Old 05-14-2014, 05:37 PM   #547
Lord Peth
Drives: 2014 BRZ
Originally Posted by 1Cor10:23 View Post
You can adjust the output equation to convert to F I believe?
Its set to F, I changed it to C just to see what would happen and it was in the high 180s. Way above operating temperature
Lord Peth is offline   Reply With Quote
Old 05-14-2014, 06:09 PM   #548
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Use the settings for setting up the sensor as described in the first/second post - this reads in the raw data in C - then change the units in torque to F and it will convert for you. Values should range from 180 - 210 depending on how warmed up the car is.
The equation should be AC-40, not AF-40.
mikalem is offline   Reply With Quote
Old 05-14-2014, 11:54 PM   #549
CladMonitor
CladMonitor's Avatar
Drives: 2013 FR-S Asphalt
To switch vaules from Celcius to Ferhinieht the app has to convrert it unless you make a custom PID to adjust. Torque won't change the value until that gauge\value is pulled from ECU again.
Still no update on PID for IAM or Knock Count?
CladMonitor is offline   Reply With Quote
Old 05-15-2014, 07:57 AM   #550
Lord Peth
Drives: 2014 BRZ
Originally Posted by yamsta View Post
I thought I would share my current in-car tablet setup. I'm using a Nexus 7 with the iOttie Easy Smart Tap Dashboard Car Holder.
--yamsta
I ordered on of these based on your review, and I works great but now I have a ring on my dash after only two days of having it mounted
Old 05-15-2014, 09:06 AM   #551
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Can't avoid the ring - that's how you get a good seal. Might just be a bit of glue residue, try a bit of surface cleaner.
1Cor10:23 is offline   Reply With Quote
Old 05-15-2014, 03:00 PM   #552
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
Originally Posted by andreyiv View Post
Hey guys,
I found the Oil Temperature PID using TorqueScan and verified it by driving, as well as heating up only the oil temperature sensor area with the engine cold (and not running).
Without further delay, here's the info:
OBD2 Mode and PID: 2101
Minimum Value: -40
Maximum Value: 215 (this is just the maximum that this location can support, which does not mean the sensor can read that high)
Scale factor: x1
Unit type: C
Equation: AC-40 (no space between A and C; "AC" is the location within the response)
OBD Header: 7E0 (Auto also works, but seems to take longer)
Just as an aside, I don't know if it's my OBD adapter, or the Header needs to be tweaked (corrected), or if the response is not always long enough but every once in a while I'll get a reading of 189 or 1840 which are both incorrect. I'm not familiar enough with torque to figure out where these glitches are coming from.
Edit: The incorrect readings of 189 and 1840 I was getting were caused by a faulty OBD adapter. Just received another one and have no problems.
Enjoy!
Andrey
How'd you find it? I ask because i have an obd II project I'm starting to work on.
I'm having trouble decoding the 4 digit torque PID with an actual PID. Does 2101 mean mode 2 0x65?
If so, how many bytes does it return and which are you multiplying together and then subtracting 40 from to get the temp?
robot is offline   Reply With Quote
Old 05-15-2014, 03:35 PM   #553
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Check out www.gt86mounts.com
As far as the knock pid is concerned. I have someone who knows a lot about can bus and searching for PID's. The problem is he lives two hours away from me. Start a list of PID's that you would like and the next time I see him we are going to start working on it. Right now I want IAM and knock correction. It could be a fee weeks before I get them but it's something I have been wanting for a long time. I just so happened to meet the right person recently.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 05-16-2014, 03:40 PM   #554
Lord Peth
Drives: 2014 BRZ
I wiped it down with some 1Z deep cleaner, it appears to be the slightly squishy dash being compressed. I had to drop it off at the dealer to get some chips fixed after some asshat sprayed me with gravel, have to see how it looks next week.
Old 05-16-2014, 03:51 PM   #555
yamsta
daGangsta
yamsta's Avatar
Drives: 2013 FR-S 6MT
Sorry for the late follow-up. I had used that mount for a few weeks and took it off. The ring leaves a residue that only lasts a couple days and then goes away after cleaning. However since then I stopped using my tablet and started using my phone using this mount:
[ame="http://www.amazon.com/Tetrax-72028-Smartphone-Magnetic-Dashboard/dp/B0064SY1T8"]Amazon.com: Tetrax 72028 FIXWAY Smartphone/iPhone/GPS Magnetic Holder, Dashboard Mount: Automotive[/ame]
I find this a lot easier to use but keep in mind that its probably not strong enough to mount a full sized tablet.
yamsta is offline   Reply With Quote
Old 05-20-2014, 06:45 PM   #556
Lord Peth
Drives: 2014 BRZ
Yea, picked my car back up and the ring is gone...just set up the return with amazon and ordered the side mount from stugg racing
Old 05-27-2014, 06:37 AM   #557
Dipstik-sportech
Dipstik-sportech's Avatar
OK so it still will not connect to my ECU. It just tries the says "can not connect to ECU possible faulty adapter or ignition not switched on". The adapter works fine in my other cars and the car is running while I'm attempting to connect so the ignition is on. Could it be something to do with ecutek not allowing it access?
The Frozen North
Old 05-27-2014, 09:34 AM   #558
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
IAM would be fantastic!
ToyoburuBRZ is offline   Reply With Quote
Old 05-30-2014, 09:56 PM   #559
Cal3000
Drives: Panda FR-S
I used the code for the engine oil temp and for some reason when I use this custom PID, it works for about a minute, then can't locate the Blutooth anymore. When I don't have this custom PID, it works fine.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 05-30-2014, 10:27 PM   #560
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by calispec View Post
Right now I want IAM and knock correction. .
IAM is available in my datalogs:
http://datazap.me/u/stugray/za1ja00c...?log=0&data=41
The PIDs will be different for the various ROMs in our cars.
It is best to lookup the logcfg.txt for the tactrix datalogging for your individual ROM.
As for finding a direct knock counter that would be great.
The engine has two knock sensors. One on each head.
Maybe you could rig a buzzer or something to each of them and then log data while toggling the buzzer on and off. If there is a counter, you should see it incrementing in synch with the buzzer being on.
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
