Xero Limit
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > DIY (Do-It-Yourself) Guides
Old 01-14-2013, 05:24 PM   #1
thejevans
Rugger Extraordinaire
thejevans's Avatar
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
DIY Warning - Removing the Crank Pulley
This warning has to do with installer error and has no bearing on the quality of any pulleys.
With removing the crank pulley, you will find this little nugget of fun. This piece is what actually seals on the front case of the engine. The crank pulley simply bolts to the face where that o-ring keeps oil from protruding out the crank bolt hole. This piece also is what drives the oil pump.
The above quote is from the Perrin blog. The part shown in the picture may come out slightly when you remove your crank pulley. If it does, it can be quite challenging to put back. It took me a little over a hour just to get it seated right. There is a keyway on the back side of it that links to a key on the oil pump. There is very little play in this connection. They must line up perfectly, or the part will not seat correctly. Pay close attention to this piece; it should be flush with the crank case. If it does not seat correctly, there will be a wobble in your crank pulley, and you may get oil leaking out. Look at it while it's idling. Is it wobbling? Cut the engine off and fix it. Don't end up a horror story.
ALWAYS CHECK YOUR WORK BEFORE TEST DRIVING.
Here, @Gopherboy6956 explains the process and the problems, in detail. I'd like to give a huge shoutout to him for great pictures, and even a video!
Originally Posted by Gopherboy6956 View Post
So - check this - I just took off my pulley today, armed with my new O-Ring. Of course, the crankshaft pulley spacer (as it's actually called) came out. I sat there for what felt like forever trying to get it back in. I eventually gave up when the cold got me (~15f).
Now, what I think may be complicating this is there is really TWO parts of this that come into play here... One is that stupid key, and the second is a moveable ring on the inside of the crank tunnel.
See photos -
In this image, you can clearly see the key on the end of the crankshaft. (red arrow)
The Yellow call-outs and arrows point to the two side keys, WHICH are on a ring that rotates freely. So, you need to have both those items lined up to get it back in.
This is the backside of the crankshaft pulley spacer
So, If you only get it seated with the outside ring, it won't slide in flush as seen in this DIY:
Also - take note, as Perrin says if you don't get it flush in there, the pulley will wobble. When i put it back in this time after changing the o-ring, I did not have it flush and it did wobble for a few seconds.
Now, I'm not sure if this is going to be an issue for me yet, but it seems it could be easy to damage the spacer and/or crankshaft key.
This is what my spacer currently looks like which has me a bit concerned:
It looks like a bit was sheared off when the engine started and the pulley was wobbling.
And a closer look at my crankshaft might show a little damage too
This makes me a bit nervous - but I'm going to order a new spacer and maybe play with it some more before I do anything drastic.
So - Let this be a strong warning to all - MAKE SURE YOU GET THE SPACER FLUSH before you start the engine.
OK!
6 hours, a sore back, lots of curse words, loss of hope, and a 15F degree garage, I got it!
I was so frustrated, and actually just gave up. I was going to get the BRZ towed to the dealership tomorrow and bite the bullet. I figured they may take pity on me, so I went about putting both the intake and pulley back to stock.
I took the stock pulley, put the new o-ring in place, attached it to the Crankshaft pulley spacer, lined it up as close as I possibly could to where I knew the key was (I used a mirror and light to better see inside) and gave her hell.
Just as with the Perrin Pulley, it went in, but not all the way. So, i decided i'd bolt it down anyways, got it to 94ft/lbs, and started to put the stock intake back on.
After that, i gave it one more cautious start, and to my *fucking* surprise, it ran WITH NO WOBBLE, absolutely perfect.
So, I cursed with joy and sorrow for time spent, and decided to take one more shot at the Perrin pulley, now that I knew the spacer was seated correctly.
So, here is the part, that should be included in the DIY to keep that spacer seated:
When removing the stock pulley, wedge a socket extension (or two) into the bolt hole to keep pressure on the spacer in place. It would be much easier with a friend, but it's possible to keep pressure on the socket extension and pull off the stock pulley at the same time. I can take a shot of this just to make it easy to see tomorrow.
It worked like a charm, and here is my spacer completely in place.
