Old 06-04-2014, 09:06 AM   #1
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Recommended cold tire pressure for PSS
First HDPE this Friday - anyone have a good recommendation for a cold psi starring point? 245/40/17's.
Thanks!
1Cor10:23 is offline   Reply With Quote
Old 06-04-2014, 09:31 AM   #2
dp1
driving smoother faster
Drives: Sold
Depending on how hard you drive them (apparently they get greasy if you slide around a lot), you will gain 5+ PSI as they heat up. You want them somewhere around 35-38 PSI hot, so you can try 30 PSI cold and measure/adjust after each session. Your speed, driving style and track layout may affect each tire differently, so best to measure and adjust hot soon after you get off track. I only use them on the street at about 33 PSI cold so others may advise you better for track use. Your camber and toe will impact this also. Pyrometer would help to measure temps across contact surface. Somebody near you may have one and likely won't mind if you borrow.
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
1Cor10:23 (06-04-2014)
Old 06-04-2014, 10:16 AM   #3
ddeflyer
Thanks!
The rate that tires heat up can vary alot based upon the driver. Until you get to know how much you heat up the tires, it is better to only take a couple of pounds out at a time and check the pressure after every session. Whatever you do, DON'T go and drop them down into the 20s for your first session.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
The Following User Says Thank You to ddeflyer For This Useful Post:
Old 06-04-2014, 10:24 AM   #4
1Cor10:23
1Cor10:23's Avatar
Thanks for the suggestions guys! Currently sitting on 31.5 Cold. Might top off to 33 before heading there Friday.
Tire Pressure for PSS? Pacific Auto Tracking / Autocross / HPDE / Drifting 12 01-22-2014 10:50 PM
Recommended tire pressure for Thunderhill I<3Twisties Tracking / Autocross / HPDE / Drifting 3 12-20-2013 01:50 AM
tire pressure mrnibbs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-18-2013 10:09 AM
Tire Pressure Fallen43 CANADA 2 10-12-2013 12:46 PM
Recommended Tire Pressure for Aftermarket Wheels and Tires Chri5 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-15-2013 01:28 PM
