Old 06-13-2014, 12:10 PM   #43
torqdork
torqdork's Avatar
Drives: RV-7
Originally Posted by codesplice View Post
I think we'll see that about the same time that GPS autolockouts get integrated into the V1 hardware
Each side has stated for years that their competitor's driving feature (Arrows / Lockouts) is unnecessary or even harmful. It would be interesting indeed to see Mike V. backpedal on that!
Thanks for the rdforum link, I'm surfing the V1 forum now.
What are your V1 program settings? I'm thinking some tweaking might be in order vs. running in All-Bogeys (A) mode.
torqdork is offline   Reply With Quote
Old 06-13-2014, 12:25 PM   #44
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
Custom sweeps:
Of course, I'm using these settings in conjunction with YaV1, to add in speed threshold muting and GPS autolockouts.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 06-13-2014, 12:40 PM   #45
torqdork
torqdork's Avatar
Drives: RV-7
Just installed YaV1. I'll be busy shortly.
Old 06-13-2014, 12:45 PM   #46
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
It would be something to see Escort combine V1's expired patent arrows into Passport Max. That might get me to jump ship.
I know the 9500ci will tell me if it is using the front or rear laser shifter. But the 9500ci OR ix doesn't tell the direction of a radar threat.
shiro is offline   Reply With Quote
Old 06-13-2014, 12:55 PM   #47
codesplice
codesplice's Avatar
I'm having trouble bringing it up, but I want to say that the V1 "arrows" patent was more specifically about a radar detector using two distinct antenna horns (front and rear) and analyzing the difference in received signal strength between the two to determine the signal's direction. So as long as that patent was enforced, Escort's products weren't able to determine direction. Now that it's expired, I'd love to see Escort take that idea and improve upon it - so that VR could then improve upon THAT later
I love watching the cat-and-mouse games in such a competitive industry.
G+
Old 06-13-2014, 01:09 PM   #48
shiro
shiro's Avatar
LI's have been the benchmark for several years, but lately the new winner seems to be the AntiLaser Priority: http://www.alpriorityusa.com/
I have to admit, both AntiLaser Priority and LI have some good shifters. Makes me think twice about the escort since I haven't seen much for actual spread pattern like the two top ones. This page was pretty interesting to read. Thanks!
http://www.rdforum.org/content/ecctg...hl=en&&ct=clnk
Old 08-12-2014, 10:27 AM   #49
xbb1024
Drives: Toyota 86 GTS
Has anyone tried to install rear laser shifters in a completely concealed way? like is it possible to hide it inside a modified rear bumper light or break light?
xbb1024 is offline   Reply With Quote
Old 08-12-2014, 06:58 PM   #50
codesplice
codesplice's Avatar
I've seen folks with other cars install the jammer heads inside headlights and taillights; I don't see an issue with it as long as you make sure the heads are properly aligned.
Note that most rear laser shots will be targeting the license plate, so jammer coverage should ideally be focused there. To that end, I've seen some folks mount a rear jammer head on/near one of those license plate frames with a built-in reverse camera. The camera would likely attract the most visual scrutiny, and the head could maybe be explained away as a parking sensor to be used in conjunction with the backup camera.
G+
Old 08-23-2014, 04:18 PM   #51
WyreNut
Drives: Firestorm Red FR-S
I use an Adaptiv TPX detector on my motorcycle, and transfer it to the FR-S when I need 4 wheels and Air Conditioning! :P
http://www.adaptivtechnologies.com/g...radar-detector
Not as high tech as the units mentioned in this thread, but it works, and has prevented a few "Performance Awards" from being paid to the State of CA! :-)
WyreNut
WyreNut is offline   Reply With Quote
Old 08-25-2014, 10:57 AM   #52
Casper223
Casper223's Avatar
Drives: 2015 UltraMarine, MT, Borla Exhaust
I'm new here to the site, have been lurking around reading your posts and am picking up my FRS today, hopefully....
I wanted to chime in on the Radar Detector thread, hopefully to help....
My background brings me through several years as a law enforcement officer, and then onto an over the road truck driver, and radar detectors have been part of my life it seems like forever.
All the major brand detectors on the market do a fairly good job, and really depends on the bells and whistles your looking for, like options on your cars... A few of them are invisible to Police Radar, In places like Washington, and Virginia, their a must... In areas where Laser is used... requires detection to protect yourself.
