#57 | |
/dev/null
Drives: Uphill
But, I've had wider tyres with more grip on previous cars for many years, so I bought new wheels with 225 PSS's and I like them better. It's a personal preference, nothing more. |
#58 |
Drives: Celica 5th Gen, Tiburon 04, GT86
Rainy road this morning and I pressed a little hard coming out of a round about, the back slipped quite clearly (maybe 50cm) before TCS stopped it all! Thanks god... I guess wihout TCS/ESC I might have messed that up as I'm no topnotch pilot.
#59 | |
/dev/null
Drives: Uphill
The general advice for this situation on slippery surface (wet, snow, ice) in any vehicle with 4 or more wheels, regardless of FWD/AWD/RWD and any stabilizer electronics present or not, is: 1. Release the throttle and engage the clutch (if not automatic gearbox) 2. Steer through the situation. Point the front wheels in the direction your vehicle should go, do not over compensate if front wheels are slipping. 3. If the vehicle has ABS, brakes might help. If no ABS, braking in such situation may cause loss of steering. There are more advanced and way more fun ways to handle such a situation, especially in nimble RWD cars such as ours, but those should be learned and trained for in a safe environment. |
| The Following 2 Users Say Thank You to Sarlacc For This Useful Post: | longhornjoe (05-26-2014), wheelhaus (05-26-2014) |
#60 | |
Drives: Whiteout 86 2014
#61 | |
#62 | |||
The Antiriced
Drives: women wild
Never said you said they were dangerous. Quote:
In the context I clearly stated yes the hell I can. |
#63 | |
Drives: 370z
At least on dry asphalt, lifting after you start oversteering is like the worst sin. |
#64 |
Drives: WRB Subaru BRZ
If you're oversteering (tail losing grip and coming around) by applying too much throttle for the available grip then yes back off the throttle (not abruptly if possible) and steer into the direction you want to go but I would advise against pushing in the clutch. This will give a you no drive and you're coasting which is not so bad in a slow speed corner such as a roundabout but you're going to come to a stop because the next instinctive thing for most drivers is to brake. This might be the safest thing in most situations though. Putting it back into gear by releasing the clutch will cause the driven wheels to spin and upset the car even more.
The correct way to get out of slide and not stop in slow speed oversteer situations is back off throttle, turn into direction of slide (that is point to where the road is or where you're intending on going, keep throttle steady and gently apply power again and wait. Car should straighten out and you keep going to your original path as it gathers grip at the rear. If you're oversteering because you lifted off the throttle (usually will only happen during higher speeds) then turn into slide and apply throttle. As always drive with care and learn the car on its limits and learn how to read the available grip from the road conditions. The stock tyres are pretty lacking when the roads are wet but are by no means a crappy tyre. I won't go into the religious debate about whether or not you should keep TC and VSC on but knowing how to drive without will let you learn more about a car's dynamics and make you a better driver with skills you can apply to any car. The twins are the probably one of the best cars on the market to teach you that. |
#65 |
Forgot to mention that as soon as you feel the car stop sliding out then slowly unwind the opposite lock on the steering wheel as you'll start to steer into the slide and possibly pendulum into sliding the car the opposite way and creating a tank slapper. That will depend how much throttle and steering input you used. Most starting out tend to wind on too much opposite lock. If judged well you should exit the corner pointing straight again with no fish tailing. Smooth inputs are always best obviously.
#66 |
Drives: DGM BRZ 6MT
With that much traffic, how are you even going fast enough to fish tail?
I've driven my BRZ in NYC and Toronto traffic. Grinding on first gear all day.
#67 | |
Drives: 2013 GBS BRZ Limited
Rephrase that to say: "Release the throttle very carefully - sudden lifting of throttle will induce snap in oversteer" Which BTW is exactly one of the things the "nannies" does incorrectly in this car. When the car detects wheel spin, it abruptly lifts the throttle and applies the appropriate brakes to straighten the car. When this occurs in a very low traction situation, you can easily find yourself looking at where you just came from (pointing backwards). |
#68 |
Well... all this tells me I've got to find a nice big parking on a rainy sunday to mess around on to get an idea of how this feels... in the meantime, I had a little small slide (just a little feel of rear "jumping") in 3rd coming out of a roundabout, less than first time.
#69 | |
Drives: 2013 asphalt scion FRS
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
#70 | |
/dev/null
Drives: Uphill
If you're in low gear I would agree that suddenly releasing throttle without stepping on the clutch will apply significant engine braking on the drive wheels and cause oversteer on a RWD car, or understeer on a FWD car. Therefore, clutch. |
| The Following User Says Thank You to Sarlacc For This Useful Post: | stugray (05-28-2014) |
| Losing Coolent | nabil_frs | Issues | Warranty | Recalls / TSB | 10 | 09-06-2013 01:25 AM |
| Losing Control. | Asterisked Accolade | Other Vehicles & General Automotive Discussions | 18 | 04-01-2013 11:39 PM |
| Been on a losing streak with my car lately...help | sa1126 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 04-01-2013 11:18 PM |
| I'm losing it. How did you cope? | Kyubi | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-09-2013 03:20 AM |
| Losing hvac lighting? | SemperFi | Electronics | Audio | NAV | Infotainment | 0 | 11-01-2012 01:36 PM |
