Old 11-12-2012, 03:45 PM   #1
Craig
Craig's Avatar
Drives: Asphalt FRS
Android Torque app questions
I recently purchased one of those nifty bluetooth ODBII scanners off of amazon for $12 shipped. Got lucky as the one I received isn't faulty, fired up my Torque app and got to cruising. My main reason for setting this up is I recently ordered a drop in filter / intake tube and would like to measure my AFR before and after the install to be sure that there's not a huge difference... It's also pretty badass to have some gauges to look at whilst cruising.
So my question is, there's obviously a logging feature, and for whatever reason I cannot seem to view the logs on my computer. I've got a macbook pro and a windows based desktop, neither of which I've been able to find a program to view the logs. I went to the Torque webpage but I am unable to make an account for whatever reason. I was wondering if there's another, non web based way to view the logs.
Also, when I try to add the AFR widget to the homescreen, it doesn't give me any values, it only states that the system is OK.
Finally if I don't plan on boosting my car, is there any added benefit to purchasing the full application?
I used the feature on ft86 and found nothing, If I've missed something kindly point me in the right direction!!
~Craig
Craig is offline   Reply With Quote
Old 11-12-2012, 04:14 PM   #2
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
What i do is go into setting and set-up what parameters i would like to log. After i do i run i email the logs as a csv file(separated with comas) and i use excel to open the file. U can few everything from there.
brichard0625 is offline   Reply With Quote
BT OBDII/Android/Torque Confirmed working Dadhawk Engine, Exhaust, Transmission 54 12-06-2012 12:57 AM
Bespoke Android Cheddar Electronics | Audio | NAV | Infotainment 5 11-07-2012 08:16 AM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
Android vs iOS vs BB os...which is best? Raiden Off-Topic Lounge [WARNING: NO POLITICS] 19 02-02-2011 10:37 PM
