08:20 AM
Subaru BRZ vinyl wrapped MATTE WHITE , Showing @ Subaru Summer Solstice 2012 Premium Auto Styling Southern California 2 06-22-2012 07:34 PM
Subaru/Toyota Coupe spotted in Socal with Subaru Plates owsiu Scion FR-S / Toyota 86 GT86 General Forum 150 05-25-2011 10:27 PM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) — General Topics 39 03-24-2011 09:22 AM
