Old 06-17-2014, 07:16 PM   #1
Scionguy28
Scionguy28's Avatar
Drives: Scion FR-S 10 Series
Stock Audio
Hey guys! I'm new to the forum but a proud owner of a 10 Series FR-S, I just had a question about the aweful FRS Audio. Is there a way to keep the stock speakers and use an Amp to better the audio?
Scionguy28 is offline   Reply With Quote
Old 06-17-2014, 07:38 PM   #2
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
OEM Audio+
DoomsdayJesus is offline   Reply With Quote
Old 06-17-2014, 07:43 PM   #3
Scionguy28
Scionguy28's Avatar
Originally Posted by DoomsdayJesus View Post
OEM Audio+
I've heard mixed reviews about the OEM, it seems to be the best option though
Old 06-17-2014, 07:43 PM   #4
cnk
Drives: '13 DGM BRZ Limited
You can always try a different HU and move on from there based on your budget and what you want to do. I just bit the bullet and replaced everything except the rear speakers. Some are happy adding the factory sub or going with a loc and amp/sub. OEM Audio+ as mentioned above is also a popular choice. I wanted more control than what they offered so I went custom.
Sent from my Transformer using Tapatalk
cnk is online now   Reply With Quote
Old 06-17-2014, 07:43 PM   #5
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Stock Audio
I believe this thread will be the best help for what you're trying to do.
http://www.ft86club.com/forums/showthread.php?t=42239
Old 06-17-2014, 09:52 PM   #6
Scionguy28
Scionguy28's Avatar
Thanks!!
Old 06-18-2014, 07:45 AM   #7
AtlasMick
Drives: FR-S 2013 Asphalt
Use sound deadener in the doors. It is like magic the difference you will hear. Only cover about 25% of the panel's surface area though because anymore isn't going to make much of a difference. Then use cardboard and duct tape to seal up all the holes and something like dynaliner over the whole door behind the door card. Night and day.
AtlasMick is offline   Reply With Quote
Old 06-18-2014, 12:21 PM   #8
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
you have done this already right? http://www.ft86club.com/forums/showthread.php?t=7578
I know the stock setup is still not good but this helps
Bu-Tang is offline   Reply With Quote
Old 06-19-2014, 09:31 PM   #9
Scionguy28
Scionguy28's Avatar
Thanks!!! Mine was set to Tc! It did make a difference!
Old 06-19-2014, 10:13 PM   #10
fz6r
Drives: 13 10 series FRS
What did you replace the door speakers with?
fz6r is offline   Reply With Quote
Old 06-19-2014, 10:27 PM   #11
cnk
Diamond Audio Hex S600S components. Not the ones they sell now, the good ones with the Eton drivers. I had them in my WRX so I just used them since they still work great. Pioneer AVIC-8000NEX for the HU, JL Audio 900/5 for the amp. Bridged front/rear channels for the front stage. Rears running off the HU. Currently have an old JL Audio 10W0 sub in a Prowedge box, but have a Sound Integrity enclosure on the way. JL 10W6v3 will be used with it.
The Following User Says Thank You to cnk For This Useful Post:
fz6r (06-20-2014)
Old 06-19-2014, 11:06 PM   #12
CatDaddysBBQ
Drives: '13 FR-S
Low budget: installed a 150w amp and sealed 8"sub in trunk. Swapped dash speakers. Adjusted output levels to minimize bass going to car speakers and let sub handle it, which took away 85% of interior/door rattle and vibration.
Sounds... Good. It's no show car setup, but if it were this good from the factory most people would hardly swap much more, let alone complain like we all do about it.
It's plenty loud and thumping inside the car but isn't the kind of loud that annoys the neighbors. Perfect.
CatDaddysBBQ is offline   Reply With Quote
WTT: Audio Equipment for Stock Wheels?! mastamoon NY / NJ / CT / PA 3 05-02-2014 04:07 PM
OBD II on Stock audio system cc DIY (Do-It-Yourself) Guides 15 10-04-2013 12:35 AM
Stock audio Gunman Electronics | Audio | NAV | Infotainment 4 04-09-2013 04:41 PM
[DIY] USB Audio Fixes (FR-S Stock HU) mezdup Electronics | Audio | NAV | Infotainment 9 02-10-2013 02:00 PM
audio formats that the stock stereo will play? jstn Electronics | Audio | NAV | Infotainment 5 11-14-2012 11:13 PM
