Old 06-15-2014, 11:28 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
How much would a dealership charge to replace all four injectors?
I keep hearing a popping noise every time I start her up... I went FI while my car had 23k miles on it, now I have 25k and I hear this popping sensation in my car.. I'm pretty sure it's the direct injections. How much would a dealership charge to fix it?
Astroboy is offline   Reply With Quote
Old 06-16-2014, 02:15 AM   #2
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
As each dealership probably would quote you a different price, there's no way to tell without calling.
That said, what makes you think it's the injectors? And (if they are defective) what makes you think replacing them will fix the issue that caused them to go bad in the first place?
I'm going to ballpark $2-5k for engine repairs through the dealer to fix your problem - unless they won't even touch a modified engine bc they can't warranty their work, in which case they would probably say return it to stock, and then they can look in to it, or suggest you buy a whole new engine.
From your post it's impossible to say really, but I'd go through the shop that installed your FI system (supercharger or turbo?) and see what they say. Though if they messed up the job, they might not be the best shop to have working on your car.
Good luck.
Edit: my other car has an aftermarket supercharger added, though it was arranged through the dealer but sent to Dinan for installation, it's still aftermarket. Whenever I have work done it costs extra bc they have to remove the supercharger to get to the valve covers, etc. And then of course they have to re-install it when they're done. No fun. Ok, the supercharged V8 is fun, the maintenance costs - not so much fun.
ashtray is offline   Reply With Quote
Old 06-16-2014, 05:39 AM   #3
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
Good luck.
Why would the injector make a popping noise? Also, can't you try to pinpoint which one it is using the GTS Active Test stuff?
Harvey is offline   Reply With Quote
Old 06-16-2014, 08:27 AM   #4
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
the local shop charged me 1 hour of shop time to replace my aftermarket injectors
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 06-16-2014, 08:29 AM   #5
sluflyer06
Drives: 2014 BRZ Ltd - DGM
You're referrring to your standard fuel injectors, OP is referring to the Direct Injection injectors which would be in the head.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
The Following 2 Users Say Thank You to sluflyer06 For This Useful Post:
Astroboy (06-16-2014), draggin_az (06-16-2014)
Old 06-16-2014, 08:36 AM   #6
draggin_az
draggin_az's Avatar
reading trumphs all
277hp 93 octane
370hp on E-85
Old 06-16-2014, 08:53 AM   #7
sluflyer06
reading trumphs all
Heh its ok, if only the direct injectors or spark plugs were that easy to get to.
2014 BRZ Ltd. - DGM
E46 323ci vert
The Following User Says Thank You to sluflyer06 For This Useful Post:
Old 06-17-2014, 07:46 PM   #8
Astroboy
Astroboy's Avatar
Drives: None
how much
Sent from my LG-D800 using Tapatalk
Old 06-18-2014, 09:51 AM   #9
draggin_az
draggin_az's Avatar
Originally Posted by Astroboy View Post
how much
i miss read what you wrote but you were talking about the direct injectors and i was talking abou the fuel injectors. anyways it was 90.
277hp 93 octane
370hp on E-85
Old 06-18-2014, 11:01 AM   #10
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
[ame="https://www.youtube.com/watch?v=sdeO4rBwuQ4"]Scion FR-S BRZ Direct Injector Seal Replacement | Problems and Issues - YouTube[/ame]
Could be useful if you wanna DIY
Mad1723 is offline   Reply With Quote
The Following User Says Thank You to Mad1723 For This Useful Post:
whataboutbob (06-23-2014)
Old 06-18-2014, 11:08 AM   #11
Mikem53
Drives: FR-S 6MT
do you get the popping noises after its warmed up?
not uncommon to hear a pop or feel a "miss" when cold, but should not occur after warmup.
Mikem53 is offline   Reply With Quote
Old 06-18-2014, 12:12 PM   #12
Astroboy
Astroboy's Avatar
Drives: None
ok look, so look I'm in my car, I turn the steering wheel completely to the right in a complete stop, I turn on the ignition and I hear a pop coming from the right. at start. the car also starts shaking very violently from that side.
Old 06-18-2014, 12:46 PM   #13
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Don't count on it being injectors. Lots of things make pop sounds in the exhuast
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-18-2014, 12:52 PM   #14
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Sounds like di seals.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following User Says Thank You to Reaper For This Useful Post:
Does the USB port charge your phone? EAGLE5 Electronics | Audio | NAV | Infotainment 30 08-15-2014 01:44 AM
Labor time to replace pump and injectors? misooscar Forced Induction 4 06-10-2014 10:37 AM
Do you feel in Charge? LS13 Off-Topic Lounge [WARNING: NO POLITICS] 0 03-28-2014 09:01 PM
Dealership is charging me $1725 to replace my OEM clutch for BR-Z venom8776 BRZ First-Gen (2012+) — General Topics 147 02-02-2014 08:34 AM
ECU Charge??? DBacon1052 Issues | Warranty | Recalls / TSB 12 09-18-2012 11:53 PM
