Old 06-12-2014, 04:51 PM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by NonStopTuning View Post
NonStopTuning has offered custom pulleys, in various sizes, since 2005. You send us your pulley, we pull measurements, and build you a custom pulley in any size and/or pattern your project requires.
Good option for JR owners.
Old 06-12-2014, 04:52 PM   #16
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
to the OP, I was recently discussing this with a friend of mine and he advised me to consider underdrive pulleys to help getting rid of some static loss and get quicker revving as it helps for better downshifting
glamcem is offline   Reply With Quote
Old 06-12-2014, 04:52 PM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
@sklimo
Old 06-12-2014, 04:53 PM   #18
glamcem
glamcem's Avatar
do you guys offer OEM size and shape lighter crank pulleys as well? shape is also very important since my crank pulley hub adapter that comes with the KW kit needs it
Old 06-12-2014, 04:57 PM   #19
NonStopTuning
NonStopTuning's Avatar
Drives: AE86
We can offer any type of custom pulley for any project. Email us if interested and please provide as much info as possible.
Best of luck with all your projects!
NonStopTuning is offline   Reply With Quote
The Following User Says Thank You to NonStopTuning For This Useful Post:
glamcem (06-12-2014)
Old 06-12-2014, 04:58 PM   #20
dp1
driving smoother faster
Drives: Sold
Now that we seem to have addressed OP's original question, what would be the smaller sizes (than 110mm) that would work for JR SC safely and without having to change injectors or compromising efficiency near the redline? I wouldn't mind a power band that comes on a little earlier, even at the expense of lowering redline if needed. Anyone looked into this for the JR Rotrex SC or it's already set up exactly where it needs to be and shouldn't be messed with?
dp1 is offline   Reply With Quote
Old 06-12-2014, 05:16 PM   #21
CSG David
CSG David's Avatar
Mmm. No comment.
Old 06-12-2014, 05:48 PM   #22
dp1
Drives: Sold
pulley size for Rotrex
Originally Posted by CSG David View Post
Mmm. No comment.
Silence is deafening...I have to provoke by assuming somebody somewhere is already looking into this
I would not want a smaller pulley unless JR Rotrex and standard injectors could handle it.
Don't need moar powah, just want it to come in a little sooner...
Old 06-12-2014, 08:16 PM   #23
CSG David
CSG David's Avatar
I'm coughing really hard. Must be the onset of another flu.
The Following User Says Thank You to CSG David For This Useful Post:
dp1 (06-12-2014)
Old 06-12-2014, 08:21 PM   #24
D K
Stig's dark passenger
How do you machine a smaller pulley to become a larger pulley?
3D printer.
D K is offline   Reply With Quote
Old 06-12-2014, 08:26 PM   #25
D K
So how much COULD the stock inj. handle?
Have you figured that out yet?
D
Old 06-12-2014, 08:37 PM   #26
dp1
Drives: Sold
D
I am not an expert but I got an impression from past reads that bigger injectors are needed around 300whp+, maybe a little less.
I'm on stock injectors at 270whp/200lbft and 11 AFR near redline based on P3 gauge with JR SC + P&L (two hi flow cats) + 2.5" Perrin, and I don't need more for street or track fun.
Old 06-12-2014, 08:41 PM   #27
dp1
Drives: Sold
I will send flu medicine immediately, mixed in with the must-reveal-truth serum 8)
Old 06-12-2014, 08:48 PM   #28
D K
You've logged your idc obviously?
Vortech 2.87 pulley belt size? draggin_az Forced Induction 0 03-31-2014 08:02 PM
Anyone know what belt size to use for a 3.125 pulley on the Vortech System? tg_1981 Forced Induction 17 08-16-2013 09:50 AM
ROTREX SC Brainstorming MANDALAY Forced Induction 61 12-11-2012 05:57 PM
Rotrex kit - why no build? MindtheGap Engine, Exhaust, Transmission 5 10-26-2012 07:01 PM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
