Old 05-15-2014, 12:28 PM   #85
fredfromnh
Drives: 2013 scion frs
At 25k I am on motor #3. First one blew rocker assembly off. Dealer did sloppy job replacing short block. Rtv got every where including oil passages. Felt it tie up on highway. Regional manager then got me hand assembled motor from factory. Everything new other than manifolds accessories etc. Seems good so far. I will avoid ecutek tuning as computer needed to be replaced 4 times. I was told that original toyobarus were a lot more powerful but were detuned as reliability issues cropped up in testing. I will continue to drive it like sports car. Toyota really took a hit on this one as last motor job alone cost them 10k. I'm any mods should be focused on power under the curve to avoid too much revs. I will probably get flamed for telling the truth but screw it.
fredfromnh is offline   Reply With Quote
The Following User Says Thank You to fredfromnh For This Useful Post:
dave77 (05-15-2014)
Old 05-15-2014, 01:07 PM   #86
acg2010
Drives: 4 wheels/engine/seats
Originally Posted by Annahra View Post
I would be concerned if all of the issues seemed related to a specific failure point, but other than the idle/CEL issue which seems to be resolved, there's no consistency.
Sent from my SPH-L720 using Tapatalk
Agree. There are bound to be bad engines in the lot, I'd be far more concerned if they all had the same problem leading to catastrophic failures.
acg2010 is offline   Reply With Quote
Old 05-15-2014, 01:14 PM   #87
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
I believe it. This motor has always "seemed" detuned to me, though it's just a hunch.
dave77 is offline   Reply With Quote
Old 05-15-2014, 01:22 PM   #88
HunterGreene
Hail Magnet
HunterGreene's Avatar
With the insane amount of aftermarket attention this platform has been getting, including across two different manufacturing lines, your "hunch" that the motor is detuned may be a bit off. If it that were the case, wouldn't some tuner out there discovered a way to unlock this by now? Its only been almost 3 years now...
It has priests in it?
Old 05-15-2014, 01:37 PM   #89
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Monogram View Post
The first link is regarding a Perrin light crank pulley equipped engine with two crank bearing failures ...
You can extrapolate from there
I am all up for saying the engine is stout and all... But really...
I have the Perrin pulley since 1K miles... 16K miles now, 8K boosted, none of my mods seem to be spinning my bearings...
Old 05-15-2014, 01:47 PM   #90
mothespaceman
mothespaceman's Avatar
Drives: 2014 BRZ SWP
Was the low idle issue actually ever resolved? I have a new '14 and the idle dips pretty hard on occasion while decelerating.
mothespaceman is offline   Reply With Quote
Old 05-15-2014, 01:55 PM   #91
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
I resolved it by getting an OFT and stage 1 tune. I tried the factory reflash (Nov 12 build date) but it didn't really do anything other than make the car feel a bit more sluggish at high RPMs and they would still drop hard. Only downside to a tune is you pretty much have to run 93 if you are running it hard on a hot day, but I only put 93 in mine since I got it so it was no big deal.
I've heard Subaru puts some pretty shoddy tunes on their cars from the factory though to account for lower fuel grades, so I expected to have it tuned when I bought it.
Sent from my XT1056 using Tapatalk
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
Old 05-15-2014, 01:56 PM   #92
mothespaceman
Sweet, man! I've been running 93 since day one, so that is no big deal to me either.
I've been thinking of going Unichip as it's removable, is OFT pretty easy to use?
Old 05-15-2014, 02:07 PM   #93
Xinshadow
Super easy, literally 10 minutes and 3 button presses. It also saves a copy of your stock tune you can revert to later if need be.
The Following User Says Thank You to Xinshadow For This Useful Post:
gramicci101 (05-15-2014)
Old 05-15-2014, 03:17 PM   #94
extrashaky
Drives: 2014 BRZ Limited
Mine blew at 37K. This makes me less inclined to think it was due to the year old front end repair.
Originally Posted by Mr 286 View Post
One accident - pickup truck backed into it
$14,000 in parts/labor.
One thing to consider beyond what's already been discussed: If the engine was running during these wrecks and was brought to a sudden halt by the accident, there can be internal damage that is not apparent. Whenever a piston aircraft has a prop strike (the propeller hits the ground or some other object), FAA regulations require that the engine be disassembled and inspected, even if it's running fine after the strike. That's to avoid engines failing in mid-air because of undetected damage from the prop strike.
Obviously we don't have to worry about dead stick landings in our cars, but there have been plenty of cases where front end damage appeared to be cosmetic only but ultimately ended up causing an engine failure long after the insurance adjuster is gone. I had front end damage to my Jeep that cause the radiator to make contact with the fan and stop the engine, and I was sweating over the potential for internal damage.
Yep, the secret is to get a really BIG monitor and set Windows to LARGE print ......
Here's my desk:
The Following User Says Thank You to extrashaky For This Useful Post:
humfrz (05-15-2014)
Old 05-15-2014, 04:25 PM   #95
Luis_GT
Original as in the first retail models or prototype?
Old 05-15-2014, 04:28 PM   #96
Sportsguy83
Drives: Limited BRZ
Oh the stories of Unicorn tears falling from the skies....
The Following 6 Users Say Thank You to Sportsguy83 For This Useful Post:
FRSBRZGT86FAN (06-10-2014), gramicci101 (05-15-2014), HunterGreene (05-15-2014), strat61caster (05-15-2014), suaveflooder (05-17-2014), xwd (06-05-2014)
Old 05-15-2014, 06:33 PM   #97
gramicci101
Off Topic
Originally Posted by extrashaky View Post
Here's my desk:
Your desk needs to be cleaned.
Old 05-15-2014, 07:17 PM   #98
acg2010
I finally got around to reading that last link: The guy hydrolocked his engine.
I think he's agreeing with you. I think he had a typo or something that may be confusing, but it sounds like he's saying the cars engine is pretty tough, and that it's rare cases that are having huge failures.
blown engine
Engine Failure (#4 Rod Bearing + Short Block) eriktherod Issues | Warranty | Recalls / TSB 215 10-30-2015 12:24 AM
Crawford posts of engine failure example at 218hp OICU812 Engine, Exhaust, Transmission 95 03-27-2015 05:40 PM
Major accident/Engine failure after repeated P0351/P0017/P0019 DB86 Issues | Warranty | Recalls / TSB 48 09-16-2014 03:05 PM
Stock Engine Failure Annahra Issues | Warranty | Recalls / TSB 37 06-25-2014 01:42 PM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
