Old 05-31-2013, 05:17 PM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
List of dB levels for aftermarket exhausts.
I got an idea when I was measuring the effect of sound deadening on my car. Using your Android or iPhone you can measure the dB levels so can we have people with different exhaust and stock exhausts measure the loudness at different RPMs so people can have an idea of how loud each exhaust is? Of course parameters need to be controlled so..
- Top of phone under the shift knob at neutral
- Car must be warmed up
- Test must be done outdoors (driveway is fine)
- No sound deadening
- Radio off, Fan/AC off
- Measure dB level @ idle (650rpm), 5000rpm, and 7000rpm.
- Other mods?
- What phone?
It should look something this for example (for me):
Exhaust: Tsudo Headerback Exhaust
Other Mods: Unichip tune, Injen intake
Phone: Samsung Galaxy S3
Idle: ##dB
@5000rpm: ##dB
@7000rpm: ##dB
I have sound deadening so my measurement wouldn't be accurate but I'll do it after work anyways.
Android app (free):https://play.google.com/store/apps/d...51bGwsMSwyLDNd
This is mostly for interior cabin noise as that is what most people would care about.
l0aded is offline   Reply With Quote
Old 05-31-2013, 05:20 PM   #2
l0aded
Addicted
l0aded's Avatar
Reserved for list if this takes off.
Old 05-31-2013, 05:25 PM   #3
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
My SRT headerback measure 89dB when I got it checked for autox rules. Will check cabin dB with app if people actually care
Out of the FRS game
Mr.Jay is offline   Reply With Quote
The Following User Says Thank You to Mr.Jay For This Useful Post:
l0aded (05-31-2013)
Old 05-31-2013, 05:28 PM   #4
mad_sb
It's also going to matter if the measurement is done in a garage or wide open space... I will get these for my nameless catted front / over pipe and nameless 3" axleback.
Might also want to add the first 30 seconds from a cold start routine since that is BY FAR the loudest time other than wot. Also windows up or down?
Old 05-31-2013, 05:36 PM   #5
l0aded
Addicted
l0aded's Avatar
I'll add that to the list, has to be outdoors. I'm sure the outside environment won't affect the interior cabin noise too much so any outdoor is fine.
Old 05-31-2013, 05:47 PM   #6
SuiSid3l
Drives: 2013 Scion FR-S Whiteout White
Ptuning exhaust will be here next week, get those numbers in as soon as its on if no one else has.
SuiSid3l is offline   Reply With Quote
Old 05-31-2013, 05:47 PM   #7
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Exhaust: Buddy Club Spec II (without silencer installed)
Other Mods: Injen intake
Tested by: SPL Meter at autocross event.
Idle: unknown
@5000rpm: unknown
WOT, 6800rpm: 95.8db @ 100ft
Scott
naikaidriver is offline   Reply With Quote
Old 05-31-2013, 06:06 PM   #8
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Idle: unknown
@5000rpm: unknown
Scott
I feel like I'm above 98 with a decatted front pipe
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
TAP Auto Parts (05-31-2013)
Old 05-31-2013, 06:09 PM   #9
naikaidriver
You likely are.
I'm curious what our cars would sound like with decatted front pipe, over pipe and EL header. I think deafening would be a good word.
Scott
The Following User Says Thank You to naikaidriver For This Useful Post:
Old 05-31-2013, 09:42 PM   #10
TAP Auto Parts
Drives: FRS
LOL Awesome would be a good word too!
TAP Auto Parts is offline   Reply With Quote
Old 05-31-2013, 09:45 PM   #11
SmsAlSuwaidi
Boosted
You likely are.
Scott
well i was very close to adding a header, but ended up saving my money because I'm going FI real soon, i dislike the tip of the buddy club but I'm running it so i gotta suck it up !
can't wait till i start shooting flames from it thou
Old 06-01-2013, 06:44 PM   #12
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
This was with the windows up.
Exhaust: Nameless performance revised offset axleback and Nameless Performance overpipe/downpipe with sport car and helmholz resonator
Other Mods: Perrin cold air intake and silicon intake hose, all Whiteline bushings (trans, diff, suspension, etc), Perrin pully,
Phone: Motorola Razor HD
Idle: 65dB
@5000rpm: 83dB *under load in 1st gear not sitting in neutral
@7000rpm: 91dB *under load in 1st gear not sitting in neutral
stockysnail is offline   Reply With Quote
The Following User Says Thank You to stockysnail For This Useful Post:
TAP Auto Parts (06-01-2013)
Old 10-20-2014, 07:13 AM   #13
pepe
Drives: gt86
you know the OEM exhaust decibels?
pepe is offline   Reply With Quote
Old 10-20-2014, 10:58 AM   #14
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Windows up, Inside cabin front of phone under shift knob
Exhaust: j2 quad
Mods: Ebay injen knockoff/crawford powerblocks/amr catless frontpipe/ecutek flexfuel tune
phone/app: Galaxy s4/sound meter
idle/neutral(750-800rpm):71db
1st gear underload(5000rpm):84db
1st gear underload(7000rpm) 89db
Not sure how accurate this app is but its great way to benchmark exhausts if everyone uses the same app. Noise level sounds way louder than 89db to me.
brichard0625 is offline   Reply With Quote
Aftermarket armrest compilation list CaptainSlow Cosmetic Modification (Interior/Exterior/Lighting) 86 01-25-2015 09:19 AM
Does TRD diffuser work with aftermarket exhausts? sittinSideways Cosmetic Modification (Interior/Exterior/Lighting) 10 05-16-2013 12:58 AM
Coolant Levels DriftEightSix AUSTRALIA 17 01-29-2013 09:19 AM
Aftermarket Exhausts? devinclfalcons Engine, Exhaust, Transmission 309 10-18-2012 02:07 AM
2013 FR-S/BRZ North American OE and Aftermarket Parts List xravexboix Scion FR-S / Toyota 86 GT86 General Forum 29 06-04-2012 03:39 PM
