Old 06-13-2014, 06:41 PM   #71
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I didn't track mine at all, but I am 100% confident that I would have worked on it till it did five 20 minute sessions a day no problem. Is a supercharger the easier solution, yes. Is a C5 Z06 an even easier solution, yes.
man, you would be surprised how the things can really change at track
and I can talk about a C5 Z06 all day , easier solution? yes
desirable solution? not for everyone if you ask me
glamcem is offline   Reply With Quote
Old 06-13-2014, 06:54 PM   #72
CSG David
CSG David's Avatar
fixt again.
@King Tut @D K is a turbo guy. LMAO
Old 06-13-2014, 08:03 PM   #73
D K
Stig's dark passenger
fixt again.
If you want to burn down a city block - Visconti tune
D K is offline   Reply With Quote
Old 06-13-2014, 08:04 PM   #74
glamcem
glamcem's Avatar
and I am an NA guy (supposedly) ..too bad I didn't have an high revving I6 motor option I'd be all over it haha
Old 06-13-2014, 08:31 PM   #75
CSG David
CSG David's Avatar
Careful that block is all you need to burn down a whole city right there.
Old 06-14-2014, 08:28 AM   #76
AJPG
Drives: 22RE, FA20, 4G63
I do it for full tank and drive until empty. Miles/gallons. 10% more consumption. OEM Rear Axles. You are welcome for my patience.
Sir with all your respect with only 10% down on MPGs that's clearly why you didn't see heating issues with your turbo BRZ.
I could easily over heat mine bone stoke on the back roads in 20 to 30 minutes, oil temp 250-290f, coolant would stay below 225f but could hear detonation. After seen that ( and that was mine fist FRS, it die young ) I have no intention to go to the track until I could warranty no heating issues...
For the record my MPGs are low, stoke 19 MPGs with FI 14 MPGs, but when my wife or mom get in the car MPGs sky rocket to 25-30. AFR 12.5 to 13 at WOT, 14 to 14.5 at partial throttle.
So a couple of weeks ago I did track my setup for 35 minutes, MPGs then get really low 10 MPGs and temps under the hood where better that expected, max engine oil temp 225f, coolant 215f, sc oil 195f.
I'm sure that it could also be done with a turbo setup, but take in consideration that I'm running an unorthodox custom made oil cooler setup ( 2 oil coolers for the engine 7.5 qts of oil and one smaller and separate for the sc )
NOTE that I live in the tropic and mine setup isn't for every one! It will only work for the heavy right foot people on hot climate.
AJPG is offline   Reply With Quote
Old 06-14-2014, 11:07 AM   #77
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
So you drive like a reckless teenager on the streets, and you think that should be the standard for MPG?
FWIW, I average over 30 MPG in my car as well (turbo'd). And it's not like I don't have fun in it- I just don't drive like an asshole everywhere I go.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following User Says Thank You to woode For This Useful Post:
AJPG (06-14-2014)
Old 06-14-2014, 12:04 PM   #78
AJPG
No!!!!
I'm lucky at the time I'm on the road there is almost no one and I can accelerate the car at it max almost every time... But this car isn't fast even with the FI... Is better.
Allways playing with the VIDI. On 0-60
So max speed 65
On the back roads 25-30 mph is fun, but wet at 10-15mph fun fun fun! With OEM tires and suspension.
Most off the time on the highway smalls accelerations15-60 also fun!
Never race on public roads!
Old 06-15-2014, 09:39 PM   #79
aaguirre123
Drives: sti 2012 sedan
I would go turbo. With turbo you hit max boost in lower rpm. With supercharger you have to wait till you reach redline.
aaguirre123 is offline   Reply With Quote
Old 06-15-2014, 10:10 PM   #80
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
http://www.ft86club.com/forums/showp...1&postcount=35
Do this
/thread
Old 06-15-2014, 10:39 PM   #81
D-VO
Drives: Whiteout FR-S, Evo 8 RS
I went with a Kraftwerks supercharger because I wanted to be different. I've always had turbo everything. (Celica, MR2, Evo) The coolest turbo kit I've seen is the STS turbo.
http://www.phasteksport.com/2013-Sci...-brz-turbo.htm
Since its rear mounted you get cooler engine temps like you would get with a supercharger but with better weight distribution.
D-VO is offline   Reply With Quote
Old 06-16-2014, 10:43 AM   #82
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You don't want to list the downsides of a rear mount turbo? @Cross has a prototype STS setup on his.
Old 06-16-2014, 11:12 AM   #83
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
What are you even buying when you get the STS setup? $7,000 with a tune an intercooler. And that's without the options.
Old 06-16-2014, 03:11 PM   #84
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
I found this thread very enjoyable . I've been researching turbo kits for my stock 2014 manual gt86 and I believe I've decided on jdlautodesign going to go with the bigger turbo and the UEL option. Any downsides here?? Air conditioning?
Celigts is offline   Reply With Quote
Installing a Turbo Kit + other mods chiefshayan Forced Induction 21 01-22-2014 11:58 PM
Unnecessary Boost needed (Turbo or Supercharge) Nickse30 Forced Induction 32 05-27-2013 01:57 PM
turbo kit supporting mods lbroskee Forced Induction 13 03-30-2013 09:56 PM
NA engine mods for turbo money? subatoy Engine, Exhaust, Transmission 62 11-28-2012 05:32 PM
if going FI, would you turbocharge or supercharge? tibsy92 AUSTRALIA 35 08-18-2012 11:02 PM
