| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: Scion FRS 10 series
OBD II on Stock audio system
is it possible use bluetooth OBD II and show data on stock audio system?
Drives: Whiteout FR-S
No
Sent from my SGH-M919 using Tapatalk 2 |
There are now 2 carseats!
Drives: 2013 DGM BRZ
It is possible probably.
Use the RCA ins of the backup camera hookup like a video-in hookup. Wire a switch so you can fool the HU into thinking it is in reverse. Use a digital to analog converter and the mini hdmi out on your android phone. I just checked the digital to analog converters are like $30. you might still have trouble with getting it to look good. |
#4 | |
do you know how to show my andoriod phone on the stock audio unit? Sent from my Nexus 10 using Tapatalk 4 |
The stock frs one. No. Only the bespoke has a screen and I'm not sure if it has an input for a reverse camera.
I was only hypothesizing that you could do this with the brz one. Other problem I didn't think about was the backup lines overlay it places on the video. I don't know if you can turn that off or not. |
Drives: 2023 WRB BRZ (MT)
backup lines are camera dependent. i have mine hooked to a switch and wen i hook up my SNES theres no lines, but u will have to deal with "CHECK SURROUNDINGS FOR SAFETY". that cant b disabled
i have the 10 series, the stock audio system with screen.
DADA
Drives: 2013
A little off topic , what code is everyone using to connect to the obd reader?
I tried 1234,123,0000,000,6789,789,999,9999,111,1111 Nothing seems to work |
i using bluetooth connector, data show on my galaxy note ii, but i want it show on the stock audio screen
#10 |
6789 Last edited by robot; 09-18-2013 at 08:23 PM. |
#11 |
I did find what should be a solution to this...it's convoluted though.
First you'd need this to convert an hdmi signal to composite: [ame="http://www.amazon.com/Mini-Composite-CVBS-Converter-1080P/dp/B009A6PJKQ/ref=sr_1_5?ie=UTF8&qid=1378855156&sr=8-5&keywords=hdmi+to+composite+converter"]Amazon.com: Mini Composite RCA CVBS AV to HDMI Converter For VCR DVD 720P 1080P: Electronics[/ame] and an android device like this to run torque: [ame="http://www.amazon.com/Version-Bluetooth-Android-Google-Dongle/dp/B00A1ZTQB8/ref=sr_1_1?ie=UTF8&qid=1378855304&sr=8-1&keywords=mini+android+pc+bluetooth"]Amazon.com: New Version Bluetooth Ug007 Mini Pc Android 4.1 Google Tv Dongle Dual Core Cortex A9 Wifi 1080p RAM 1gb+rom 8gb+3d: Electronics[/ame] then you need a way to power it all: so 12v to usb would work...tuck that under your dash somewhere then you'd need some way of controlling the screen: so a touch pad or something then you'd have to wire an spst switch to tell the screen your car is in reverse...so you can switch to the input on demand. Then you'd have to solve the issue of getting android to boot and run an application on boot...https://play.google.com/store/apps/d...=com.autostart Seems simple enough. Oh, and those little mini-computers don't have accelerometers so you'd be missing out on capturing those readings. $30 + $45 + $10 + $5 + $15 = $105 I kind of want to do this, but it's in the realm of not worth it. You could even get it down some if you used your own phone or tablet in place of the mini computer, but then you'd have to set it up every time you got in the car. |
#12 |
BRZ FNG
Drives: 00 Civic LX/CWP or GBS BRZ someday
If any of you are into basic programming, there's a simple little Android computer called the Raspberry Pi. It can run apps, music sharing, internet services, etc. It can also fit almost anywhere and has multiple awesome outputs. I may try to set up Torque on it with an added accelerometer board and hook it up to the factory BRZ head unit once I actually purchase my baby.
Seriously, look it up. It requres 5V power (tap into the USB port power) and has audio out, video out, an HDMI port, ethernet, USB, everything. Seems awesome to me. It's also pretty damned quick for its size and low price. |
#13 | |
So, this should only set me back $20 for the converter, $2 for the hdmi mini to hdmi cable, $a few to for the molex to rca adapter for the back of the headunit, etc. I wonder if there is a gps/vss limitation that shuts of the reverse camera video at speed? |
#14 |
Drives: Scion FR-S
Using Ipad mini
I just use my Ipad mini with Dashcommand app
I got pictures on my profile |
| OEM Audio + system in Canada? | Bradvot | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 10-09-2013 11:20 AM |
| Anyone in the Bay Area have the OEM Audio Plus System in FRS? | JohnAyySays | Northern California | 5 | 07-29-2013 02:42 PM |
| BRZ Stock Audio Video System / USB Drive Issue | Space Boy Matt | Electronics | Audio | NAV | Infotainment | 0 | 10-23-2012 01:19 PM |
| Audio System/JBL Package | Olly | AUSTRALIA | 18 | 09-06-2012 05:41 PM |
| New Audio system going in | Jordan6908 | Electronics | Audio | NAV | Infotainment | 20 | 06-25-2012 02:12 PM |
