Old 06-16-2014, 07:01 AM   #6231
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Originally Posted by nlowell View Post
Thanks...looking at some logs from tonight, I actually recorded a 4.79 at 2,835 RPM. The only problem is my AFR at that RPM was 18.03:1...
Check your log for knock events. If you're getting knock, stop using the ESC until the AFR is adjusted.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 06-16-2014, 09:19 AM   #6232
fenton
Originally Posted by DeliciousTuning View Post
The OEM Map sensor only reads to about 5 pounds of boost, that equates to about a 1.37 bar map sensor. So it is not truely a 1.5 bar map sensor.
Cheers,
William Knose
Does it depend on your atmospheric pressure or is it just 1.37 for all?
thanks for the info!
fenton is offline   Reply With Quote
Old 06-16-2014, 09:23 AM   #6233
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Flashed back to 91 this morning -- just waiting on the tune from the guys over at Vishnu, then install should happen in the next day or two, finally.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 06-16-2014, 09:57 AM   #6234
raven1231
Yeah the highest it seems like most of us peak is 4.79
Old 06-16-2014, 10:27 AM   #6235
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Will test this today.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
raven1231 (06-16-2014)
Old 06-16-2014, 10:44 AM   #6236
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by DAEMANO View Post
Also, don't know if this matters in Canada but it kills the crickets in my car we get in California caused by the ethanol in CA91 pump gas (which is roughly e10)
I've been on ethanol-free fuel for over half a year and still got the crickets, so I don't think ethanol is the cause.
Originally Posted by Sojhinn View Post
Im going to vegas this week, so Im getting my alignment done tomorrow.
Originally Posted by DC2R View Post
Funny in in las Vegas right now from Miami
Sent from my SM-G900T using Tapatalk
I'll be there on Thursday! Flying, though.
TM is offline   Reply With Quote
Old 06-16-2014, 11:07 AM   #6237
Sojhinn
Sojhinn's Avatar
I'm at Vegas Tuesday- Friday.
Installed Mods:
Old 06-16-2014, 12:38 PM   #6238
DAEMANO
Time Traveller
The general consensus on is that the crickets are caused by decreased lubricity of ethanol and evaporation of ethanol causing air bubbles in the HPFP. These issues are so well known that companies like Lucas market products to restore the above properties into vehicles running e85. Using these or other fuel additives or lubricants (like 2 stroke oil) even in small concentrations tends to resolve the issue immediately. However, even a quarter tank of blended ethanol gasoline can bring the crickets back.
From what I understand, in NY unless the gas pump specifically states "Ethanol Free", chances are you're getting gas with Ethanol. Just as an example of how sparse ethanol free stations are in NY, in 2012 there were two known ethanol free gas stations in central NY, and it made the news. http://www.syracuse.com/news/index.s...gas_stati.html
Currently there are many more spread across NY, still however it's quite sparse. Here are the known ethanol free pumps in NY on buyrealgas.com . http://buyrealgas.com/NewYork.html
Making it even more difficult to know if your gas has "E" content or not, NY gas stations are not required to label gas that has ethanol with ethanol concentration like they do in CA. http://www.e0pc.com/NY.php
Funny thing is, some fuel stations that sell heavy "E" concentration gas, blend in an additive that improves lubricity and evaporation which then again decreases crickets. So some people that run e85 exclusively report no crickets whatsoever. That can sometimes further confuse the issue.
The Following 3 Users Say Thank You to DAEMANO For This Useful Post:
Gums (06-16-2014), sato (06-16-2014), Stormalong (06-16-2014)
Old 06-16-2014, 01:12 PM   #6239
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Advanced Multiplier is at a solid 1 with no change.
FLKC dips from 0 to -1.95 almost always after let off after a WOT run
LTFT ranges from 0 to 5.47
FLKC: http://www.datazap.me/u/nlowell/june...og=0&data=1-12
What else do I look at to give me indication of knock and "health"?
nlowell is offline   Reply With Quote
Old 06-16-2014, 01:14 PM   #6240
Sojhinn
Sojhinn's Avatar
http://www.datazap.me/u/sojhinn/esc-15-8-weeks
My run this morning. These are all third gear pulls.
Installed Mods:
Old 06-16-2014, 01:25 PM   #6241
TM
TM's Avatar
Drives: DGM BRZ 6MT
The station that I have been getting gas at is labeled ethanol-free premium. Crickets came in after 3 months. That's when I switched to 93 with 10% e and never looked back. Also more knock resistant than the e-free 91.
Old 06-16-2014, 03:08 PM   #6242
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I guess I'll have to do some research. We had 1 station around here that sold ethanol-free gas, (local station been in business 60 years) but ~3 years ago I saw the 7% ethanol sign on the pump and asked the guy why they changed. He told me that federal mandate forced them to meet the minimum then 7% now 10% minimum ethanol content. All my lawn mower/line trimmer manuals call for low or no ethanol gas.
Target70 is offline   Reply With Quote
Old 06-16-2014, 03:50 PM   #6243
DAEMANO
Time Traveller
You may have some choices.
http://buyrealgas.com/Georgia.html
The Following User Says Thank You to DAEMANO For This Useful Post:
Target70 (06-16-2014)
Old 06-16-2014, 03:56 PM   #6244
DAEMANO
Time Traveller
I wonder if the station that was labeling ethanol free was actually ethanol free. If not, I hope you weren't paying extra at that station. In any case, you guys are lucky to be able to get 93 of any kind. I think both us peeps in Cali and in AUS get 91 as premium and it stinks.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
