#1443 |
Drives: 2013 BRZ Limited
one more question, what gauges are you using? i bought a cheap GlowShift on amazon and the T fitting supplied with the restrictive fitting won't fit their own supplied hose... so i used a different T fitting and since there's no restrictor, im getting -20 to 15 PSI readings... with the C30... any suggestions?
#1444 | |
Drives: 2013 BRZ Premium Dark Gray Metallic
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
#1445 |
Drives: 2022 BRZ Limited
I don't understand the need for the boost gauge
since the boost is limited with pulley size you shouldn't be able to overboost or anything like in turbocharged cars, am I missing something? as opposed to turbocharged cars boost level should be pretty consistent and shouldn't be affected by the temperature etc..as long as you are hitting the target boost (which can be seen with a simple Torque app) I think you should be fine .. if the accuracy of the boost readings via OBS is questionable, I don't know
| The Following User Says Thank You to glamcem For This Useful Post: | Xero-Limit (06-08-2014) |
#1446 | |
#1447 |
Exactly just knowing there is a boost leak can save you from having bigger issues
may the schwartz be with you.... |
| The Following User Says Thank You to captain_jack For This Useful Post: | NCItaly (06-08-2014) |
#1448 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Wideband is a better indicator of malfunction with an SC setup. You'll immediately know if you have a major boost leak since power will be down, but you'll be able to find the smaller leaks by seeing a change in the top end AFR....those you may never feel or the SC may be able to still boost normally with.
| The Following User Says Thank You to Xero-Limit For This Useful Post: | glamcem (06-09-2014) |
#1449 |
Drives: Scion FR-S Firestorm MT
I've been getting ready for my own install and reviewing all the docs available while I wait for my package to arrive. I have been reading this thread and the amount and quality of info here is invaluable.
This caught my attention: I'm looking at the service manual and all I can find says that this bolt takes two turns, one at 15ft*lbs, and after that a 90 degree turn. See attachment. Am I looking in the wrong place? |
#1450 |
As I understand it, it's not so imperative as the rotation of the crank tightens that bolt anyway
Sent from my SAMSUNG-SGH-I337 using Tapatalk |
#1451 | |
#1452 | |
And re. the sticky, is that a concern given that the pulley is not coming out? |
#1453 | |
you may also use this as a reference http://www.ft86club.com/forums/showthread.php?t=12583
#1454 |
Are you guys running 0w-20 after supercharging for your daily drive? Not looking to get into an oil debate, but just wondering if that weight will suffice for DD and a little spirited driving or should I bump up to a bit heavier weight? I've got an oil change up coming up soon.
#1455 | |
#1456 |
Professional Smartass
Drives: White Out FRS
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
