Old 05-23-2014, 08:42 PM   #15
TmP
TmP's Avatar
Drives: A bunch of 'em...
But there are 3 sizes between 225 and 255
I am basically torn between 235 and 245 on 18x9 et 25 or 35.
et 25 will need rear camber, et35 wont.
et 25 should give me more lock.
Decisions decisions...
WHAT TO DOOOO. haha
TmP is offline   Reply With Quote
Old 05-23-2014, 08:53 PM   #16
diss7
Drives: AE86, 2x GT86, TE27
WHAT TO DOOOO. haha
Its the corner of the tyre that governs your lock.
A 245 is 20mm wider than a 225. so a 245 on a +25 will have the same inner foul point as a 225 on a +35 (ignoring profile, which makes the 245 worse)
If you are worried about lock, then tyre width is important; and the last thing you want to do is run a tyre wider than you need to.
Even your comments re offset and camber, its the same thing. It depends on the tyre size as well.
I should probably add that I despise the notion of using camber to fit wheels and tyres. Camber is there to provide grip while the car experiences roll. Using camber for anything other than that is a fail IMO.
diss7 is offline   Reply With Quote
Old 05-23-2014, 08:56 PM   #17
TmP
TmP's Avatar
Well, seeing how you are one of 5 actual drifters on this board, maybe you are right. LOL
Are you positive 225s stretched on a 9" wheel don't suck for turn in response and lateral grip?
The last thing I want is to run stretched just because it's JDM tyte yo, without a proper reason...
So if you were to buy wheels again. Would you do 25 or 35 et, considering that this is a drift car with Megan rack ends?
Old 05-23-2014, 09:08 PM   #18
diss7
18x9 + 35 and a 225/40 is the best compromise for looks, inner and outer clearance, and grip. Seriously, you dont need any more tyre than that, and all its going to do is limiit your lock.
I actually think the 225 is too wide, Lol.
Im looking at step down to 16x8.5 +13, with a 205/45/16 tyre. I use 205's on the front for drifting and they're plenty grippy. Note the tyre, narrow, and not very tall. That means more lock before fouling. And the outside corner point just dips in similar to the meaty tyre thread max fitment which is 265/35/18 on a 9.5 + 38. Here, this might make it more obvious what I'm doing. See, it'll look stanced out, but check out the inner clearance and inner tyre corner (fouling) point. Also its way shorterso more lock before it fouls internally, and it'll also be much further from the inner fender, even with much more castor.
http://www.willtheyfit.com/index.php...et2=13#content
This dude here has a very similar setup to what I want to do. The front looks sick IMO, and gives maximum consideration to lock.
I dont like the rear on this pic, think its one step too far. I'l run 16x8.5 +13 all round. This pic has an even more aggressive rear fitment.
But the 16's make the car uber low. Which is the compromise I'll be making from the 18" setup I'm recommended (and running currently) above. (225/40/18)
Old 05-23-2014, 09:09 PM   #19
CSG David
CSG David's Avatar
225 to 255 will work. You won't have much clearance issue with the right setup.
@diss7 has a good setup and works very well too. It's all about what you want. 245 would "look" good on it. If you want the herrafrush setup, then you'll probably run a 205.
Old 05-23-2014, 09:10 PM   #20
TmP
TmP's Avatar
16x8.5 et13 sounds like yummy lip!!!
Pics?
You may change my wheel choice entirely. lol
Old 05-23-2014, 09:12 PM   #21
TmP
TmP's Avatar
My heart just likes the 245s. LOL
But I don't want to sacrifce lock, so maybe et 25 with 235s?
GAH. First word problems, I'm telling you...
What kind of wheels should I put on my 7th car to burn up for fun. LOOL
Old 05-23-2014, 09:14 PM   #22
TmP
TmP's Avatar
I would have pictured a loooot more lip on a 16x8.5 with ath little ET. Meh. LOL
Can't argue the lock topic though.
Old 05-23-2014, 09:15 PM   #23
CSG David
CSG David's Avatar
You won't sacrifice lock...
Old 05-23-2014, 09:17 PM   #24
TmP
TmP's Avatar
FOUR INCH LIP. drool
http://shop.klutchrepublik.com/colle...cts/sl1-silver
Old 05-23-2014, 09:21 PM   #25
diss7
He will, as he's running new tie rods that give the car more lock.
My 225's rub on the swaybar, but still give decent lock up until that point. 235's will rub sooner, so less lock. Ditto 245, ditoo 255.
Old 05-23-2014, 09:22 PM   #26
TmP
TmP's Avatar
Dude - 215 40 16 on 16x9 et 20 FOUR inch lip
Mind = blown
Old 05-23-2014, 09:26 PM   #27
diss7
Mind = blown
But see, as a drifter you have to factor another thing in, tyre size/cost. 205/45/16 there are a few cheap tyres in that size. 215/40/16 is an expensive size.
The difference between paing $80 a tyre and $200 a tyre adds up quick!
Old 05-23-2014, 09:27 PM   #28
TmP
TmP's Avatar
No shit Sherlock :P Gt Radials - 80 bucks for the 215s.
Tire size help sharris721 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-19-2014 12:03 AM
Tire size TofuAE86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-10-2014 12:03 AM
Appropriate tire size for 250-350 whp Tiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-12-2013 02:40 PM
Help with Tire Size Sivtec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-12-2013 12:40 AM
Tire Size help! J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-04-2013 12:04 PM
