crew chief
Drives: Race car FR-S
pulley size for Rotrex
What boost are the Jacson Racing and Kraftwerks supercharger kit ? Do they offer different pulley sizes, i can't find anything about this except for the Vortech kit.
I know this is a weird question but the thing is i want to run LESS boost, don't ask why, i just need to make less power than what the kit makes out of the box. So, any pulley change can be done, are they available for sale with a different belt? thanks |
Drives: 2013 Ultramarine FR-S
Screw it I'm asking.... Why?
crew chief
lol, building a race car and we are limited on the amount of horsepower we can run, NA doesn't make enough power to be competitive but every FI there is is giving too much for our rules. Only the Vortech i can find a pulley to run 6 PSI.
Interesting. What are the Whp limitations?
Stig's dark passenger
You can always run a restrictor plate if you need to cut top end power...
Is it a hp/lb class? If so, you might be able to play with weights a little bit
110mm is the diameter on the JR kit.
Have you considered lowering your redline instead? You can always run a different final drive as well, to get your powerband in the RPMS you need it in. |
crew chief
yes it is a hp/lbs rule, we intend on running the car at a really low weight. Also, the thing is that the rule might change from one year to another, we might need to remove 20hp for the next year so either that or we need to had like 240lbs...
I guess i'll have to play with timing, i just thought it was nice from Vortech to be able to swap pulley to get a lower boost or higher boost when needed. |
NASA SpecE30 Racer
Area under the curve my friend. That is all I am going to say.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
Drives: Kraftwerks BRZ
#10 |
aint that the thruth
#11 | |
Drives: AE86
#12 |
NASA SpecE30 Racer
Wouldn't you have to stop tuning to machine it to their specs?
- King Tut
#13 |
#14 |
Drives: AE86
NonStopTuning has offered custom pulleys, in various sizes, since 2005. You send us your pulley, we pull measurements, and build you a custom pulley in any size and/or pattern your project requires.
| Vortech 2.87 pulley belt size? | draggin_az | Forced Induction | 0 | 03-31-2014 08:02 PM |
| Anyone know what belt size to use for a 3.125 pulley on the Vortech System? | tg_1981 | Forced Induction | 17 | 08-16-2013 09:50 AM |
| ROTREX SC Brainstorming | MANDALAY | Forced Induction | 61 | 12-11-2012 05:57 PM |
| Rotrex kit - why no build? | MindtheGap | Engine, Exhaust, Transmission | 5 | 10-26-2012 07:01 PM |
| NEOPLOT Crank pulley Alternator pulley& Waterpump pulley | ANREX | Engine, Exhaust, Transmission | 10 | 10-25-2012 07:45 PM |
