Old 06-11-2014, 09:52 PM   #29
kingkai23
Drives: 13 swp limited
Which subaru model gs ebc works on our cars 08 up wrx/sti ?
kingkai23 is offline   Reply With Quote
Old 06-12-2014, 12:20 AM   #30
D K
Stig's dark passenger
You can't vent the top of the wg to atm.
If you do, the MAX boost you will ever see is the spring.
The top and the bottom need to go to the solenoid to control it properly.
D K is offline   Reply With Quote
Old 06-12-2014, 12:22 AM   #31
D K
4 port:
top
bottom
boost
atm
Easy as that.
There are also 4 port solenoids that i believe do something similar @jamesm
Old 06-12-2014, 06:24 AM   #32
Fear
Drives: Ft86
Dual solenoid is awesome i want dat!
Fear is offline   Reply With Quote
Old 06-12-2014, 10:54 AM   #33
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
I been running a ebcs operated by ecutek for a year now
Three port is plenty for the levels our motors take
Perrin tune and solenoid
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-12-2014, 12:15 PM   #34
mike the snake
Presently I'm on the 10 pound wastegate spring. I am tuned with the Hydra standalone, and I plan to install an EBC and have the ECU control boost, when I tune for higher boost.
If I were to want to control boost per each gear (like 1st=8lbs, 2nd=10lbs, 3rd and up=highest boost) is there one setup that is better?
Old 06-12-2014, 04:28 PM   #35
RickyB
Drives: Mazdaspeed 3
You cannot use a EBC to control boost below your wastegate spring pressure. If you have a 10psi spring, your lowest boost cannot be 8psi with a boost controller.
RickyB is offline   Reply With Quote
The Following User Says Thank You to RickyB For This Useful Post:
kiichiro (06-13-2014)
Old 06-12-2014, 04:36 PM   #36
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
with a 3 port solenoid yes it works just like that, vta top of spring.
Old 06-12-2014, 07:16 PM   #37
D K
Thats not true.
You can set the duty cycle of the solenoid to hold the wg open if you want.
Old 06-12-2014, 07:49 PM   #38
xwd
Thats not true.
Huh? WGs aren't held open, they are held closed.
In order to open the WG sooner than the spring pressure you'd either have add positive pressure on the bottom WG port from some source other than the turbo or put a vacuum on the top port to pull the diaphragm upwards. I've never seen or heard of anyone doing either of those things since while doable, it would be incredibly complicated, and you could just buy a lower pressure spring for $15.
And yes you can VTA the top port of the WG. In a simple MBC/bleed setup you are just bleeding off air from the bottom WG port so the spring sees less pressure and the top port is always left VTA. However with a 3-port solenoid you would generally hook up to the top port and bleed from there to keep the WG shut longer, and it's much safer since if the line melts or the solenoid goes kaput you just get spring pressure and not 30 PSI.
The Following User Says Thank You to xwd For This Useful Post:
Sportsguy83 (07-21-2016)
Old 06-12-2014, 09:19 PM   #39
D K
Yes, that is true.
But there are ways to get lower than spring pressure. Not saying they are always conventional, but sometimes they are needed.
Old 06-13-2014, 10:15 AM   #40
kiichiro
Thats not true.
Ha
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
Old 07-21-2016, 12:10 PM   #41
handsomegirl
Drives: Toyota GT86 2015 Black Aero Kit.
When you connected the solenoid to the connector, you just left the purge and everything as is right? or did you completely remove the purge ?
Plug and play and it connects to this blue connector on the top left of the pic. When the manifold is installed in the car, it will be towards the back and driver's side.
handsomegirl is offline   Reply With Quote
Old 07-21-2016, 12:18 PM   #42
Sportsguy83
Drives: Limited BRZ
My purge valve is connected and all lines in place like stock. Just disconnected the electric connector and connected it to the EBCS, nothing else.
