Drives: 2022 BRZ Limited
Save your money and effort on the secondary catch can since I have been using it for the last couple track events and not a single drop of oil collected, and that's with a Supercharger kit !!! I also have to say, I don't baby my car
somehow I managed to destroy my gaskets and bolts on my CBE at the last event but still not a single drop on the breather side catch can ..FYI they are both baffled![]() ![]() PCV side on the other hand is a must even for NA cars ..see below to see how much oil I collected after a single event ![]()
| The Following User Says Thank You to glamcem For This Useful Post: | charged86 (06-20-2014) |
#2 |
It's highly dependent on the motor, some motors seal very well and while others have enough blowby and pressure that the breather line is heavily utilized, I have seen several people on here having to clean out the intercoolers already.
| The Following User Says Thank You to Dezoris For This Useful Post: | DAEMANO (12-18-2014) |
#3 |
Drives: FRS(sold), AP2, R35, FJC, ED9
can you clarify which one is breather and which is your pvc in your last picture?
#4 |
interesting maybe with higher power /turbo but in my case it was definitely worthless..Have you checked yours and seen any oil buildup ?
#5 |
the one on the left is PCV side and the other one is breather side
| The Following User Says Thank You to glamcem For This Useful Post: | garfull (06-03-2014) |
#6 |
Drives: FR-S Whiteout
Those are nice little catch cans. I have one in black. Are you running a element in the little baffle chamber? I may have to add one as the return tube to the mani on mine had a bit of oil residue in it.
#7 |
#8 |
Drives: 2016 STi DGM
shitty ass gaskets...
-2014 SSM BRZ MT
| The Following User Says Thank You to ramiram1984 For This Useful Post: | glamcem (06-03-2014) |
#9 |
This depends on a lot of factors on a NA car I probably wouldn't even consider one. It's not going to do one. But I had my front hose disconnected on the dyno one day and you could clearly see smoke coming out of mine. Mind you I am on a built engine with boost.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#10 |
Run vent to atmosphere with no filters and run the tubes behind the car. Your rear vehicle driver will appreciate it.
| The Following User Says Thank You to FR-S Matt For This Useful Post: | nelsmar (06-03-2014) |
#11 | |
This was found in the oil catch can after around 1500-2000 miles of street driving, mostly just putting around. ![]() Oil catch can is a good investment even if you are completely stock IMHO. |
#12 |
interesting, I will check mine too ..maybe I should put some scrubbers in the chamber
#13 | |
![]() again, I have been boosting for a while with track use still not a single drop..maybe at those power levels (that I see in your signature), have you been running the catch can since you saw this smoke?
#14 | |
Drives: 86
This is after 4 track days and aprox 5k miles of daily driving. I don't quite understand how some of you are getting sooooooo much blowby. |
| Radium Engineering Catch Cans | FRS2000 | Engine, Exhaust, Transmission | 111 | 03-02-2016 01:49 AM |
| Catch cans: what are you running? | Apex Chase | Engine, Exhaust, Transmission | 144 | 08-14-2014 08:17 AM |
| Radium or Crawford catch cans/AOS | diss7 | Forced Induction | 16 | 02-18-2014 08:50 AM |
| Catch Can breather line question | protpibe | Engine, Exhaust, Transmission | 1 | 01-18-2014 04:20 PM |
| cusco catch cans difference | Silverdub | Engine, Exhaust, Transmission | 15 | 04-23-2013 10:17 AM |
