Old 06-08-2014, 02:15 AM   #2409
ft86me
ft86me's Avatar
Drives: 2013 FRS
on 18x10 -1.8 f and -1.3 r with 245 40 18. have about 2mm clerance from my kw up front. Can someone provide me with info with running either 255 or 265 all around?
Have lower lca and kwv3 and camber bolts to adjust camber.
thanks!
ft86me is offline   Reply With Quote
Old 06-08-2014, 06:44 AM   #2410
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Here's a few pics of my car at the track, with freshly mounted 255/35R18. Gained about 4 secs over my 245 Contis.
Slick is offline   Reply With Quote
Old 06-08-2014, 07:28 PM   #2411
b rawr z
b rawr z's Avatar
Drives: 2014 BRZ, 2008 Impreza
Exclamation
hi everyone. im thinking of getting 17x9 +45 with ST coilovers and ive read a bunch of post on the wheel directory but still not clear if this set up will rub or not. im planning to lower .8 to an inch. im also not sure what tire size i should get and i dont plan to camber. any advice?
i appreciate any help in advance.
b rawr z is offline   Reply With Quote
Old 06-08-2014, 09:32 PM   #2412
Slick
Slick's Avatar
From what I have seen, these will clear the strut since you're on coilovers, but might rub the tires inside on max lock.
The Following User Says Thank You to Slick For This Useful Post:
b rawr z (06-09-2014)
Old 06-09-2014, 01:51 PM   #2413
b rawr z
b rawr z's Avatar
Exclamation
Any suggestion with tire size and this setup?
Old 06-09-2014, 01:56 PM   #2414
Slick
Slick's Avatar
Something closer to a +35 to +38 offset and you could rock a 245/40R17 without issue.
The problem with the +45 is that it is tucked in a bit too much, and the tire will rub on full lock, but it's not because of the tire size it's due to the offset of the wheel.
b rawr z (06-11-2014)
Old 06-09-2014, 08:51 PM   #2415
Drewbie
Drives: 2013 Asphalt FRS 6AT
Ok so I was looking at Avant Garde M220's...
18x8 +30 on 225/40/18
Think those would work?
Thanks guys.
P.S. Planned on lowering springs, probably about 1" but wanted to wait to see the wheels on the car so I can see how much fender gap I need to take up.
Drewbie is offline   Reply With Quote
Old 06-09-2014, 11:34 PM   #2416
Lemar58
Drives: Scion FR-S
Wheels and tires first upgrade
Lemar58 is offline   Reply With Quote
Old 06-10-2014, 11:22 AM   #2417
Slick
Slick's Avatar
Thanks guys.
No problem with that wheel size and offset, should work well. Tire size is also good for this wheel.
Drewbie (06-10-2014)
Old 06-10-2014, 11:27 AM   #2418
Slick
Slick's Avatar
Originally Posted by Lemar58 View Post
Before I get bashed on this, I have an incredibly tough time with suspension and wheels so try to take it easy on me...
I'm lowered on eibach sportlines and I'm looking into an 18x8.75 all around +35 offset. Can anyone let me know if I'll have any issues here? The lowering springs drop me about 1.4 inches I believe.
Good size wheel, will be pretty flush without rubbing and you'll have a bit of clearance on inside to clear the spring perch as well. Pretty close to my setup actually.
Ideal tire size would be 245/35R18 or 225/40R18 if you don't want to go as wide.
Old 06-10-2014, 12:05 PM   #2419
Drewbie
Awesome! Thanks for the help bro! Now I can pull the trigger on them.
Old 06-12-2014, 04:28 PM   #2420
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Can you fit 255/35/18 at the front without any rubbing stock ride height? If not, how about 245/35/8
How much understeer can one expect from running 265 rear and 245 front on stock suspension?
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 06-12-2014, 04:53 PM   #2421
Slick
Slick's Avatar
255/35R18 is still a big tire for this car. It may fit but poke depending on your wheel setup (width and offset) and camber plays a big part in tucking in a large wheel/tire combo.
I'd stick to a 245/35R18 square setup and not worry about the understeer. Do you have power mods to warrant 265's?
Old 06-12-2014, 04:55 PM   #2422
Brody602
Drift King
Brody602's Avatar
Will this fit? (width, offset and tire size Qs)
I am planning for 400-450whp, so I want a decent size tire to hook up, was thinking of 255 square to avoid understeer, but if it doesn't fit well I may just stick with 245/35/18 square @Slick
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
