Old 06-08-2014, 01:29 PM   #1443
NCItaly
Drives: 2013 BRZ Limited
one more question, what gauges are you using? i bought a cheap GlowShift on amazon and the T fitting supplied with the restrictive fitting won't fit their own supplied hose... so i used a different T fitting and since there's no restrictor, im getting -20 to 15 PSI readings... with the C30... any suggestions?
NCItaly is offline   Reply With Quote
Old 06-08-2014, 02:11 PM   #1444
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
I get my readings directly from the OBDII port. I assume is correct because it reads directly from the ECU. Torque app with Parrot Smart HU.
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 06-08-2014, 02:48 PM   #1445
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I don't understand the need for the boost gauge since the boost is limited with pulley size you shouldn't be able to overboost or anything like in turbocharged cars, am I missing something? as opposed to turbocharged cars boost level should be pretty consistent and shouldn't be affected by the temperature etc..
as long as you are hitting the target boost (which can be seen with a simple Torque app) I think you should be fine .. if the accuracy of the boost readings via OBS is questionable, I don't know
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
Xero-Limit (06-08-2014)
Old 06-08-2014, 02:57 PM   #1446
NCItaly
Well, i'm certainly not worried about over boost, but, i've blown off hoses a few times now, and sometimes it noticeably NA-like, sometimes i get idle problems, and sometimes its just kind of okay. even though i'm almost certain i clamped every possible hose that might be a problem, i'd like to have a gauge that i don't have to worry about. I currently use the torque app with my phone, but i hate having to mess with my phone every time i get in my car and a simple gauge is cheaper than a good mount and a tablet. (plus i dont like the idea of having to look way over to get readings)
Old 06-08-2014, 03:34 PM   #1447
captain_jack
captain_jack's Avatar
Exactly just knowing there is a boost leak can save you from having bigger issues
may the schwartz be with you....
The Following User Says Thank You to captain_jack For This Useful Post:
NCItaly (06-08-2014)
Old 06-08-2014, 09:32 PM   #1448
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Wideband is a better indicator of malfunction with an SC setup. You'll immediately know if you have a major boost leak since power will be down, but you'll be able to find the smaller leaks by seeing a change in the top end AFR....those you may never feel or the SC may be able to still boost normally with.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
glamcem (06-08-2014)
Old 06-08-2014, 11:36 PM   #1449
penguin
Drives: Scion FR-S Firestorm MT
I've been getting ready for my own install and reviewing all the docs available while I wait for my package to arrive. I have been reading this thread and the amount and quality of info here is invaluable.
This caught my attention:
Did you check the tq on the crank pulley with a torque wrench? it should be 94 ft/lbs according to the service manual
I'm looking at the service manual and all I can find says that this bolt takes two turns, one at 15ft*lbs, and after that a 90 degree turn. See attachment. Am I looking in the wrong place?
penguin is offline   Reply With Quote
Old 06-08-2014, 11:38 PM   #1450
NCItaly
As I understand it, it's not so imperative as the rotation of the crank tightens that bolt anyway
Old 06-08-2014, 11:43 PM   #1451
zoth
zoth's Avatar
It is 94ft lbs. BTW there is a sticky in the DIY section that you really need to look at regarding the crank pulley.
Old 06-09-2014, 12:05 AM   #1452
penguin
Thanks. Do you happen to know where this torque number came from?
And re. the sticky, is that a concern given that the pulley is not coming out?
Old 06-09-2014, 12:33 AM   #1453
glamcem
glamcem's Avatar
you don't have to remove the crank pulley, you simply remove the bolt and keep the pulley in place then install the hub adapter
you may also use this as a reference
http://www.ft86club.com/forums/showthread.php?t=12583
Old 06-09-2014, 06:55 AM   #1454
FR-S Matt
Are you guys running 0w-20 after supercharging for your daily drive? Not looking to get into an oil debate, but just wondering if that weight will suffice for DD and a little spirited driving or should I bump up to a bit heavier weight? I've got an oil change up coming up soon.
Old 06-09-2014, 08:47 AM   #1455
zoth
zoth's Avatar
Pondering this for a bit now, I think i'll go with 10-30 on my next oil change.
Old 06-09-2014, 08:48 AM   #1456
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I did 94ft lbs and the pulley bolt fell out later that day. I went to 120 after that. And rechecked it a dozen times.
post_break is offline   Reply With Quote
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
