CANADA Canada
Old 05-23-2014, 01:58 PM   #15
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Originally Posted by congee View Post
Is it really a big issue(besides the annoying sound) if it crickets or not?? I only use shell 91 and never had an issue with crickets. Whenever I fill up with esso or petro however, the crickets are loud AF.
Don't really feel like going to the dealer to get a replacement pump
So far crickets haven't resulted in any issues other than the sound. I would strongly encourage everyone in canada to run Ultra 94 if you want a solid 1 IAM.
1Cor10:23 is offline   Reply With Quote
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
Migero86 (05-23-2014)
Old 05-23-2014, 02:13 PM   #16
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
How many batches of Shell 91 did you run, and if so, from the same location?
I was planning on doing this evaluation on my own with summer gas. Are you using Torque (or similar) or OFT?
drewbot is offline   Reply With Quote
Old 05-23-2014, 02:17 PM   #17
mabviper
Drives: WRB BRZ
What is IAM? o.o intake air manifold?
I've been getting my gas from Major Mac and Jane. That's when I notice the crickets. I guess I'll change stations for a while.
Sent from my Nexus 4 using Tapatalk
mabviper is offline   Reply With Quote
Old 05-23-2014, 02:22 PM   #18
1Cor10:23
1Cor10:23's Avatar
Used OFT - I typically fill at either valleymede & 7 or 16 & leslie when I was running v-power. Some batches were definitely worse than others. You could audibly hear the tip-in knock sometimes on high load in the 2k-3k rpm range. Ran v-power for more than half a year before logging revealed the sub-optimal performance.
Gotta remember that the car was tuned on 93 octane from factory. When they say it will run 'fine' on 91 - likely means that ECU is smart in compensating by dropping IAM but you're leaving quite a bit of performance on the table when it dips as low as .5
Old 05-23-2014, 02:24 PM   #19
1Cor10:23
1Cor10:23's Avatar
My understanding is still minimal, if anyone sees an issue with my explanation please correct me:
IAM = Ignition Advance Multiplier. Value goes from 0-1. If you have IAM as 1, that means you get full timing as called for by the tune. IAM of 0.5 means you get half.
IAM lowers when ecu detects 'knock' (premature detonation) to compensate for lower quality fuel than expected by the tune. If you're not at 1, you're leaving quite a bit of performance on the table that you could have with higher octane.
Hope this helps.
Old 05-23-2014, 02:33 PM   #20
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
But I don't want to run ethanol into the fuel system. Are you guys strictly pumping off the dedicated V-Power pump and not the mix one?
I can only hear crickets on idle after a drive (at the light or when I'm parked). No crickets on startup since it's running only on port injection.
Other direct injection cars have this sound so I'm used to it, albeit not as loud (my old car had a Hitachi HPFP and direct injection, could only hear it with the hood opened). Who makes ours Denso?
krayzie is offline   Reply With Quote
Old 05-23-2014, 02:43 PM   #21
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
I run Shell V Power on my cars and have so since my first vehicle. I have crickets and do not change. If you think about it's actually quite funny.
AVodka14 is offline   Reply With Quote
Old 05-23-2014, 02:51 PM   #22
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
I rarely see the dedicated V-Power pumps anymore. Where I fill up regularly, it's only one pump for all grades.
What I try to do is line up behind a BMW/Audi/MB (since there are so many of them) since I know 99% of the time they are filling up on 91
Old 05-23-2014, 02:58 PM   #23
mashal
DADA
mashal's Avatar
Drives: 2013
The pumps at shell , especially the new ones are designed to dry out the hose after every fill, the only residue maybe on the tip .. My uncle owns a few shells I have seen the engineering drawings
mashal is offline   Reply With Quote
The Following User Says Thank You to mashal For This Useful Post:
drewbot (05-23-2014)
Old 05-23-2014, 03:10 PM   #24
Migero86
Migero86's Avatar
Drives: 2015 Trailhawk
Giggity Giggity....
Migero86 is offline   Reply With Quote
The Following 4 Users Say Thank You to Migero86 For This Useful Post:
D_Thissen (05-23-2014), FJ/BRZ (05-26-2014), mashal (05-23-2014), roddy (05-27-2014)
Old 05-23-2014, 03:23 PM   #25
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
That's how you get your GF pregnant yo
The Following 3 Users Say Thank You to drewbot For This Useful Post:
FJ/BRZ (05-26-2014), mashal (05-24-2014), Migero86 (05-23-2014)
Old 05-23-2014, 04:45 PM   #26
PMPB
Drives: BRZ Sport-tech
I fill up at the same Shell every time, and obviously V-Power from a mix-pump (no dedicated V-powers around my area). Chirps are intermittent, but especially noticeable after the car has warmed up, and only when the car is stopped at idle engine speed. Can *barely* hear them with the windows up.
PMPB is offline   Reply With Quote
Old 05-23-2014, 05:22 PM   #27
krayzie
Drive From Home
krayzie's Avatar
There are V-Power dedicated pumps at Shell Kennedy & Passmore.
I think using the mix pump could be the culprit.
Old 05-26-2014, 01:36 PM   #28
Choco
Embarrassed Doge
Choco's Avatar
Drives: Shibaru BRZ
I have been using mostly v power for nearly almost 2 years of my BRZ ownership. Still chirps.
Recommendations for Car Wash? Esso, Petro, Shell? LDN2012 CANADA 45 06-23-2014 04:06 PM
Shell 92 Octane Bonner Southern California 1 11-18-2013 09:32 PM
WTB: FRS or BRZ shell in any condition Guildjs Want-To-Buy Requests 0 10-01-2013 07:33 AM
which is better to use Shell 91 or PetroCanada 94? chenshuo CANADA 90 03-05-2013 09:17 PM
Petrocanada 94 or shell 91? QC-FRS CANADA 24 06-18-2012 04:55 PM
