CANADA Canada
Old 10-11-2013, 11:04 PM   #1
Fallen43
Drives: Sliver FRS done the way I like it
Tire Pressure
What pressure you guys run ur street tires and track tires at ? .
Fallen43 is offline   Reply With Quote
Old 10-12-2013, 10:43 AM   #2
Zook@SimplyTire
Zook@SimplyTire's Avatar
Drives: 996 C4S
Street Tires always use Factory Reccomended unless Diffrent Size, then you need to play around to your Comfort Level.
Track Pressure really depends on your Tire, Condition, Alignment Spec, Driving Style and Track .
With Toyo R888's on my Porsche around Mosport the sweet spot is 32-34 PSI heat dependent. If Michilen PS Cups like 30ish. however Pirelli Trofeo's require more camber and lower pressure around 29psi and Trofeo R's like 27psi. These are Hot Temps
Whats your Track Set-Up?
Zook@SimplyTire is offline   Reply With Quote
Old 10-12-2013, 12:46 PM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
the stock Michelins seem to respond well when set at around 35psi cold, this is for both autocross and track
if you're gonna be on the track, don't stay out too long and bleed off pressure if you start going over 39 hot
Have a tire pressure gauge you really like? Anthony Tracking / Autocross / HPDE / Drifting 21 09-10-2013 06:09 PM
what is your tire pressure? abling2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-03-2013 10:49 AM
What Hot Tire Pressure? gbgracer Tracking / Autocross / HPDE / Drifting 24 05-14-2013 05:47 AM
Autocross Tire Pressure on ZII's Areddi Tracking / Autocross / HPDE / Drifting 6 04-12-2013 08:37 PM
BEST TIRE PRESSURE TO RUN TRACK karma003 Tracking / Autocross / HPDE / Drifting 13 10-24-2012 05:32 PM