And a reminder of when it is NOT in place:
Also, here is a quick clip of my Perrin Pulley after this project:
http://www.youtube.com/watch?v=AJD-u...ature=youtu.be
Hope this info helps someone.
thejevans is offline   Reply With Quote
The Following 26 Users Say Thank You to thejevans For This Useful Post:
Black Tire (05-05-2013), BLACK->BULLET (06-02-2015), brybot (01-03-2017), Caspian (08-31-2015), CBR600RR (04-02-2013), Choco (01-21-2015), ChrisD (01-27-2016), Dadhawk (02-14-2013), echo419 (12-09-2014), Efferalgan (08-30-2013), finch1750 (09-23-2013), GhostOp86 (04-13-2015), Gixxersixxerman (01-14-2013), hyper4mance (04-02-2013), Jesse (04-01-2013), JPxM0Dz (03-26-2013), kykiee (02-14-2013), LeeMaster (02-27-2013), Mike86 (08-30-2013), ProjectD (01-15-2013), so26 (01-14-2013), tbwoodlee (01-15-2013), TRD_07 (04-02-2013), Tristor (08-26-2018), whataboutbob (01-14-2013), Wolfking (09-18-2013)
Old 01-14-2013, 05:33 PM   #2
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
This should be stickied with all the recent threads that are having issues
Gixxersixxerman is offline   Reply With Quote
Old 02-14-2013, 02:23 PM   #3
kykiee
kykiee's Avatar
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
This should get a bump and stickied
2013 Subaru BRZ Limited - GBS - 6MT - VIN #01197
kykiee is offline   Reply With Quote
Old 02-14-2013, 02:51 PM   #4
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
& it is sticky now
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
86kahl (06-04-2016), thejevans (02-14-2013)
Old 03-26-2013, 11:57 AM   #5
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
I ran into this issue when installing mine this weekend. The Oring came off with the old pulley. I tried to place it back in, but it was ever so slightly bigger than the area for it. So, i ordered a new one for about $2.
Found here:
http://wardmuscatellsubaruparts.com/...iagram=7610205
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
microbionic (03-26-2013)
Old 03-30-2013, 10:25 AM   #6
Yruyur
Yruyur's Avatar
So I put my pulley on yesterday on my replacement frs so this is my second install. When taking the bolt out I actually got some oil that came out that I don't remember having the first time around. This sleeve stayed in as far as I can tell. Now you got me worried. I need to double check. Anyone have a pic of how fush the stock one sits in the block? Is it just pressed in?
Old 03-30-2013, 05:44 PM   #7
White64Goat
A picture of the backside of that little nugget might be helpful......so people know what the key-way mate up would be.
Old 04-01-2013, 12:18 AM   #8
thejevans
thejevans's Avatar
From what I remember, when seated correctly, it is almost exactly flush. The pulley will most likely wobble if it is seated incorrectly.
1994 Plymouth Acclaim - Engine died and went to cash for clunkers
2001 Dodge Neon R/T- Hydro-locked engine and parted out
2003 Nissan Sentra SE-R Spec-V - Traded for next car
2013 Scion FR-S - Got taken out by a distracted driver while I was sleeping. Total loss.
1997 Mazda Miata - Current
Old 04-01-2013, 12:22 AM   #9
Gopherboy6956
Yep, exactly.
When first took off the stock pulley, the end of the crank stayed in, but then when I took it apart a second time (because i forgot the oring, that end piece came out. Pretty easy to slide it back in, and yes, there will be a little oil, that's normal. It won't gush out or anything.
Old 04-01-2013, 07:58 PM   #10
Gopherboy6956
See photos -
I'd like to do a quick callout to @thejevans and @PERRIN and see what they think, and specifically to thejevans - how did you get it realigned?
The Following 3 Users Say Thank You to Gopherboy6956 For This Useful Post:
Jesse (04-01-2013), Mr. (04-22-2013), thejevans (04-02-2013)
Old 04-02-2013, 01:27 AM   #11
Gopherboy6956
OK!
Here is the part, that should be included in the DIY to keep that spacer seated:
Here are two photos of how I used the socket to keep the spacer in - The bolt is obviously in place, I just wanted to show how I used the socket extension.
Here is my spacer completely in place.
The Following 9 Users Say Thank You to Gopherboy6956 For This Useful Post:
Black Tire (05-05-2013), brybot (01-03-2017), ExquisiteStance (07-22-2014), fstlane (09-01-2013), GhostOp86 (04-13-2015), MJones_RB (11-16-2016), Mr. (04-22-2013), thejevans (04-02-2013), Yruyur (04-02-2013)
Old 04-02-2013, 02:34 AM   #12
Yruyur
Yruyur's Avatar
Fantastic. Thank you
Old 04-02-2013, 09:14 AM   #13
thejevans
thejevans's Avatar
I'd like to do a quick callout to thejevans and PERRIN and see what they think, and specifically to thejevans - how did you get it realigned?
I got it back with lots of luck, and patience. The tolerance for that keyway is so low, that it's almost maddening. I actually filed down the outside corners of the keyway, slightly, to give the key room to slide in.
Thank you so much for your pictures and information. I'm glad you got it back in. I'm going to update the first post with quotes from yours.
Old 04-02-2013, 09:54 AM   #14
Gopherboy6956
That is funny... I actually filed down my edges as well!
Search this Thread:
Advanced Search
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 07:45 PM
Kartboy crank pulley Turn in Concepts Engine, Exhaust, Bolt-Ons 5 05-22-2013 10:51 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
