#57 |
Drives: BRZ 6MT
#58 | |
Drives: CBS Subaru BRZ Limited
Also I'm so glad I got the windshield/remote/PDR insurance when I bought my car because within 3 months I got a mysterious crack an hour after parking outside. Then about a month ago on the freeway I got a small knick on the windshield, almost another crack but not yet. Seems like it's easily cracked, not sure because the angle or the glass but that's basically twice in a year. |
#59 |
Trust me, I'm the Doctor
I just got my windshield replaced on Friday due to significant pitting within driver's line of sight. $0 deductible with USAA, and they even managed to get dealer glass too.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#60 |
Drives: Scion FRS 2.0 6AT
You can add me to the list as well fellas...walked out to my car Monday after work and found a small crack near the top of the windshield (passenger side). It hasn't spread as of now *knocks on wood* and I'm hoping it stays that way. I'll make sure to post a pic soon.
#61 |
Drives: 2013 WRB 6MT
I shopped around a bit and ended up going with an aftermarket option for about $480 installed. New windshield is holding up well about 10k miles in. I'm typically an OEM-only sort of guy when it comes to repairs, but I really think aftermarket is the way to go here.
#62 |
Just got a quote here in Austin TX from longhorn glass to replace mine for $199.95. Seems too good to be true?
#63 |
Drives: WRB BRZ
A place in Houston that sealed my chip quoted me $210. Seems like prices have dropped.
#64 | |
Drives: 2014 BRZ Limited
I replaced the $300 glass in my Jeep with $150 glass from the place in the parking lot of the Pull-a-Part, and that worked fine even though they did a sloppy job with the glue. It's kind of a beater so who cares. I wouldn't do that with my BRZ though. With the size and rake of this windshield, any imperfections in the glass are going to be more noticeable, both from inside and out. |
#65 |
Drives: 2014 GB Scoobie BRZ
408 dollars at safelite
#66 |
#67 |
Drives: World Rally Blue BRZ Limited, MT
So I just had me windshield replaced by Safelite. I went through my insurance and everything seemed to go great. However when I inspected the job after they left it seems that they just cut out my old windshield and glued the new one on top of the remain edge on the old glass. So basically it looks like I have 2 layers of glass. (I'll post a pic later) Is this common practice? this is my first windshield replacement.
- World Rally Blue BRZ | Limited | Manual -
"Some guys think that having a better car makes them better than other guys, and those guys are right." -Top Gear |
#68 | |
Drives: 2014 SWP BRZ Limited 6SP
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now. |
#69 | |
Drives: 2020 DGM BRZ Limited
#70 | |
1. Using a tool they run a steel wire through the existing factory seal, between the glass and the frame of the car. Using a suctioned ratcheting system, this cable is pulled along the edge of the windshield to break the seal. 2. Once the factory glass is removed, they use another tool to shave down the factory seal (Third and fourth images) - they leave some of the urethane in place to have the new urethane seal better (urethane to urethane seals better than urethane to metal) 3. The factory molding (the rubber piece of the windshield is applied to the sides and top, and a new bead of urethane is applied to the bottom of the windshield 4. It's placed back - you shouldn't see it stuck up any higher than the original windshield - if it is, something is likely wrong. I hope this helps! I work for the company but I'm not a windshield tech - I deal with their IT systems. |
| The Following 4 Users Say Thank You to mikalem For This Useful Post: |
| front door 6" speaker replacement mount | derka-derka | Electronics | Audio | NAV | Infotainment | 5 | 12-13-2012 11:23 AM |
| Replacement Front Rotors | Texas BRZ | Tracking / Autocross / HPDE / Drifting | 40 | 11-27-2012 03:44 PM |
| New windshield cost? | JimmyMac | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 21 | 11-05-2012 12:04 AM |
| Removing writing on front windshield | Chinadian | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 14 | 10-24-2012 07:08 PM |
| VIN not visible in front windshield. | Tonym427 | BRZ First-Gen (2012+) — General Topics | 6 | 09-16-2012 10:56 PM |
