Old 04-08-2013, 12:42 PM   #1
Gunman
Drives: 2019 Mazda Miata RF
Stock audio
Is the stock audio system just lack bottom end? I've had my BRZ Limited for a couple weeks now, and played with the EQ settings, and the highs in the dash seem to be all I hear. I checked the other speakers, they are working, but the bass end of the spectrum is lacking.
If that's the case, I'm going to have to dig out some old school equipment I have, ie a pair of 6" dvc bazooka bass tubes, and a PPI 2050 amp. The stock audio in my F150 sounds better.
Edit: Let me add, that this is a low volumes. Once the dial gets up around 30, the doors and lower frequencies are more audible and balanced.
Gunman is offline   Reply With Quote
Old 04-08-2013, 01:06 PM   #2
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
If you want clean, clear, deep bass, you need more than your Bazooka tubes in your trunk. The BRZ is a "smaller" car but has more than twice the cabin volume of your F-150.
Scott
naikaidriver is offline   Reply With Quote
Old 04-08-2013, 10:09 PM   #3
Gunman
I ran these tubes in my standard cab Ranger, and my Mustang, so I'm sure they will make up for whats lacking at the lower volumes.
The F150 is a supercab, so with the trunk volume of the BRZ I suspect cabin volume isn't much different.
The question is, or more correctly the problem, is the amplified door speakers don't do much at lower volumes.
Old 04-09-2013, 03:28 PM   #4
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Sealing + deadening the doors has a huge impact on how well those doors speakers play the bottom end. i would recommend that before anything.
FreshFRS is offline   Reply With Quote
Old 04-09-2013, 03:41 PM   #5
mashal
DADA
mashal's Avatar
Drives: 2013
I'm with him , the frs stock audio system isn't all that bad, but it rattles like a can.. Seal it and it will have a huge impact
mashal is offline   Reply With Quote
The Following User Says Thank You to mashal For This Useful Post:
FreshFRS (04-09-2013)
Static audio with radio reception? FRS stock stereo encity5 Electronics | Audio | NAV | Infotainment 14 10-02-2013 09:58 PM
FS: Stock BRZ head unit (Sat, Nav, BT audio, etc) with amp & speakers Mach V Dan Audio/Visual, Electronics, Infotainment, NAV 20 02-18-2013 04:59 PM
[DIY] USB Audio Fixes (FR-S Stock HU) mezdup Electronics | Audio | NAV | Infotainment 9 02-10-2013 01:00 PM
audio formats that the stock stereo will play? jstn Electronics | Audio | NAV | Infotainment 5 11-14-2012 10:13 PM
BRZ Stock Audio Video System / USB Drive Issue Space Boy Matt Electronics | Audio | NAV | Infotainment 0 10-23-2012 01:19 PM
