Old 05-20-2014, 04:09 PM   #15
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
People have answered your question.
If you aren't throwing a CEL and you don't hear/notice any strange behavior in your car, then I wouldn't worry.
Old 05-20-2014, 04:12 PM   #16
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Originally Posted by J_kennington View Post
that's ALOT of black making it through in my eyes.
husker741 is offline   Reply With Quote
The Following 4 Users Say Thank You to husker741 For This Useful Post:
clayrush (05-20-2014), Pseud0logik (05-21-2014), tahdizzle (05-20-2014), Xinshadow (05-21-2014)
Old 05-20-2014, 04:24 PM   #17
eighty666
Go wipe your finger across any exhaust pipe on any car parked on the street. your finger will be black. thats just how it goes
eighty666 is offline   Reply With Quote
Old 05-20-2014, 04:24 PM   #18
tahdizzle
So elite I'm 1338
Pervert
Old 05-20-2014, 04:28 PM   #19
eighty666
Originally Posted by tahdizzle View Post
Pervert
Only if you fist it
Old 05-20-2014, 04:34 PM   #20
mid_life_crisis
Drives: FR-S 10 #103 AT
If it got that dark that fast, you should monitor your AFR just as a check. You are probably running pig rich. I have 10,000 miles on my car and not a spec of soot that you can see without getting down behind the car to check specifically for it.
My old Speed3, now that had a black exhaust tip, but that was because
factory turbo = pig rich mixture.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 05-20-2014, 04:51 PM   #21
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
It's likely just the way the exhaust tips are shaped. My Perrin exhaust makes even a tiny bit of "soot" very obvious on the large smooth surface compared to the stock tips which have lots of edges to catch and hide it.
Old 05-20-2014, 05:01 PM   #22
Tainen
Drives: First SWP BRZ-L
As Mid_Life_Crisis stated, AFR plays a role. Additionally, be aware that the stock tune is pig-rich, so in stock form this is pretty common. A tune actually would reduce the soot levels some Neutron256 also makes a valid point too. Tip shape might have impact.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 05-20-2014, 05:13 PM   #23
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
so I put a nameless axle back on my car with 4" tips. After ~week of driving the tips are covered in black soot.
My two cents:
I put JDM GT86 tips on my stock exhaust. Black "soot" more visible without change in driving style.
My conclusion: when you mod the car, you notice these small things more. I went back and looked at my stock tips, and lo and behold... they're pretty damn dark too!
I just never noticed with a stock exhaust because I wasn't bothering to look.
-alex
Old 05-21-2014, 01:07 PM   #24
2pt5RS
Berz
2pt5RS is offline   Reply With Quote
Old 05-21-2014, 09:40 PM   #25
steve99
Drives: FT86
Pretty sure you all took it way out of context. I'm not saying a motor should never create any. I'm saying I don't believe a stock motor with stock exhaust should create enough to turn 4" tips completely black in a weeks time. If I had no mufflers, no resonators, and no cats. I could understand a good bit being produced out the tip. But with 2 cats, resonators and 2 mufflers, that's ALOT of black making it through in my eyes.
It happens on stock car as well
Depends on yur driving and if its all city stuff you tend to get more soot , lot of freeway driving and it will be less
As others have said tip design can make a difference larger tips run cooler and accumulate more soot you can see
Fuel also makes a difference 10 percent ethanol fuels produce less soot nad emmissions as the ethanol aids combustion.
Run E85 with appropiate tune and there will be no soot at all perfectly clean :-)
These cars being sports cars are generally tuned a bit richer than your family ecno box so you will often see more soot on sports cars
J_kennington (05-22-2014)
List of dB levels for aftermarket exhausts. l0aded Engine, Exhaust, Transmission 22 07-01-2022 04:51 PM
Does TRD diffuser work with aftermarket exhausts? sittinSideways Cosmetic Modification (Interior/Exterior/Lighting) 10 05-16-2013 12:58 AM
Black Stealth Exhausts Cjymiller Engine, Exhaust, Transmission 7 05-07-2013 10:25 PM
Water with black soot in exhaust KamalT Engine, Exhaust, Transmission 17 01-08-2013 09:28 AM
Aftermarket Exhausts? devinclfalcons Engine, Exhaust, Transmission 309 10-18-2012 02:07 AM