Personally... I have installed, and run a V1. It's mounted to my rear view mirror with a very professional bracket made by Blend Mount. The higher you can mount the detector in your vehicle, the better off you are, the height improves reception. I chose the V1 for a few reasons.... First and foremost, The V1 has the best Laser Detection in the business, Bar-None.... The Passport Max doesn't hold a candle to Laser detection of V1, The V1 like the Passport Max has 2 Antennas, front and rear, and just a few weeks ago, while stretching it out through Mississippi, I kept getting a beep, beep, and as I looked at my detector, found the bear was coming up from behind me, although he was a few miles behind me, it took him a while to catch up, by that time I was in the right lane, moving with the flow of traffic. The arrows on the V1 are remarkable, whether meeting a bear head on, or whether he's coming up from behind, or if he's a non threat and on the side road somewhere. The V1 is also programmable, "X" band is a dinosaur, rarely in use anywhere, but causes a lot of chatter with every detector, I shut it off, problem solved... I pay attention to "K" Band, and am very cautious of "Ka" which is almost always a Bear, and the Laser is of course the objective... One reason why I passed over the Passport Max for the V1, is because the Passport, which is a GREAT detector, uses GPS, and after marking a door alarm 3 times, Mutes that alarm. Twice recently, I've met and got by a bear, who also knew sitting in those areas was easy targeting of John Q Public... I'd rather my V1 bark once to many, than Once shy.... Those tickets aren't cheap, and the insurance is ridiculous. A couple of other things I want to throw out there, is the V1 has an optional "Remote Display" let me explain, when I'm stretching it out across say Florida's I-10, and the car behind me sees the arrows and lights on my dash, e immediately knows he's safe to jump in behind me, and before long, you tend to be the rabbit with a line of cars following you.... So I run a concealed display, which causes the face of my V1 to remain blacked out but working, and on the shelf behind my steering wheel at the bottom of my speed meter is where my concealed display is mounted, and I do use Savvy also, mostly for city driving, which it keeps chatter to a minimum in the city, by beeping once at a signal below the set speed you have it set for, and by beeping again at an exceptionally strong signal, just to keep you alert. V1, also has an iPhone and a droid app for your cell phone, and through a blue tooth adapter, flashes alarms in real time over your cell phone. The base price of the V1 is a $150 less than it's strongest competition, which is the Passport Max, and I'm guessing the $150 should pay for the GPS incorporated into the max. Another Pro or Con however you view it, is the Passport Max also will blue tooth over your phone through a network which you pay for this service and I think it's $90 bucks a year, which it communicates with other detectors on this network and tracks bears in your area, speed traps etc.... Due to the cost of this Radar Detector, plus the additional $90 bucks a year for the networking, Users of the Passport have stated it hasn't caught on as well as they had hoped it would. Make no mistake about it, Passport Max is a Dang Good detector, as is the V1. The Redline on the market is also a good detector. My problem with Redline is it has been known to detect radar up to 14 miles away.... I often pick up radar in my area 3 to 7 miles off, ALWAYS.... in plenty of time to react and be behaving before meeting the actual threat. The problem with Redline, is it's barking at a signal its getting 14 miles away, your thinking it's a false alarm by the time you actually meet the threat.
Someone else also mentioned a good point about the V1, it's an investment. Every Radar detector on the market, if you read the reviews are comparing themselves to a Valentine. Valentine has set the bench mark for many years. While others are catching up, there something very important to remember. The equipment that Police are using is constantly changing. With a Valentine One, you mail the detector back to Mike Valentine, and he updates your equipment for a nominal fee and sends it back to you, with the other detectors, toss em in the garbage, their now obsolete.
Unbeatable combination is the Valentine One, and the HP 905 Laser Jammer.... Hope this helps some, or at least provides you with some ideas and choices. I enjoy your forum, Thanks for allowing me to join.
Casper223 is offline   Reply With Quote
Old 08-25-2014, 12:37 PM   #53
Shady195
Drives: '13 10 Series FRS #1203
Best laser detection? Well thats fantastic, however to bad if your radar detector picked up on it you have already been clocked. A LiDar does not emit anything until the trigger is pulled, and once that trigger is pulled you are tagged. It's nice to know if you plan on running or want to prepare your bullshit excuse.
The V1 is a great radar detector, however I personally find the arrows/signal counter a bit gimmicky, sure its cool to know but really isnt going to change your game plan that much. Either way you're still going to slow down and be cautious.
Radar detectors are fantastic as an aide tool but never fully rely on it, don't let your senses dull and become lazy to your surroundings because you have a radar detector. Unfortunately a lot of people do.
Shady195 is offline   Reply With Quote
Old 08-25-2014, 12:57 PM   #54
Cope52
Drives: 2014 BRZ
Don't buy the Valentine. It will false so often you'll wish you were being tortured in a chinese prison instead. Something Car and Driver never told us for 20 yrs until their most recent test. Mike Valentine should be horsewhipped.
Originally Posted by LeeMaster View Post
I cannot stress this enough, when I changed my rear differential fluid with Motul 300, my clutch engagement point felt smoother.
Cope52 is offline   Reply With Quote
Old 09-10-2014, 12:02 PM   #55
coredump4
Drives: 2013 BRZ Limited MT, 2006 Spec.B
I couldn't agree with this more. I recently bought a BEL STi Magnum (twin of the Redline) after about 20 years of not having a detector, and though the Magnum is nice, I find I don't really need it that much. For that 20 years, my experience and judgement replaces a lot of what the detector is needed for. Sure, I still drive spiritedly, but there's a time and a place for certain behaviors. Like you say, the detector is a tool to provide you with information, but you should never rely on it 100% and you still have to have good judgement.
I do like having it when taking a long road trip into areas I don't regularly drive. That's when the detector is more useful, because the information it provides helps make up for lack of knowledge of the area.
coredump4 is offline   Reply With Quote
Old 11-23-2014, 12:12 AM   #56
bababooey
Drives: BRZ SWP Limited -6MT
I had an 8500 running well for about 8 years. Replaced that with an x50 a couple years back. I like having that extra layer of eyes for them sneakers. But ur toast against laser so keep your eyes peeled
bababooey is offline   Reply With Quote
Radar detectors NMMI89 Cosmetic Modification (Interior/Exterior/Lighting) 73 01-03-2019 12:54 AM
Radar Detectors TONYpepperon1 Electronics | Audio | NAV | Infotainment 39 10-09-2013 09:32 PM
radar detectors Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 9 02-24-2013 02:27 PM
Radar Detectors swag BRZ First-Gen (2012+) — General Topics 28 01-31-2013 04:58 PM
Radar Detectors nbafandan CANADA 11 01-23-2013 06:19 PM
