#113 | |
Sent from my SCH-I535 using Tapatalk 2 |
#114 |
Version 2 Coming Soon...
Drives: Turbo Argento FRS, Asphalt FRS
I'm trying to determine if the torque app with a tab is a true solution for monitoring AFR and boost. Me and Pure Automotive are in the process of completing the Full Blown turbo build. Does the torque app work on cars that have been tuned by Ecutek, more specifically monitor Boost (psi) and AFR?
Part Out Thread: http://www.ft86club.com/forums/showthread.php?t=39992
#115 |
Yes. I have three tunes and reads specs just fine
#116 |
Do you believe that the ECU actually monitors boost accurately? What's the delay time like?
#117 |
As far as I know its accurate. There is a delay. I can get a video for you when I get my car back this week.
#118 |
Drives: Clio TCE
Wait, the stock ECU has a built in turbo management?
#119 |
Vacuum and boost are on the same scale. Its normal. One is the negative value and one is the positive.
#120 |
Drives: 13 White MT FR-S
I wish I could have more faith in this...
#121 | |
Drift King
Drives: '13 Firestorm FR-S 6MT
Brody
'13 6MT Firestorm FR-S
#122 |
You did see where it said 184hp and 194tq right? I doubt it especially @ 5000rpm
#123 |
Drives: Hot Lava FR-S
Torque Oil Temperature PID
Hey guys,
I found the Oil Temperature PID using TorqueScan and verified it by driving, as well as heating up only the oil temperature sensor area with the engine cold (and not running). Without further delay, here's the info: OBD2 Mode and PID: 2101 Minimum Value: -40 Maximum Value: 215 (this is just the maximum that this location can support, which does not mean the sensor can read that high) Scale factor: x1 Unit type: C Equation: AC-40 (no space between A and C; "AC" is the location within the response) OBD Header: 7E0 (Auto also works, but seems to take longer) Just as an aside, I don't know if it's my OBD adapter, or the Header needs to be tweaked (corrected), or if the response is not always long enough but every once in a while I'll get a reading of 189 or 1840 which are both incorrect. I'm not familiar enough with torque to figure out where these glitches are coming from. Edit: The incorrect readings of 189 and 1840 I was getting were caused by a faulty OBD adapter. Just received another one and have no problems. Enjoy! Andrey Last edited by andreyiv; 02-12-2013 at 09:49 AM. |
| The Following 49 Users Say Thank You to andreyiv For This Useful Post: | 2forme (02-03-2013), 3essess (12-11-2013), 86drift (02-04-2013), @Art_Mighty (06-22-2015), Area86 (02-03-2013), B L U E S L A T E (11-05-2013), Brody602 (02-04-2013), cobrabyte (03-13-2013), CxG (01-12-2017), d1ck (02-03-2013), dasting (10-27-2020), developer (02-17-2013), Draco-REX (04-22-2014), ft_sjo (02-04-2013), garfull (09-16-2013), Guillaume (02-04-2013), IBill4You (06-06-2015), jsooke (08-21-2014), jwoodland (08-20-2014), keelerad (02-06-2013), keen as (02-06-2013), Laika (02-03-2013), lazyluka (02-04-2013), LeeMaster (02-03-2013), melon (02-16-2014), michaelxchristopher (07-04-2018), ML (02-07-2013), Ninjin (02-03-2013), nix (02-08-2013), nzer (02-04-2013), orthojoe (02-03-2013), Pete (02-06-2013), pheoxs (02-04-2013), PineappleFriedRice (11-22-2013), pixel67 (02-03-2013), pkny (02-05-2013), Pug (02-04-2013), RJ_ (02-06-2013), Sarlacc (11-30-2013), Sideways? (02-04-2013), t0dd (02-04-2013), The Slow One (02-04-2013), ultra (12-17-2013), whataboutbob (01-01-2020), ybotspawn (06-30-2014), Yobiwan (02-04-2013), Yruyur (02-03-2013), zoomzoomers (04-09-2013), zoth (06-03-2014) |
#124 | |
#125 | |
Because compromise ®
Drives: Red Herring
I have the Mini ELM327 V1.5, I have TorquePro. Thanks |
#126 |
Drives: SWP BRZ 6MT
Open the Torque app and then hit the menu button. Select "Manage extra PIDs/Sensors" (should be second from the bottom).
Hit the menu key again and select "Add custom PID". Enter the information provided by @andreyiv (And a full and short name of your choice). Hit ok. The oil temp parameter will now be available for logging and real time display. |
| The Following 5 Users Say Thank You to Ninjin For This Useful Post: | Captain Snooze (02-03-2013), CxG (01-12-2017), keelerad (02-06-2013), Sportsguy83 (02-03-2013), zoomzoomers (04-09-2013) |
| Tags |
| android, app, boost, gauges, torque |
| Torque app for android question | Brody602 | Electronics | Audio | NAV | Infotainment | 8 | 01-08-2015 04:53 PM |
| Torque for Android | Freeman | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 11-22-2012 11:05 PM |
| Android Torque app questions | Craig | Engine, Exhaust, Transmission | 1 | 11-12-2012 04:14 PM |
| Bluetooth OBD scanner and Android Torque - less than 25 shipped | whataboutbob | Engine, Exhaust, Transmission | 7 | 10-20-2012 01:15 PM |
| Android Tablet + torque | CharlieChaos | Electronics | Audio | NAV | Infotainment | 3 | 10-04-2012 08:23 PM |
