Old 09-01-2013, 07:04 PM   #1
dabocx
dabocx's Avatar
Drives: Scion FRS
ECBS
So I had been running on waste-gate for the past 3 weeks but today I decided to install the EBCS, I followed the online instructions but when I went for a drive I got a check engine for P0451 ERROR code, even when we clear it we get some sort of limp mode or something that feels like it. Car is apparently building boost but it feels even slower than stock or when it was just on wastegate spring. It also spools slower and seems to run wayyy richer.
I have both the MAC ebcs and a grimspeed one, something tells me Ive done something stupid but im a bit lost or could the EBCS just not been setup in the basemap?
dabocx is offline   Reply With Quote
Old 09-01-2013, 07:07 PM   #2
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
doesnt ebcs needs a tune?
The Following User Says Thank You to whitefrs For This Useful Post:
Jason@DSG (05-12-2014)
Old 09-01-2013, 07:07 PM   #3
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
@King Tut or @Sportsguy83 can chime in
Old 09-01-2013, 08:44 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
There are some issues to address here.
1) You NEED a tune for the EBCS, because the way the EBCS works, the ECU will control the boost and control the solenoid as to when to open or close.
2) If you do not have a tune, the EBCS will open and close according to the ECU signal that is telling it to open and close to purge the gasoline tank.
3) I had the same issue when I installed the EBCS without a tune as far as the CEL code. I removed it quickly and went back to MBC, but that pesky CEL always came back.
4) When your tuner sends you your tune file, it will include a CEL clear for that code because if not, it will keep coming back.
5) With that CEL and a second one (P0458 I BELIEVE) active, my car ran like SHIT. Even when switching back to MBC, it would not accelerate. It was just like you said, worst than stock.
6) To run higher boost, you need a tune.
Old 09-01-2013, 08:49 PM   #5
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
the tuner needs to set up maps and duty cycles with it and send you a tune
dont damage your car by trying stuff thinking its working if you plug and play
448hpsti is offline   Reply With Quote
Old 09-01-2013, 11:40 PM   #6
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
As everyone said....get a tune. It may plug...but its not play without it.
gdrider77 is offline   Reply With Quote
The Following User Says Thank You to gdrider77 For This Useful Post:
Old 09-01-2013, 11:48 PM   #7
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Is everyone using the same gasoline purge for the ebcs? How do you make sure ur gas tank doesn't pop? Vented gas cap?
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 09-02-2013, 01:05 AM   #8
Sportsguy83
Drives: Limited BRZ
I was concerned about this but read lots of info online of people doing this for years with zero ill effects.
Sorry if this posts has mistakes, I'm on the phone!
Old 09-02-2013, 01:12 AM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
What people?
Old 09-02-2013, 01:15 AM   #10
Sportsguy83
Drives: Limited BRZ
What people?
Because Racecar type of people probably.
I can't remember right now exactly where, but in different forums.
Old 09-02-2013, 02:29 AM   #11
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
So, This purge valve isn't for or near your gas tank. It's for evap emissions return to intake.
It's been done for years on many a Subie before our 86
Old 04-21-2014, 10:25 AM   #12
Jacques Blom
Turbo 86
Jacques Blom's Avatar
Drives: Toyota 86 Turbo
Sorry for my stupid question. . but how did you connect the electronic side of the grimspeed EBCS.. I need to fit my EBCS, but not use howto connect the EBCS SIDE of the controller..what plug did you use or did you cut in to the loom, , and how did you do it.
I am running a Greddy kitt.
Jacques Blom is offline   Reply With Quote
Old 04-21-2014, 12:29 PM   #13
Sportsguy83
Drives: Limited BRZ
Plug and play and it connects to this blue connector on the top left of the pic. When the manifold is installed in the car, it will be towards the back and driver's side.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Jacques Blom (04-21-2014)
Old 05-09-2014, 12:42 PM   #14
aaguirre123
Drives: sti 2012 sedan
i searched and search an finaly found it. thanks man. this is a great help. by the way, once it's unplug do you just leave it open or can it be in parallel with ebcs?
aaguirre123 is offline   Reply With Quote
