Old 06-03-2014, 02:48 PM   #1
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Wink Save your money on the Breather tube catch CANS..They are pretty much worthless!!
Save your money and effort on the secondary catch can since I have been using it for the last couple track events and not a single drop of oil collected, and that's with a Supercharger kit !!! I also have to say, I don't baby my car somehow I managed to destroy my gaskets and bolts on my CBE at the last event but still not a single drop on the breather side catch can ..FYI they are both baffled
PCV side on the other hand is a must even for NA cars ..see below to see how much oil I collected after a single event
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
charged86 (06-20-2014)
Old 06-03-2014, 03:02 PM   #2
Dezoris
Dezoris's Avatar
It's highly dependent on the motor, some motors seal very well and while others have enough blowby and pressure that the breather line is heavily utilized, I have seen several people on here having to clean out the intercoolers already.
The Following User Says Thank You to Dezoris For This Useful Post:
DAEMANO (12-18-2014)
Old 06-03-2014, 03:08 PM   #3
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
can you clarify which one is breather and which is your pvc in your last picture?
garfull is offline   Reply With Quote
Old 06-03-2014, 03:08 PM   #4
glamcem
glamcem's Avatar
interesting maybe with higher power /turbo but in my case it was definitely worthless..Have you checked yours and seen any oil buildup ?
Old 06-03-2014, 03:09 PM   #5
glamcem
glamcem's Avatar
the one on the left is PCV side and the other one is breather side
garfull (06-03-2014)
Old 06-03-2014, 03:27 PM   #6
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Those are nice little catch cans. I have one in black. Are you running a element in the little baffle chamber? I may have to add one as the return tube to the mani on mine had a bit of oil residue in it.
Old 06-03-2014, 03:29 PM   #7
garfull
garfull's Avatar
one more question.
there are two connections there, are you splicing into the left, right or both.
Old 06-03-2014, 03:48 PM   #8
ramiram1984
Drives: 2016 STi DGM
shitty ass gaskets...
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
The Following User Says Thank You to ramiram1984 For This Useful Post:
glamcem (06-03-2014)
Old 06-03-2014, 04:20 PM   #9
nelsmar
This depends on a lot of factors on a NA car I probably wouldn't even consider one. It's not going to do one. But I had my front hose disconnected on the dyno one day and you could clearly see smoke coming out of mine. Mind you I am on a built engine with boost.
My flickr - Canibeat
Local magazine scout
Old 06-03-2014, 05:04 PM   #10
FR-S Matt
Run vent to atmosphere with no filters and run the tubes behind the car. Your rear vehicle driver will appreciate it.
The Following User Says Thank You to FR-S Matt For This Useful Post:
nelsmar (06-03-2014)
Old 06-03-2014, 05:39 PM   #11
solidONE
solidONE's Avatar
My car is currently factory stock in terms of engine performance related hardware save for the drop in air filter.
This was found in the oil catch can after around 1500-2000 miles of street driving, mostly just putting around.
Oil catch can is a good investment even if you are completely stock IMHO.
The Following 3 Users Say Thank You to solidONE For This Useful Post:
ATL BRZ (06-18-2014), DAEMANO (12-18-2014), glamcem (06-03-2014)
Old 06-03-2014, 05:56 PM   #12
glamcem
glamcem's Avatar
interesting, I will check mine too ..maybe I should put some scrubbers in the chamber
Old 06-03-2014, 06:01 PM   #13
glamcem
glamcem's Avatar
one more question.
I am not sure I am following you
again, I have been boosting for a while with track use still not a single drop..maybe at those power levels (that I see in your signature), have you been running the catch can since you saw this smoke?
Old 06-03-2014, 06:11 PM   #14
TemeCal
Drives: 86
Isn't there cause for concern with the high amount of blowby some of you are getting?? I have one Radium catch can for the PCV, and one for the breather. The breather is bone dry, and the PCV only has a few drops.
This is after 4 track days and aprox 5k miles of daily driving. I don't quite understand how some of you are getting sooooooo much blowby.
TemeCal is offline   Reply With Quote
The Following 2 Users Say Thank You to TemeCal For This Useful Post:
JDKane527 (06-03-2014), tahdizzle (06-03-2014)
Radium Engineering Catch Cans FRS2000 Engine, Exhaust, Transmission 111 03-02-2016 01:49 AM
Catch cans: what are you running? Apex Chase Engine, Exhaust, Transmission 144 08-14-2014 08:17 AM
Radium or Crawford catch cans/AOS diss7 Forced Induction 16 02-18-2014 08:50 AM
Catch Can breather line question protpibe Engine, Exhaust, Transmission 1 01-18-2014 04:20 PM
cusco catch cans difference Silverdub Engine, Exhaust, Transmission 15 04-23-2013 10:17 AM
