Old 05-15-2014, 12:34 PM   #113
bluesman
Drives: 2015 FR-S
Originally Posted by CajunFRS View Post
So I guess no one knows who makes it...?
I called Topspeed and was told that they prototype their products at home in Texas, then spec them to their own factory in China for production. I suspect they don't actually own the facility - it's probably a huge contract shop like the ones that make guitar bodies in huge volumes to be sold under others' names.
My catback was shipped yesterday, scheduled for arrival Monday. The hardware's apparently zinc plated steel, so I'll substitute SS bolts, nuts & washers - I don't understand why anyone (except maybe in a very dry, warm climate) would leave anything in a SS system that will definitely rot and need replacement within a few years. I saw in an earlier post on this thread that the bolts are 14mm, and 9/16 is less than 0.02" larger. So if the flange holes are slightly oversize (which most are), 9/16F SS hardware will fit fine. And if the band clamp is also mild steel, I'll use a SS piece for that too.
I'm tempted to polish the bluing off the tips, since I'm not sure I like it. They're blued with chemicals, not heat - so it should polish up like the rest of the system with a little fine paper followed by some compound on a rag wheel. One way or the other, it'll be up and running by the middle of next week & I'll post when it's on.
bluesman is offline   Reply With Quote
Old 05-15-2014, 10:10 PM   #114
MPI_Jack
Drives: '13 FRS, '02 BMW 530i(550HP, turbo)
I polished it off mine. Sounds perfect once mated to a catless/resonator-less front pipe. No rasp no drone.
MPI_Jack is offline   Reply With Quote
The Following User Says Thank You to MPI_Jack For This Useful Post:
bluesman (05-16-2014)
Old 05-15-2014, 10:27 PM   #115
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
[ame="http://www.amazon.com/Outlet-Subaru-Exhaust-Muffler-Silencer/dp/B00HWIEMLQ/ref=sr_1_2?ie=UTF8&qid=1400207206&sr=8-2&keywords=spec+d+brz"]Amazon.com: 4" Dual Outlet tips Subaru BRZ FRS 4" Exhaust Muffler w/Silencer: Automotive[/ame]
Just got these in today. Looks good. $320 + free shipping (Even to Hawaii!)
Will put them on tonight and tell you how it goes!
fantah is offline   Reply With Quote
Old 05-16-2014, 08:51 AM   #116
bluesman
Drives: 2015 FR-S
I'm planning to use 400 grit paper, then 2000 grit, then compound on a 3" ragwheel in a hand-held power drill. But I'm happy to try a different method if you found something that works better or is easier to do.
Old 05-17-2014, 09:25 PM   #117
MPI_Jack
Mothers Aluminum/Mag polish and a rag works well.
bluesman (05-18-2014)
Old 05-18-2014, 03:35 PM   #118
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I'm looking at getting an exhaust for my car and the TopSpeed products caught my eye.
My car is my DD, so I can't tolerate anything overly loud or with drone, but I want to be able to hear my car when I get into it. I'm willing to rust proof it and/or hush mat my trunk if its too loud.
Should I get the dual canister, or the single?
Thanks!
Bobblehead is offline   Reply With Quote
Old 05-18-2014, 03:37 PM   #119
bluesman
Drives: 2015 FR-S
That's a lot easier than paper and a rag wheel - I'll have a go at it! I can't quite look forward to blued tips on my car, as hard as I'm trying. One minute I think they're cool and the next I think I'll tire of it fast.
Thanks!!
David
Old 05-18-2014, 03:54 PM   #120
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Thanks!
I would just go with the single/axle-back if you are worried about sound. BlueDubbinTDI is happens to be selling his to go back to stock because of his commute.
JonAvalon is offline   Reply With Quote
The Following User Says Thank You to JonAvalon For This Useful Post:
Bobblehead (05-18-2014)
Old 07-20-2014, 01:46 PM   #121
Kylefujiicaelian
Drives: Scion frs when i turn 16
Im sorry if this is a stupid question but
Do the top speed catback and top speed axleback sound the same?
Kylefujiicaelian is offline   Reply With Quote
Old 10-02-2014, 01:58 AM   #122
Firejetmanguy
Firejetmanguy's Avatar
Drives: 2013 Whiteout
I too am trying to decide between the race and the street. On an otherwise stock setup, would the race exhaust be loud enough to, let's say, be a nuisance to the neighbors? Also, how much louder is the street than the stock exhaust, again, with an otherwise stock setup?
Firejetmanguy is offline   Reply With Quote
Old 10-02-2014, 06:20 AM   #123
Bobblehead
Bobblehead's Avatar
The axle back/street set up is a Greddy SP Elite copy. I have one and its just a little louder than stock.
The race set up is a Greddy EVO3 copy. It is loud, it will drone.
Old 05-06-2015, 11:34 AM   #124
Swift2000
Drives: 2013 frs hot lava
I have the Borla UEL header, isis 2.5" overpipe, J2 catless front pipe, and the top speed
street catback. Its sounds amazing and there is absolutely no drone. The fitment is about 90%. Its just a tad off center coming out the bumper, but with some tweaking i think i can get it spot on.
Swift2000 is offline   Reply With Quote
Old 11-20-2016, 05:16 PM   #125
DatFR-S
Which exhaust to get
I've been looking into the Perrin 2.5 catback and the hks legamax premium catback. Can you guys help me on which I should get? I also want to put an injen cold air intake
DatFR-S is offline   Reply With Quote
Old 11-21-2016, 06:09 PM   #126
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
Can't speak for the hks, but I just had the 2.5 perrin resonated installed for 2 weeks and it really sounds great. No drone. It's more subtle and not too loud but definitely louder than stock whereas you can actually hear it in the cabin which I couldn't when I had the stock catback.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Oxyg3n is offline   Reply With Quote
Ballin' on a budget - good lookin exhaust on the cheap! Larkin Cosmetic Modification (Interior/Exterior/Lighting) 8 09-05-2013 02:34 AM
FS: MXP cat back exhaust in Socal mtsui Engine, Exhaust, Bolt-Ons 4 08-21-2013 12:27 PM
Like New OEM BRZ Cat Back Exhaust Zoomby_U Canada Classifieds 2 08-11-2013 10:16 PM
SRT Cat-back exhaust prest1ge Engine, Exhaust, Bolt-Ons 15 03-17-2013 02:37 PM
My new set of cat back exhaust Koe Engine, Exhaust, Transmission 23 10-13-2012 06:44 AM
